An SS/TC Without The Turbocharger!!!
Old Jun 2, 2009 | 12:19 AM
08ShowbaltLS's Avatar
How much hp do you think an LNF 2.0 thats naturally aspirated would make to the flywheel?
Last edited by 08ShowbaltLS; Jun 2, 2009 at 12:19 AM. Reason: Automerged Doublepost
Old Jun 2, 2009 | 12:21 AM
afireinside7710's Avatar
160 maybe?
Old Jun 2, 2009 | 12:22 AM
KillerBee's Avatar
thats a good guess!^^^^
XgunsmokeX's Avatar
wouldnt it be less then a 2.2 which is 148
Old Jun 2, 2009 | 12:23 AM
09BlueBaltSS's Avatar
id think its easily capable of the 150-180 range
Old Jun 2, 2009 | 12:25 AM
yeah im thinking 100hp from the turbo, right
Force's Avatar
The 2.2 isn't a performance-minded motor... The internals are weaker, it doesn't use direct injection, etc.
VVT and DI would help it to get more hp
Old Jun 2, 2009 | 12:26 AM
Stamina's Avatar
If I had to take a wild guess, I'd say 170-190hp.
I'm basing this off of the fact that the internal dimensions are similar to the LSJ, and although it would be naturally aspirated, it would still have direct injection and cam phasing on its side to make up for the difference.
I've thought about this question before myself. I contemplated getting a copy of HP Tuners in the future and set the commanded parameters to atmospheric/sea level pressure to play around with it and see. Although it wouldn't be truly naturally aspirated still, you could at least get a feel for what the engine can do on its own.
Edit: The more I think about it and read the good thoughts some of you have, the more I think it would be lower.
PimpLay2's Avatar
stock boost is 16lbs... each psi says to be 10hp
so 100 hp
Old Jun 2, 2009 | 12:28 AM
so 100 hp
i wouldnt think so, but you might be right
Old Jun 2, 2009 | 12:29 AM
KillerBee's Avatar
so 100 hp
Thats being tuned for a turbo i assume that if its tuned for the motor it will be much more!
Old Jun 2, 2009 | 12:31 AM
Stamina's Avatar
so 100 hp
I like the thought process. I'd add a bit more to it though I think.
USMCFieldMP's Avatar
Rattlesnake Race Shop
Not only is it a 2.0... but it is like a 9.2:1 Compression Ratio, iirc.
It wouldn't be much. I'd say less than 150hp.
so 100 hp
Hahahahahahahahahahahaahahahahaha....
No.
With your genius HP guessing equation... that would mean that 10psi from a stock turbo... and 10psi from a GT42R would make the same amount of power. Ummmm... Okay.
Last edited by USMCFieldMP; Jun 2, 2009 at 12:32 AM. Reason: Automerged Doublepost
Old Jun 2, 2009 | 12:32 AM
Stamina's Avatar
120-140hp seem fair?
Old Jun 2, 2009 | 12:35 AM
There is really only one way to find out... and that would be to do it. There are WAY too many factors that go into it. Like, Cams... how well will the stock cams work in a N/A situation... manifolds, etc, etc.
Old Jun 2, 2009 | 12:36 AM
i totally forgot about direct injection and vvt in the LNF.
the camaro is n/a and it makes 304 hp out of a 3.6L
and vvt adds some power like in the accord and cobalt 2.4.
so im thinking it probably makes about 180
i wonder if somebody has tried it?
Old Jun 2, 2009 | 12:38 AM
PimpLay2's Avatar
No.
perfect example of why ppl dont get on .net anymore.... 2 many *********
Old Jun 2, 2009 | 12:39 AM
i think it would be stupid to do, so i can only guess that no one has tried it
USM is your senior, and you are to respect him as such
Last edited by afireinside7710; Jun 2, 2009 at 12:39 AM. Reason: Automerged Doublepost
Old Jun 2, 2009 | 12:44 AM
REIGN SS's Avatar
Original Hayden Fanatic
...Yea it's because of the ********* with the correct answers/idea, not the ones that blast B.S. and pull incorrect info outta there anus.
Old Jun 2, 2009 | 12:47 AM
PimpLay2's Avatar
the OP states "How much hp do you think an LNF 2.0 thats naturally aspirated would make to the flywheel?"
key word THINK i stated how much I would THINK it would be... and there isnt CORRECT info because no1 would know the correct answer buddy, there is no exact number
thats MY job
Old Jun 2, 2009 | 12:50 AM
REIGN SS's Avatar
But if what you "think" isn't based on any technically true merit what you "think" really isn't worth much is it?...
XgunsmokeX's Avatar
and it starts again
ItalianJoe1's Avatar
FWIW, buddy of mine ran his stock LSJ on a dyno with the boost bypass done wrong, valve stayed open and the car made 0 boost. Put down 130 somthing. I'd assume the LNF would be slightly higher with the DI and VVT, but how they would react to just pulling boost out of the stock tune, I wouldn't know. IF the engine was specifically tuned for NA, then you can't really compare, as the tuning would make the difference.
I'd guess 150-160hp, if everything was left stock but boost was disabled. Assuming the car would still complete the pull.
