For Sale Updated - 2006 LSJ Turbo Part Out - Wrecked LOT OF PARTS
Old 03-06-2014, 04:51 PM
sl0wlsj's Avatar
Payment: Paypal or Pickup
Contact: PM
I have another thread that I am having locked. This thread will contain the updated parts list as well as more updated pictures. If you have any questions, feel free to PM me. All prices DO NOT INCLUDE SHIPPING or PAYPAL FEES, 3%. Prices are OBO, some of this stuff is hard to price so just work with me on the price if it's too much. There are parts not listed below that are in pictures and vise versa, just PM me if you need a picture or price.
Also, if anyone would need any body components before I scrap the frame, for example core support I am more than happy to cut it out for you or you can come look for yourself. I am going to be taking it in about a week, so let me know before hand.
Inside:
Turn Signal Control - $20
Wiper Blade Control - $20
Shifter Cables - $35
Pedal Assembly - $45
Power Steering Motor - $50
JVC Single Din Radio MP3 USB Aux - $40
Cup Holder – Rear - $10
Shifter Trim & Cup Holder – Front - $30
Black HVAC - $45
Gauge Bezel - $14
2006 Gauge Cluster (Has blue LED mod, will need power and ground, I hooked to ignition fuse) - $76
Dash Trim (Laser Blue Metallic) - $60
Black Glove Box - $40
Stock A-Pillar (1Pod) – Drivers Side - $25
Stock A-Pillar – Drivers Side (Wrapped with plaid fabric) - $25
Stock A-Pillar – Passenger Side (Wrapped with plaid fabric) - $25
Rear Deck Carpet - $40
Dashboard - $75
Dashboard Air Bag (x2) - $50 each
Sunroof with motor - OFFER
Rear Speakers (Pioneer) - $50
Passenger Side Stock Axle - $30
Moog Sway Bar Links (pair) - $25
Passenger Side Door Panel - $75
Drivers side window/door controls - $20
4-way flasher button - $5
Engine Bay Area:
Turbo Kit - $3300
* Precision 5531 .48 T3 Turbocharger
* TTR Intake Manifold
* ZZP Exhaust Manifold
* Custom Charge Pipes
* Front Mount Intercooler
* Custom Downpipe (2 bungs – 302 Stainless Steel Vband Exit)
* 80# Injectors & Harness
* Oil Pan with Return Bung
* Oil Feed/Return Lines
* Alternator/Belt/Tensioner
Gen 1 Engine - $1600
* Gen 3 LDK Pistons/Rods
* New Rings & Bearings
* ARP Head Studs
* Stock Cams
* 16 New Lifters
* ZZP 82# Valve Springs with Titanium Retainers
* Supertech Intake Valves
* Supertech Exhaust Valves
* Viton Valve Seals
* 2 Step Cooler NGK Plugs
Engine Harness - OFFER
2006 Fuse Box - $75
Master Cylinder - $40
Coolant Tank - $25
Engine Cradle - OFFER
Stock Engine Mount - $25
Stock Trans Mount - $20
Stock Rods - $40
Stock Valve Springs & Retainers - OFFER
Outside/Body:
Passenger Side Fender - OFFER
Passenger Side Side Skirt - OFFER
Trunk Deck Carpet - OFFER
Trunk Reverse Lights – Stock Tinted - $25
Drivers Side Tail Light – Stock Tinted - $10
Headlight bulb harness’ - $10
Passenger Door - OFFER
Rear Calipers - $75 pair
Rear Brake Pads - $15
1 KYB Shock - $20
Front FE5 Strut Assembly (H&R Lowering Springs – Both mounts have 1 bolt broken off, only 2 mountable to car) - OFFER
Miscellaneous
Haynes Cobalt Manual - $15
5x120 CSL Reps 18x8 18x9 Rims - OFFER
5x110 to 5x120 19mm & 31mm adapters – Motorsport Tech MADE (WILL GO WITH RIMS)
NEW AC Delco Battery - OFFER
sl0wlsj is offline
Old 03-06-2014, 04:52 PM
sl0wlsj's Avatar
sl0wlsj is offline
Old 03-06-2014, 05:14 PM
CradleofFilth08's Avatar
Pm'd
CradleofFilth08 is offline
Old 03-06-2014, 05:53 PM
sl0wlsj's Avatar
More pictures uploaded of engine and turbo kit.
sl0wlsj is offline
Old 03-06-2014, 06:16 PM
blueLNFftw's Avatar
Why does the cluster need external power?
Lit up pics?
blueLNFftw is offline
Old 03-06-2014, 06:21 PM
sl0wlsj's Avatar
Lit up pics?
I removed the white lights and have blue LEDs in them. Requires power for them to light up. Just like an led mod. I have no power to light them up.
sl0wlsj is offline
Old 03-07-2014, 02:58 AM
sl0wlsj's Avatar
Bump.
sl0wlsj is offline
Old 03-07-2014, 07:25 AM
bmxracerchamp12's Avatar
subd for possible turbo kit partout
bmxracerchamp12 is offline
Old 03-07-2014, 12:05 PM
sl0wlsj's Avatar
Shifter trim - SOLD
sl0wlsj is offline
Old 03-07-2014, 04:01 PM
GoofyBalt's Avatar
Do you have a LSJ Dipstick? I dont need the tube, let me know.
GoofyBalt is offline
Old 03-07-2014, 04:08 PM
sl0wlsj's Avatar
Goes with turbo kit.
sl0wlsj is offline
Old 03-07-2014, 11:41 PM
sl0wlsj's Avatar
Someone buy this engine and turbo kit. Make me an offer on all this stuff. Need gone!
sl0wlsj is offline
Old 03-07-2014, 11:43 PM
sl0wlsj's Avatar
Engine and turbo kit. Together $4500
sl0wlsj is offline
Old 03-08-2014, 02:48 AM
mexi_loco's Avatar
That's a damn good offer on the engine turbo kit combo. Glws! How many miles on the whole thing?
mexi_loco is offline
Old 03-08-2014, 06:58 AM
valencia1900's Avatar
How much for the injectors and harness shipped? And how many miles on them?
valencia1900 is offline
Old 03-08-2014, 08:34 AM
rains_crusader's Avatar
Do you have the dash harness and body harness?
rains_crusader is offline
Old 03-08-2014, 08:37 AM
sl0wlsj's Avatar
Engine has 105k. Rebuild has 500 miles. Turbo kit less than 5k.
Go with turbo kit. $3300
sl0wlsj is offline
Old 03-08-2014, 08:43 AM
sl0wlsj's Avatar
I have the body harness and engine harness. No dashboard harness it is sold.
sl0wlsj is offline
Old 03-08-2014, 08:58 AM
Ss27gogeta's Avatar
Where you located in Ohio
Ss27gogeta is offline
Old 03-08-2014, 10:57 AM
sl0wlsj's Avatar
Carrollton, Ohio 44615
sl0wlsj is offline
Old 03-08-2014, 04:12 PM
sl0wlsj's Avatar
Turbo kit has been sold. Thanks Tyler!
sl0wlsj is offline
Old 03-08-2014, 04:35 PM
tylerman683's Avatar
Hellllllll yes it is!!!! Thanks again man
tylerman683 is offline
Old 03-08-2014, 04:48 PM
sl0wlsj's Avatar
Bump. Still have pretty much everything. Engine is still up for grabs as well as most of the list above and everything pictured...
sl0wlsj is offline
Old 03-08-2014, 07:47 PM
Interitus's Avatar
Any update on that lock post ring from the bad door panel?
Interitus is offline
Old 03-08-2014, 08:09 PM
sandman's Avatar
Any possibility of cutting up the harness anytime soon?
sandman is offline
Quick Reply: For Sale Updated - 2006 LSJ Turbo Part Out - Wrecked LOT OF PARTS
