All About the LSJ
Old Apr 10, 2005 | 02:25 AM
JonyyB's Avatar
Site Founder
All About the LSJ
I got some emails from guests asking about the LSJ, so lets get some info up.
What makes this engine good, what needs improvement, and what are some of the mods that can put this engine in the 13’s?
Redline and SS guys, what is your experience with the LSJ?
2.0L ECOTEC Supercharged DOHC LSJ
Displacement (liters/cu. in.): 2.0/122.0
Bore & stroke (in.): 3.4x3.4
Bore & stroke (mm): 86.00 x 86.00
Compression ratio: 9.5:1
Block material: cast-aluminum
Cylinder head: cast-aluminum
Valves per cylinder: 4
Ignition system: electronic
Lifters: hydraulic
Cam drive: chain
Alternator rating (amps) 105
Battery (SAE rating, cca) 525
Recommended unleaded fuel 87 octane 91+ octane (note1)
Redline (RPM) 6500
Horsepower/kW @ engine RPM 205/152.93 @ 5600 RPM
Torque (lb.-ft./N-m) @ engine RPM 200/271.16 @ 4400 RPM
note1: Cobalt SS Supercharged will operate with 87 octane unleaded fuel. However, a power loss will be noticeably felt by the driver.
chevy.com
Old Apr 12, 2005 | 12:14 AM
CoBIZZLE's Avatar
From what I hear people are already hittin 13s w/just homemade intakes and generic mufflers! Imagine what could be possible w/ an designed and tested aftermarket intake system from intake to TB to manifold, a boost pulley and header back exhaust!
Old Apr 12, 2005 | 02:40 PM
tiny's Avatar
what is the redline for the NA motor?
Old Apr 27, 2005 | 10:42 AM
Chrisxotic's Avatar
EMS?
Who's developing?
Will AEM?
Everyone will be Pi$$ing in the wind until then.
Only Ecotec I've Dynoed was a Redline @ 210WHP w/ K/N.
Old Apr 27, 2005 | 03:25 PM
Eddie's Avatar
and 13's redlines drivers are barily hitting 14's majority of them are in the 15's. not dissing but its true. probably 4 - 5 owners have hit 14's all others are 15-16 range. i know its the driver but i just find it hard to believe
imo what it will take to hit 13's will be, CAI, after market header, definatly the LSD. if the SCDYNE header gives the car 25+whp then that should be enough to get the ss into the 13's. possibly just an intake with a good tune will let it hit 13's.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
