Make a SC handle like a TC?
Old Jul 19, 2009 | 02:04 AM
ScaryFatKidGT's Avatar
Is it possible to make a SC handle more like the greatly praised SS/TC? The SCed has some understeer/front-end problems because of its overly stiff front sway, and alot more time went into tuning the TCeds set up.
Iv been thinking the SCed already has pretty good shocks/struts/springs (not to hard not to soft) and a 24mm front sway so all it needs is a 24mm rear right? and then some slightly wider rims and 225 tires (or wider) instead of 215 and it should be pretty close right? or is it alot more complicated than that?
I read somewhere that aftermarket sways on balts don't replace the old one they just add a second sway...I don't think that's right? is it?
Old Jul 19, 2009 | 02:20 AM
drew1991sf's Avatar
do the suspension i have. my car handles just as good if not better.
ss/tc struts/shocks, w/e springs u want, ottp or ttr rear sway, ottp cabs, and do hawk hps pads with slotted rotors
if u got enough money get the Pedders coilover set-up best one out
Old Jul 19, 2009 | 02:37 AM
how much different are the TC shocks/struts then the SC?
yeah hawk hps's are the best street pads
and do slotted/cross drilled really help cooling people say they don't but every vette, ferrari, lamborgini and porscha have slotted/cross-drilled rotors so I don't think there just for looks.
Old Jul 19, 2009 | 12:23 PM
drew1991sf's Avatar
they help but not until u upgrade the brake pads.
and the ss/tc struts/shocks are night and day over the sc's. wish i would have taped the difference in stiffness.
Old Jul 19, 2009 | 12:29 PM
BlackSSNick's Avatar
where can you buy ss/tc shocks, struts, besides the overly priced stealership?
Old Jul 19, 2009 | 12:43 PM
drew1991sf's Avatar
crateenginedepot.com
call tom or email him. got mine for 372shipped.
Old Jul 19, 2009 | 12:45 PM
rallyracer's Avatar
Cobalt FE5 Struts and Shock Pkg FE5-S
Note: Special Order, Please allow 2 weeks delivery
SKU: FE5-S
RETAIL: $485.92
YOUR PRICE: $327.22
http://www.crateenginedepot.com/stor...P2433C188.aspx
Old Jul 19, 2009 | 12:50 PM
those are the ones they use on the turbocharged balt, because mine is supercharged and they look like the same ones.
Old Jul 19, 2009 | 12:58 PM
rallyracer's Avatar
Im not sure how we tell the difference ...the web site doesn't get specific. I guess you'll have to just search by part numbers.
FE5 part numbers
Sway bar: 15821093
Clamps: 22608428('05 only , 1bolt/1slot) 10389617(2 bolt, ALL other FE5 including LNF)
Insulators: 22700091('05 only) 15822993(06-07 only)
Rear Axle: 15232752(same as FE3)
Links: 20784688(ALL FE5 same, including LNF)
Struts: 15247245/15247246(L/R)
Shocks: 22728821
Frt Springs: 21994335(L/R same)
Rr springs: 10390024(same as FE3)
Lower control arm: 15803766/15803767( L/R, right same as LNF)
Knuckle: 22667248/22667249(same as all except LNF)
LNF/FE5 Part numbers
Sway bar: 15782696
Clamps: 10389617(same as 06-07 FE5)
Insulators: 25847760
Rear Axle: 25864579
Links: 20784688( ALL FE5 same)
Struts: 19181044/19181043(L/R)
Shocks: 25793745
Frt Springs: 25833647(L/R same)
Rr Springs: 25821162
Lower control arm: 25930725/15803767( L/R, right same on ALL FE5)
Knuckle: 25923942/25923941(L/R, unique to LNF)
Old Jul 19, 2009 | 01:07 PM
drew1991sf's Avatar
just call or email tom he knows. shipping is like $40-50 cuz the box weighs like 35lbs.
Old Jul 19, 2009 | 01:14 PM
Maven's Avatar
Originally Posted by rallyracer
I guess you'll have to just search my part numbers.
That looks a lot like the part numbers I posted......dont think they are yours.
Theres actually a new number for one front strut, and the price dropped, its no longer over $160 for the one strut.
Old Jul 19, 2009 | 02:23 PM
rallyracer's Avatar
BY part numbers...miss type.
Old Jul 19, 2009 | 03:40 PM
so you don't think the "hardcore" bar made your car to stiff or tail happy?
did u notice a big difference with the control arm bushings? Does anyone make steering rack bushings?
I don't really want coil-overs the adjust ability is great but the car cant be to stiff then you cant pick up chicks with it
Old Jul 19, 2009 | 03:55 PM
tonio5555's Avatar
What is the improvment found in the TC suspension which makes it that much better than the SC? Is it the springs? The struts and shocks?
I have ss/sc springs on my 2.2 as of now, but I'm debating upgrading to the ss/tc springs or getting ss/tc struts and shocks and keeping the ss/sc springs.
Old Jul 19, 2009 | 05:52 PM
less under steer and better ride its a little bit of everything. go with the struts and shocks and keep ur springs then get a some sways when u save up enough
Old Jul 19, 2009 | 10:57 PM
drew1991sf's Avatar
i havent had the hardcore bar or control arm bushings on yet it still hasnt been shipped.
but i had the ttr 1" and it was good not tail happy at all
struts/shock are SO MUCH STIFFER its amazing.
Old Jul 19, 2009 | 11:23 PM
CordiaDOHC's Avatar
have also wondered about this since im on the FE3 suspenion and would like a bit better handling without having to worry about scraping the front bumper.
Old Jul 19, 2009 | 11:50 PM
WickedSS2005's Avatar
All cobalt coupe handles are the same..... lmao
Old Jul 19, 2009 | 11:51 PM
"Make an SC handle in a TC"
Old Jul 20, 2009 | 12:15 AM
CordiaDOHC's Avatar
lol not true they come in different colors and sometimes even chrome
Old Jul 20, 2009 | 03:21 AM
drew1991sf's Avatar
get ss/tc struts/shocks and springs if u want it a little lower and handle better w/o it being to "low". then a rear sway and ur fine
Old Jul 20, 2009 | 05:58 PM
does anyone make an adjustable rear sway?
Old Jul 20, 2009 | 06:09 PM
Area47's Avatar
Rent me! per hour
rear twisting beam
shocks
struts
springs
front knuckles
steering rack
power steering motor
axles
hubs
wheels
tires.
Old Jul 20, 2009 | 06:20 PM
drew1991sf's Avatar
can u use the knuckles without using the axles?
Old Jul 20, 2009 | 06:45 PM
Evoly's Avatar
Nope! Knuckles need the TX axles, splines are different.
