| Forum Jump | Gallery | Social Groups | VBgarage | Videos | Chat | Link To Us | Decals | Site Map | Contact Us |
| 2.0L LSJ Performance Tech 205hp Supercharged SS tuner version. 200 lb-ft of torque Technical Discussions ONLY! |
Thread Tools | Display Modes |
#1 |
I had my 2006 Cobalt SS Supercharged dynoed when it was bone stock and it made 211.4 HP. I installed an AEM dryflow filter, did the airbox mod, and installed the GM Performance Stage 1 upgrade (fuel injectors and tune). After the installs, the dyno run showed only 213.6 HP (a gain of only 2.4 HP).
Has anyone else dynoed their Cobalt before and after the GM Stage 1 upgrade? I was expecting much more from an upgrade that promised 30 HP over stock, and I didn't even get 1/10th as much horsepower as GM advertises. Here is the video of the GM Stage 1 dyno pulls. Let me know what you think. I think it shows how under-rated the Cobalt really is stock. It is deceptive though that GM advertises so much more horsepower than you actually get with Stage 1. http://videos.streetfire.net/video/G...ock_634271.htm Enjoy Eric |
#2 |
Member #: 8418
why did you only get stage 1???
It was only a fuel injector upgrade, considering that they should of given you a tune up to 7,000 rpms if im not mistaken.... I forgot if thats just stage 2 or not but that would be the difference maker right there
__________________
Currently 1995 Civic Si with gsr swap and lots of other soon to be goodies
My honda build thread http://www.cobaltss.net/forums/showthread.php?t=174465 |
#3 |
Member #: 21039
wHY WOULD U GET STAGE 1??
That was the first mistake Stage 2 is the way to go This coversation is over bro
__________________
'09 BLACK COBALT SS/TC W/LSD,HIGH RISE WING & SUNROOF
Mods:HAHN 3" Exhaust,ARK Shorty Antenna,TTR Motor Mount,AEM CAI,Hahn Intercooler,Hahn Intercooler piping,Hahn 3" Maxflow downpipe W/cat,HKS SSQV BOV,Bsr PPC Tuned,Hahn Block off plate,TTR sway bar,Ottp Rotated Mounts myspace.com/jvcougar: ![]() ![]() |
#4 |
man that sucks...stage 1 FTL
__________________
![]() http://mrsilent13.mybrute.com fight me Damn Norcalers letting their power/weight ratio race for them |
#5 |
Member #: 8418
you spent like 300-400 beans on stage 1 when you can get stage 2 for 550 bucks and installs for 150-200 bucks....
the pulley is going to make the biggest difference not the fuel injectors.... Also i have never seen any ss/sc gain only 2 hp from a mod like that... Ive always seen good numbers from the upgrade, what probably happened is that the guy running dynoying your car didnt no you can run it up to 7 grand, considering that redline on the tach is 6500....tell him to go up to 7 grand if you hit redline then they didnt tune your car and you need to take it back to chevy!!!!!!
__________________
#6 |
Member #: 22785
ott. that sucks was it installed correctly???
#7 |
I will answer a couple questions, I got stage 1 instead of stage 2 so I can still run in my class during autocross events. They don't allow you to change the pulley size on superchargers, or increase boost pressure on turbo cars and stay in the stock division.
I figured that the value of 30 hp over stock for about $400 was a good value, so I chose Stage 1. Plus, I didn't want my car to run lean on the factory fuel injectors when I am pushing it to the limit at high rpms on the track. My redline did increase to 7,000 rpm, but I don't really see any increase in power. It just holds the stock HP levels all the way to 7,000 rpm instead of only 6,500 rpm. If you look at the DYNO graph that GM publishes for the Stage 1 upgrade, they used a very thick line to mask how similar stage 1 is to stock. |
#8 |
When i had only stage 1 i felt a nice bump in power from 5500rpm - 7000rpm .... You should have at least made it into the 220's whp range with stage 1. True that all it does is extend the stock power range to 7000 rpm, but these cars keep making power after 6500 rpm so you should have gained more than 2 or so hp.
__________________
2007 Laser Blue Metallic Cobalt SS/SC
Tune: GM Stage III, Pulley: GM Stage III (76mm), Injectors: 42 lb/hr., Intake: AEM w/K&N Filter, Exhaust: GMPP Manifold, ZZP 3" Dp, GMPP Touring Muffler, Cooling: Opt. B, 80/20 mix + RL Water Wetter, Traction: Ingalls TD set @ 10mm, SS/TC Mounts, Diagnostics: Aeroforce Interceptor, Appearance: Painted Engine Covers, MRZ Fuse Box Cover, GMPP Pedals, GM Armrest, ARK Shorty Antenna, Vent Visors. ![]() |
#9 |
Member #: 29455
hmmm my 06 ss/sc is "bone stock" right now and i dynoed it @ 216whp on a dyno jet dyno!! ???
__________________
2006 Chevy Cobalt SS/SC: 216whp 182tq
Appearance: Tinted Tails, Custom Shorty Antenna (8 Inches), Gunmetal Front Bowtie, RTX 6000k HID Lighting System, Debadged Trunk Power: Airbox Mod Performance: Slotted Rotors |
#10 |
Did you rev to 7,000rpms? The only place it makes teh additional HP is above the stock 6,500 rpm limiter.
__________________
Tuner of 2.2L, 2.4L, 2.0L S/C, 2.0L T/C Cobalts, and Ford Mustangs
#12 |
Member #: 23893
My 06 G85 bone stock made 238.8 WHP and 189 WTQ on the heartbreaker at SMG in mass, you know what I mean by heart breaker! It really all depends? I assume the break in is the absolute most vital thing!!!!
__________________
#13 |
i just watched your video .... it doesnt sound like they brought it to your 7000 rpm rev limiter. Everytime, they cut the dyno short .... prob at 6500 rpm. Look at your dyno sheets and make sure they ran it to 7000 rpm. that could be the solution to your problem. on a good note, your car is very consistant with hp numbers between pulls.
__________________
#14 | |
Got Corn?
[img]http://**************/images/smiles/newbie.gif[/img]
Although your results are common they are not unexpected. The stock 34# injectors have no problem providing enough fuel for the stock 3.35" pulley. The GMS 42# injectors will allow you to build for my hp in the future. Don't let anyone tell you that you made a bad purchase. You actually saved yourself some money because now you can buy a Modular Pulley System (MPS) much cheaper then GM charges. http://smoothflowpulleys.com/Stage2.html And you can order a 2.9" pulley right off the bat. Instead of getting GMS2 which includes a 3.1" pulley and then going out and buying a 2.9" pulley. You probably saved yourself at least $150 once it is all said and done. Now go and order your MPS and get back on the dyno! Quote:
^^^^This statement is false. Everyone knows that the LSJ does NOT make more hp past 6500 rpms. Unless you are running aftermarket cams or a different power adder. After 6500rpms the hp always drops off.
__________________
I like OTTP, ZZP and TTR! Get over it!
06 Silver RL 329whp/290wtq Cook something sweet and surprise the wifey! Last edited by ebristol; 02-06-2009 at 11:41 AM. Reason: Automerged Doublepost |
#15 |
Here are the stock dyno graphs.
http://videos.streetfire.net/photo/S...no_1013558.htm Here are the stage 1 graphs plus the stock all on one graph. You can clearly see that the rpm cutoff is higher with stage 1 than stock (6,500 rpm vs 7,000 rpm) http://videos.streetfire.net/photo/A...pg_1598160.htm Here is just stage 1 dyno graphs. http://videos.streetfire.net/photo/G...pg_1598161.htm Yes, all of the dyno pulls were done on the same dyno with the same conditions. Yes, the operator did bring it to 7,000 rpm because I told him the rev limiter was changed with the Stage 1 tune. |
#16 | |
Quote:
__________________
#17 |
Member #: 7822
HuH?!? Every SS/SC cobalt I have seen with either Stage 1 or Stage 2 always makes HP all the way to 7K. If your HP drops off at 6.5K then there is something wrong with the car.
__________________
![]() ---=Victory Red '05 Cobalt SS + G85=--- - GM Stage 2 + Nate's 75mm Pulley - Dual Pass Intercooler + Option B - Ingalls ETD - K&N Drop in - GMPP Extrude Honed Exhaust Manifold - GMPP Performance Exhaust - NGK BKR7E @ .038 |
#18 | ||
Got Corn?
Quote:
Quote:
Just like the guy in this thread. Peak hp about 6600. NOT 7k!
__________________
06 Silver RL 329whp/290wtq Cook something sweet and surprise the wifey! Last edited by ebristol; 02-06-2009 at 12:15 PM. Reason: Automerged Doublepost |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
