Best size/model TURBO for my build????
hey im in the process of parting up for my turbo build and i jus wanted to get sum suggestions for what size/model turbo would be best. i have a stock 2.2 and all im plannin to do is get a safe 8to10 pounds with stock internals, injectors, FMIC, BOV, wastegate...u know..the usual and not to mention turbo grind cams as well...any help is appreciated
8 to 10 pis with what kind of flow. A 16g does not flow the same amount of air at 8 psi as a GT47. I hate how people define power by PSI.
A good turbo for you would be GT2876r. Its a nice midframe turbo should be able to provide over 300 whp if wanted but can be more conservative used if desired.
check out the forced induction threads/stickies. Theres pretty good explanations on picking turbo sizes. What do you want, a small, quick spooling turbo that'll peak fast, or a big, slower spooler?
I agree that a GT28 would be probably about the size you will want.
haha yea that sabout the size of my donut in the trunk..thnx n e way
nevr heard of that ill look it up thnx 4 the input
Last edited by jerseyfatboy; Oct 21, 2009 at 11:48 PM. Reason: Automerged Doublepost
you've never heard of a GT28 before? Thats one of the most popular 4 banger turbos out there. GT2860 and GT2871.
Its a good one. Whats your budget though? A newer borg-warner turbo would be very nice, though i imagine theyre a little on the pricey side. Also, I imagine a K03 or K04 would be a good one for low power levels and maintaining a quick spool (as the LNF demonstrates)
What I meant was that given the same volume in the intake tract/head/cylinder that 8psi of air is 8psi of air as long as we aren't talking about temperature. A bigger turbo isn't going to "fit" more air into the same psi in a fixed volume.
Unless I'm way off my rocker in which case help me out. lol
Otherwise, yes, you're correct
good to know.. i was lookin into the turbo that comes in the garrett kit..its the gt2806rs i think?
