Forum Jump Gallery Social Groups VBgarage Videos Chat Link To Us Decals Site Map Contact Us
Cobalt SS Network Forums
The Cobalt SS Network is the leading resource for all Chevy Cobalts and related Delta
platform cars. Registered users do not see the above ads. Please Register - It's Free!
Supporting Vendor Index | Vendor Forums
Go Back   Cobalt SS Network > General > How to Guide
- New threads must be approved by mods before they are displayed.
Thread Tools Display Modes
Old 07-24-2006, 09:52 PM   #1
Blackout06LS
Member #: 7343
Images: 9
Check out my gallery  Check out my vbgarage
How-To: A/F Gauge Install on 2006 Cobalt LS & Supercharged
Vehicles covered by this write-up: 2005-2006 Cobalt LS & Supercharged
Installation Duration: 1 hour
Skills needed(1 being least and 10 being expert): 2
Parts you need to purchase:
Some sort of gauge pod(your preference)
Air/Fuel Gauge(Summit Racing brand Part # SUM-G2986)
Wire
Crimps
Tools:
Clothes hanger
Wire cutters and strippers
Crimpers
10mm socket & wrench
Directions:
1) Disconnect battery(located in trunk)
2) Install gauge pod onto A-pillar or whereever following their instructions. I used a a-pillar gauge pod and had to attach it with four screws and drill a hole for the wires as I'm going more for function right now.
3) Remove rubber plug on firewall located as shown. Slide clothes hanger through hole and find in the engine bay. Attach two wires to it and pull back through. This is your power wire and A/F signal wire. Mark them to keep them seperated.
4) Hooking up the power wire - using a crimp put the red A/F wire(power) and crimp it into one side. The power wire you ran through the firewall will be connected to the other side using the same method.
5) Now adding power - Take off the fuse box cover and find the IP Ign fuse. A mini green 20A fuse. Strip off some of the wire and put this on ONE side of the fuse and re-insert fuse. Congrats-You have power now.
6) Hooking up the signal wire(grey wire) - Perform the same method as connecting the wires as you did the power. Locating the signal wire is fairly easy. In the bundle of wires next to the ECU locate the Purple wire with a white strip. Cut this wire and strip the ends. Connect the signal wire you ran through the firewall on one wire and connect the two using a crimp.
Location of bundle:
Wire:
7) Hooking up your ground - Anywhere will be great, but I used the metal bracket that supports my clutch pedal. Just removed one bolt put the black wire there and bolted it back down.
8: Reconnect battery and check wires and make sure everythings snug.
9) Crank her up and watch the gauge. Give it a second to get the signal and tap the gas a couple times to see if the gauge changes. After a few minutes of idle it may dance which is normal.
10) If everything is working properly you are finished!
Disclaimer: Do not put gauge where it will affect your night time driving. I am under no reason responsible for where you install it. Please drive safely & responsible.
__________________
My Car website.
1989 Mazda MX6 - Currently under a lot of construction
2006 Chevy Cobalt LS - RIP 10/2007
Blackout06LS is offline   Reply With Quote
Old 07-26-2006, 04:46 AM   #2
Florida 76
Member #: 1198
Images: 68
nice how to.. i will be installing my A/F gauge soon just cause thay look cool at night
Florida 76 is offline   Reply With Quote
Old 07-26-2006, 05:44 AM   #3
cashstacker
Member #: 5282
what about putting a new sensor in the downpipe?
cashstacker is offline   Reply With Quote
Old 07-26-2006, 08:40 AM   #4
cvenom2122
Member #: 233
does this gauge run air fuels from the computer? because unless it does then you signal is fake and you need a wideband i want to buy a air fuel gauge asap if its that easy lol
__________________
Delaware'z fastest saturn! 13.4 @ 105 w/ a 2.2 60ft
cvenom2122 is offline   Reply With Quote
Old 07-26-2006, 02:04 PM   #5
NGalaxyTimmyo
SEE Carclub
NGalaxyTimmyo's Avatar
Member #: 3206
Images: 7
That would be a narrowband setup, which is why there isn't any sensor being installed. To install a wideband, it's pretty much the same thing, except you don't tap into that purple wire. You would hook it up to the sensor. You/someone will need to install a place to install the sensor though. It says in the instructions how far from the header to put it, I forget at the moment.
__________________
NGalaxyTimmyo 06 Laser Blue Chevy Cobalt SS/SC
Picked up on Sept 27th, 2005
Moded
E/T Time: 13.87 at 105.11MPH with a 2.43 60ft
Dyno'd at 248.0 HP and 241.0lbs of Torque
NGalaxyTimmyo is offline   Reply With Quote
Old 07-26-2006, 02:18 PM   #6
Witt
Witt's Avatar
Member #: 5710
Images: 10
May want to throw in an add-a-fuse. Unless you test the circuit after removing the fuse you put the stripped wire to, you only have a 50/50 chance of running a fused circuit to the gauge. If the power wire that runs through the firewall rubs between the steel and rubber boot, bye bye cobalt.
Witt is offline   Reply With Quote
Old 07-26-2006, 02:33 PM   #7
GSoccer24
Member #: 4146
Images: 18
nice write up, thanks for taking the time to do it and provide good pics of everything. you'd definitely want to put a fuse in that power wire, within 18" from the source. also for the record, this shows a narrowband installation.
__________________
GSoccer24 is offline   Reply With Quote
Old 07-26-2006, 02:45 PM   #8
zomghax
OH SNAP
zomghax's Avatar
Member #: 376
Images: 16
Quote:
The signal isn't "fake", it's just kinda useless as far as tuning and more of a light show than anything.
From what I've read, the AEM UEGO and Innovate LC-1 widebands can actually use your primary o2 sensor location and relay your narrowband signal back to your wiring harness for you using an analog output. One less sensor to replace and no need to get a bung welded would be the main benefits of doing that, I guess.
__________________
zomghax is offline   Reply With Quote
Old 07-26-2006, 04:01 PM   #9
Witt
Witt's Avatar
Member #: 5710
Images: 10
Oh wow, I never thought about that. FedEx is delivering my AEM UEGO today. Do you have any more info on using an analog output to power the narrow band? Thanks greatly in advance.
Old 07-26-2006, 04:08 PM   #10
Witt
Witt's Avatar
Member #: 5710
Images: 10
A quick google search shows that AEM UEGO can emulate your stock rear O2 sensor by adjusting the output from 0-5v to 0-1v. zomghax, you sir, are the &^%$ing man.
Old 07-26-2006, 04:11 PM   #11
zomghax
OH SNAP
zomghax's Avatar
Member #: 376
Images: 16
Quote:
Info on how to do it with the Innovate LC-1, might help you a bit:
http://www.hptuners.com/forum/showthread.php?t=2947
A bit of info on the AEM gauge confirming it works the same way, nothing too specific though:
http://www.hptuners.com/forum/showthread.php?t=6606
__________________
Old 07-26-2006, 04:15 PM   #12
zomghax
OH SNAP
zomghax's Avatar
Member #: 376
Images: 16
My friends warned me against using it in the rear location because the cat will throw the wideband readings off. That seems to be the general consensus on the HPTuners forums as well. And thanks but I'm just a n00b who's trying to learn like everyone else
__________________
Old 07-26-2006, 04:23 PM   #13
Witt
Witt's Avatar
Member #: 5710
Images: 10
Yeah I read the same about the rear location, however I "think" if you use it in the front location, it has to be wired with a capacitor. Not sure, but if the FedEx guy ever gets here, I'll know for sure.
Some other forums that I googled mentioned the capacitor, but it might only be for older models of the UEGO or may have to do with the make/model of vehicle. Hopefully I'll know shortly.
Old 07-26-2006, 04:39 PM   #14
zomghax
OH SNAP
zomghax's Avatar
Member #: 376
Images: 16
Well hey, please post up your results and let us know!!
__________________
Old 07-26-2006, 04:43 PM   #15
Witt
Witt's Avatar
Member #: 5710
Images: 10
I sure will.
Old 07-26-2006, 09:19 PM   #16
Blackout06LS
Member #: 7343
Images: 9
Man wish this got the attention back when I was TRYING to find that purple wire. LOL
Circuit will be tested to make sure its fused. I don't want to run straight to the battery due to I don't want it lite up 24/7. So right now its just tied into that fuse. But I'll test the fuse tonight. I believe I have it on the right side, but gotta double check.
__________________
My Car website.
Old 07-27-2006, 03:56 AM   #17
Witt
Witt's Avatar
Member #: 5710
Images: 10
Quote:
haha, isn't that the way it always works?
Old 07-27-2006, 08:21 AM   #18
Blackout06LS
Member #: 7343
Images: 9
Yeah I know. I spent a good week to two weeks at work searching. Of course not solid I had to actually work, but 5 mins here and there.
__________________
My Car website.
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Installed Boost Gauge (Warning: Long Install Instructions) ExHondaMan How to Guide 29 08-08-2006 08:36 PM
Info On My Cobalt LS Coupe 2006 djblass Appearance 1 02-03-2006 11:56 AM
Team Cobalt aims for Championship in sophomore season, five cars compete in opening G JonyyB Front Page News 5 01-30-2006 10:22 PM
Chevrolet Cobalt SS Supercharged Coupe Project zinner Front Page News 8 06-03-2005 04:23 PM
2005 Chevrolet Cobalt SS Supercharged Coupe JonyyB Front Page News 0 11-11-2004 08:59 PM
vBulletin copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©Cobalt SS Network, Enthusiast Networks LLC - All posts are the opinions and copyright of the original authors and must be referenced with a link.
This site is not affiliated nor endorsed by General Motors. Chevy Cobalt and related trademarks are the property of GM.
