supercharging my 2.2 tomorrow
Old 12-27-2008 | 02:34 AM
ei3dag3's Avatar
well tomorrow we're (centexcc) going to supercharge my 2.2 been building up and collecting parts since september, and finally now that i've taken off a week...as well as not in school we can finally do it.
http://www.centexcarclub.com/forums/...hp?topic=979.0
more info on the build etc...
i'm so excited. finally moving up into the fi world.
next will be the clutch, as i know mine will be going out with that much power on it.
then an engine build, and even more stuff to come
wish us luck.
Old 12-27-2008 | 03:09 AM
HunterKiller89's Avatar
good luck with everything man, and feel free to txt me or PM me here if u have questions
Old 12-27-2008 | 03:41 AM
ei3dag3's Avatar
oh yea that reminds me of that pic ! lemme know if you can't get that for me.
and thanks ill def be using your knowledge haha
Old 12-27-2008 | 03:45 AM
scottyguy401's Avatar
So how much did everything cost you, did you keep track?
Old 12-27-2008 | 03:51 AM
ei3dag3's Avatar
-supercharge build - 2120 total
(Parts List:
Eaton M62 Supercharger - mine
Stock LSJ Intake Manifold - mine
Intake Manifold Bottom Mount - mine
Boost/Vacuum Gauge - mine
42.5# Injectors - mine
Stage 2 Belt - mine
Dual pass endplate - mine
lsj h/e - mine
ic pump Mounting Bracket - mine
2.5 Bar Map/Intake Temp Sensor - mine
2.5 Bar Pigtail - mine
LSJ Intercooler Pump - mine
Extended Upper Radiator Hose - mine
lsj air box - mine
aem wideband afr - mine
cobra h/e - 125
trifecta tune - 285
injen intake - 120
spark plugs - 45
lsj 42 lb - harness - 50
reservoirs, gaskets, pulley bracket, sc sticker - 200)
Old 12-27-2008 | 03:52 AM
Was that everything bought new or used?
Old 12-27-2008 | 04:04 AM
ei3dag3's Avatar
a mix of both. 90% was used though
Old 12-27-2008 | 04:32 AM
redssna's Avatar
Good luck man hope everything goes smoothly for ya.
Old 12-27-2008 | 04:35 AM
ei3dag3's Avatar
thanks! we're gonna need it
Old 12-27-2008 | 04:37 AM
SlowBalt_06's Avatar
auto ...or this will fail
Old 12-27-2008 | 10:01 AM
Dayta's Avatar
cant wait to see this
Old 12-27-2008 | 10:04 AM
DebadgedBALT77's Avatar
good luck man! pics and vid when done. also post pics during the build process.
Old 12-27-2008 | 10:08 AM
El Mariachi's Avatar
nice, cant wait to see the conclusion
Old 12-28-2008 | 12:33 AM
ei3dag3's Avatar
well just an update.
we took off the pins from the lsj harness with the 42s and repinned it into the plastic sensor part for the 2.2. so no soldering required.
turned my single pass end plate into a dual, mounted the pump, the manifold, and the stock h/e.
still gotta install all the other piping, and the cobra h/e, as well as the option b.
also the sc of course, need to get the injen intake..should be coming in the mail. and that tune from vince...and since hes been under 2 ft of snow in seattle he hasn't been able to send it. also gotta install my mrz stock size crank pulley.
really tired. out for the night. will def be updating with pics and vids no worries.
thanks guys
Old 12-28-2008 | 01:05 AM
Preston's Avatar
week sauce
kiddding
Old 12-28-2008 | 01:09 AM
nikebaseballx00's Avatar
sounds like ur moving right along, good luck
how hard has the install been?
i may go this route instead of turbo because it seems cheaper/easier
Old 12-28-2008 | 01:52 AM
ei3dag3's Avatar
the install hasn't been bad.
just a couple of random issues, like making the stock h/e fit right.
lsjs have 2 fans with a space between them, we have 1. so the welded on bent piping for the h/e doesn't fit ...so we just cut it off at the bottom and made it work.
i think thats the main issue we've run into so far....
other than that. the change of the radiator hose was easy.
so was taking out the dipstick, and moving the ac condensor lines a bit to make everything sit right.
its pretty cut an dry. i'm using an lsj throttle body, ill have to repin that to make it work right, but you don't necessarily have to use that.
we also have to install the tensioner...and since my friend juan fucked up my belt for the sc setup, we'll have to get another. (you have to cut a rib off to make it work on our cars)
idk, its pretty easy...it would have been done had we not had to drive back and forth to round rock (about 15-20 mins away from hutto where the car club pres lives) to get stuff like some drill bits, taps, and random screws and bolts haha. but i've got time, and since my tune isn't gonna be here till monday i can wait.
and idk, i think a turbo build is much easier than the sc build..but the sc build isn't bad either. it is cheaper though.
Old 12-28-2008 | 01:55 AM
cool thanks for the info
how long do u think it would take to install with a few people
Old 12-28-2008 | 02:02 AM
ei3dag3's Avatar
hmm, really if you don't do dual pass, or option b (not necessary at all)
a day easy. its pretty much just repinning, relocating certain things, and bolting stuff in.
..that is if you aren't like us and like to get food, and grill and drink a bit too haha.
we had most of the club over. most were just chillin, having a good time. so it was hard to get to seriously into it. 2-3 guys working alone, would easily knock it out in a day, if even that long if you had all the right parts.
Old 12-28-2008 | 02:05 AM
yea i probably wouldnt go dual pass or option b
i just want something decent with around 250hp
Old 12-28-2008 | 02:35 AM
so...wanna show me how you re-pinned the harness? i got some 60's in my closet just waitin to be thrown on the car, and would love to skip the re-soldering process...lol
Old 12-28-2008 | 02:43 AM
Jn2's Avatar
Jn2
i did the re-pin'n took me a good 10 min to do lol
is hard to explain, PM xcobalt05x for details on it, im too lazy right now to post it
Old 12-28-2008 | 04:08 AM
laaaame...lol
Old 12-28-2008 | 11:20 AM
ei3dag3's Avatar
yea no prob casey.the repin is pretty easy.
i would have done it, had he not been all stubborn about it haha.
all you did to pull the pins out is grab small pliers and move the pins a round and pull from behind.....only after you've taken the plastic pin that keeps the wires in place from the back. from the 2.2 side...you never take out the map. follow the diagram for the repinning order. its pretty easy. just a suggestion, label your injectors, and it makes it even easier once you've taken the tape holding them together. any questions ask me, or juan.
Old 12-28-2008 | 11:25 AM
WhiteSSBalt's Avatar
Not a Sebring
Very nice. Good luck!
Quick Reply: supercharging my 2.2 tomorrow
