Eibach springs and stabilizer bars
Old Apr 30, 2006 | 01:52 PM
red_wing_2121's Avatar
I am saving up to buy the Eibach stabilizer/anti-roll/sway bar set (whatever you want to call it, all the same), and some lowering springs. I was wondering what the difference is for the pro springs and sportlines for the 2.2L coupe because Gravana Tuning says that they both would lower my car the same. Is one set stiffer than the other or what?
Old Apr 30, 2006 | 01:56 PM
BlackBalt's Avatar
It would seem that since the sportlines are lower, you would loose suspsension travel with them, they are most likely made stiffer so they stay off the bumpstops. I was going to buy the Eibach sway bar kit but the date was pushed from early spring(march 06), to late spring, to sometime in the summer of 06.
Old Apr 30, 2006 | 01:59 PM
Halfcent's Avatar
I'm old school
Pro kit is about an 1.5 inch drop. Sport lines are a little over 2 inch drop. Not the same.
Old Apr 30, 2006 | 05:08 PM
qcpursuit's Avatar
the ride is totally different between the pro kit and the sportline,the sport line drop way much and they re a lot more stiffer than the pro kit
Old May 1, 2006 | 06:41 AM
I think I would lean toward the pro kit judging from your info. Thanks.
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
Sep 26, 2015 06:44 PM
