Forum Jump Gallery Social Groups VBgarage Videos Chat Link To Us Decals Site Map Contact Us
Cobalt SS Network Forums
The Cobalt SS Network is the leading resource for all Chevy Cobalts and related Delta
platform cars. Registered users do not see the above ads. Please Register - It's Free!
Supporting Vendor Index | Vendor Forums
Go Back   Cobalt SS Network > Engine Technical Discussion > 2.0L LSJ Performance Tech
2.0L LSJ Performance Tech 205hp Supercharged SS tuner version. 200 lb-ft of torque
Technical Discussions ONLY!
Thread Tools Display Modes
Old 04-05-2009, 01:15 PM   #1
bwalker0510
Member #: 19430
Check out my gallery  Check out my vbgarage
white smoke from vent
so im thinking i might have blew my pistons rings. i have white smoke that only comes from the vent on the valve cover. somewhat of a wrx sound but im turbo not sc so its sounded like that for awhile. and the car runs fine and pulls fine. i havent gotten on it at all though since the smoke started. anyone with real knowledge care to chime in. thanks guys.
__________________
T3/T04E 57 trim .63 a/r at 20 psi, snow performance meth kit, built and studded block, vulcan intake manifold
You call it lag, i call it temporary traction improvement!
bwalker0510 is offline   Reply With Quote
Old 04-05-2009, 01:16 PM   #2
BLAZIN07SS
BLAZIN07SS's Avatar
Member #: 17170
Images: 19
compression and leakdown test. go now
__________________
OTTP - Often Imitated, Never Duplicated
TURBO BUILD IN PROGRESS!
BLAZIN07SS is online now   Reply With Quote
Old 04-05-2009, 01:16 PM   #3
ItalianJoe1
Member #: 3956
Do a compression test and find out.
How do your plugs look?
__________________
ItalianJoe1 is offline   Reply With Quote
Old 04-05-2009, 01:19 PM   #4
bwalker0510
Member #: 19430
the plugs look perfect. and i shined a light into the spark plug holes and from what i could see there was no oil or coolant on the pistons.
theres noone around here open today to do a compression test.
__________________
Old 04-05-2009, 01:24 PM   #5
ItalianJoe1
Member #: 3956
You can buy a compression tester from Autozone or some place like that, there has to be one open near you somewhere. They aren't very expensive <$50, and not a bad thing to have if you do any work yourself.
__________________
Old 04-05-2009, 01:28 PM   #6
bwalker0510
Member #: 19430
yeah i do all my own work minus tune and weld. dont know how to tune. dont know how to weld nor have the space in the garage. i guess ill be ordering a cosmetic head gasket and diamond pistons ina month or so. italianjoe i know you always got parts laying around. happen to have anyone of those
__________________
Old 04-05-2009, 01:28 PM   #7
Jackalope
Haters.......SUCK MY,
Jackalope's Avatar
Member #: 9496
Images: 22
What they said. Also if its blown and leaking compresion then there wouldn't be anything in the cylinder cause the compression is blowing it outward. Does that make sence?
__________________
Pontiac saved the best for last.
Jackalope is offline   Reply With Quote
Old 04-05-2009, 01:31 PM   #8
bwalker0510
Member #: 19430
yeah it makes sense. hince that would be the smoke i guess. but last time this happen i had cruise set at 55mph and it backfired really bad and blew out my dipstick and covered everythig in oil. and it was the number 4 piston. this time i was sitting in a turning lane and smoke started coming from under the hood.
__________________
Old 04-05-2009, 01:32 PM   #9
ItalianJoe1
Member #: 3956
Quote:
Have both, but used
I gotta pull down my old shortblock (the one with the split sleeve) and see how the pistons faired, they probably are fine, just ring damage. That motor only had 5K miles on it before it decided to give up on me.
__________________
Old 04-05-2009, 01:34 PM   #10
bwalker0510
Member #: 19430
so you do have some diamond pistons?
__________________
Old 04-05-2009, 01:36 PM   #11
ItalianJoe1
Member #: 3956
Yeah, Diamond 10:1 with ceramic coated tops, but like I said they are sitting in my old block under the bench in the garage. Once I get the other LSJ down there off the engine stand, i'll toss mine up there and take it all apart, salvage what I can and scrap the rest.
__________________
Old 04-05-2009, 02:44 PM   #12
bwalker0510
Member #: 19430
wouldnt that compression be to high for my turbo set up and 20psi.
well i took the breather filter for the valve cover off and wiped the inside with a cotton swap. its m**her fu*k*ing milky. so yeah i guess something is blown. anytips on how to rebuild this thing lol. anyone got a book for it.
__________________
Old 04-05-2009, 03:37 PM   #13
ItalianJoe1
Member #: 3956
There is an LSJ build book out there, you can get it all online or buy an acutal copy. Or get a Haynes manual, has all the instructions and torque specs and stuff. These motors are fairly straight-forward to put together, not bad at all.
Compression is up to you. Higher compression makes more power, I was doing it because of the bigger cams I was running. You get a loss in effective compression when you increase overlap, so I was basically going back to stock compression instead of dropping below it.
__________________
Old 04-05-2009, 06:22 PM   #14
bwalker0510
Member #: 19430
so with a good tune i should be safe though right. i have a really good tuner so im not to worried about it if its up to the quality of the tune.
__________________
Old 04-05-2009, 10:38 PM   #15
ItalianJoe1
Member #: 3956
Yep, it's all in the tune.
__________________
Old 04-06-2009, 11:53 PM   #16
bwalker0510
Member #: 19430
ok well just send me a pm with the price in what not and ill have the money ina about 2 weeks. now will i be able to use the rings already on there or do i need to replace them. also is there anything i can do with the head other than cams to lower the compression abit. while its off im going to port and polish it. but im keeping all the stock valve train.
__________________
Old 04-07-2009, 12:09 AM   #17
ShortStack
Member #: 27978
Images: 24
could there be a oil feed problem?
__________________
2005 Cobalt SS TurboCharged LsJ?!? / s20g
Whoosh.
ShortStack is offline   Reply With Quote
Old 04-07-2009, 02:24 AM   #18
ItalianJoe1
Member #: 3956
Thicker head gasket or a little material removal from the combustion chamber, it's only .5 more than stock though, not that bad. You will need new rings, there isn't any good time to re-use rings, and the ones on the first cyl are probably damaged from where the sleeve let go.
__________________
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©Cobalt SS Network, Enthusiast Networks LLC - All posts are the opinions and copyright of the original authors and must be referenced with a link.
This site is not affiliated nor endorsed by General Motors. Chevy Cobalt and related trademarks are the property of GM.
