Japeatr's garage sale
Old 07-25-2014, 07:54 PM
South Central *********
JapEatr's Avatar
Contact: Pm, or 214-668-1014
LSJ Coil Cover - $20 shipped
LSJ Pcv tube (the one that is on the valve cover)- $10 shipped
LNF Dipstick tube -$15shipped
Stock LSJ belt- great condition - $20 shipped
LNF oil cooler - $40 shipped
Coupe tail lights- fair condition $20 shipped
Black leather rear headrests -$40shipped
Headlight bracket -$15shipped
JapEatr is offline
Old 07-25-2014, 08:07 PM
JapEatr's Avatar
Thumbs up
Found another Stage 2 belt while packing the one that Adam bought
It is good except this rib. Id still run it, but it isnt perfect like the other one $15 shipped
Custom Clear Image Automotive header with catless and catted downpipes. These have vband outlets. Header has ball and socket collector for leak free seal. Buyer will either have to weld a vband flange or weld the DP to their catback. Both downpipes have extra bung for wideband. I had these made, sent drawings of what I wanted to Rick at CIA. This header is capable of supporting upwards of 500whp on blower. Asking $350 shipped.
The header and catless dp are coated with thermal black paint. I saw a reduction in Temps via laser thermometer after coating them. Was applied via hvlp gun.
JapEatr is offline
Old 07-25-2014, 08:18 PM
JapEatr's Avatar
Stage 2 belt sold
Have a set of brand new LSJ front caliper bracket bolts. $20 shipped
How about oil pressure sensor, LSJ injector buckets with good o rings, or some galley plugs
Also have a low mileage supercharger coupler, T3/T4 turbo oil drain flange and low mileage balance shaft chain tensioner
Have a set of low mileage LNF lash adjusters, took out of running engine to swap with cams $80shipped
Anyone need a rear taillight socket?
ARP Flywheel bolts for aftermarket clutch/flywheel conbos only
I also have just about any bolt you could think of, a ton of timing guides, timing anything, stock LSJ cams, dont see it, cant hurt to ask me!
JapEatr is offline
Old 07-25-2014, 08:28 PM
Can you take better pictures of the tails? Maybe close up of each one? Its just blurry, thanks
Slowbalt2000 is offline
Old 07-25-2014, 10:28 PM
JapEatr's Avatar
Bump items added
Off to take better pics of tails
JapEatr is offline
Old 07-25-2014, 10:40 PM
JapEatr's Avatar
Left has some surface haze, most likely overspray or body shop grime, can feel with fingernail, looks like it will come off with googone or plastic polish.
Here is the right. It is very clear, only flaw is the socket has been warped by a blown bulb. The socket does thread in fine however.
JapEatr is offline
Old 07-26-2014, 12:59 AM
JapEatr's Avatar
Added more parts
Low mileage clutch pipe with perfect Oring
Lsj injector clips $10 shipped
LNF injector clips and some other bits
Also have a set of cam caps from a good motor with bolts
Ported LNF manifold. Taintedred07 ran this on his zfr setup. Still has some rtv residue from phenolic spacer. Asking $100
05 LSJ Motor mount low mileage. Bushing still tight $20 shipped
JapEatr is offline
Old 07-26-2014, 01:35 AM
ItalianJoe1's Avatar
What's different about those headers versus the normal CIA ones? Bigger primaries?
ItalianJoe1 is offline
Old 07-26-2014, 01:36 AM
JapEatr's Avatar
Even more parts added tonight
Will be posting more up tonorrow. Have some ported LNF intake manifolds and some rods for sale tomorrow as well.
JapEatr is offline
Old 07-26-2014, 01:45 AM
taintedred07's Avatar
Selling my lnf stuff I see haha just don't sell anything I could use or need
taintedred07 is offline
Old 07-26-2014, 01:58 AM
JapEatr's Avatar
Nah i got your pile seperate.
This has become a kickstart fundraiser haha
JapEatr is offline
Old 07-26-2014, 02:03 AM
JapEatr's Avatar
Different collector and VBand outlets on the dp
JapEatr is offline
Old 07-26-2014, 02:20 AM
JapEatr's Avatar
Adding injector harness clips - $20 shipped
I believe these are for FIC1200/80s
JapEatr is offline
Old 07-26-2014, 02:33 AM
JapEatr's Avatar
Bezel sold!!!
Thanks Vincent!
JapEatr is offline
Old 07-26-2014, 02:38 AM
Haven07's Avatar
No ty lol Been looking around for one
Haven07 is offline
Old 07-26-2014, 10:15 AM
JapEatr's Avatar
All PMa replied!!!
JapEatr is offline
Old 07-26-2014, 04:49 PM
JapEatr's Avatar
LNF intake manifold added!
JapEatr is offline
Old 07-26-2014, 05:15 PM
CobaltSS 16's Avatar
Hey Vaughn I PMed you.
CobaltSS 16 is offline
Old 07-26-2014, 05:35 PM
JapEatr's Avatar
Just sent you one back
JapEatr is offline
Old 07-26-2014, 06:06 PM
paypal sent. thanks man
Old 07-26-2014, 06:16 PM
JapEatr's Avatar
Ported TB sold!
JapEatr is offline
Old 07-26-2014, 10:20 PM
JapEatr's Avatar
All oarts sold so far are boxed and ready to go out on Monday!!!
JapEatr is offline
Old 07-27-2014, 02:26 AM
JJVeld's Avatar
I need the plastic shield that connects to the right side of the left splash guard. Also could use one headlight bolt and a few of the small splash guard bolts. Pm me as I don't come on here much
JJVeld is offline
Old 07-27-2014, 04:09 PM
JapEatr's Avatar
Have headlight and splash gaurd bolts
JapEatr is offline
Old 07-27-2014, 07:49 PM
richienolan's Avatar
do you have a passenger side headlight bracket?
richienolan is offline
Quick Reply: Japeatr's garage sale
