Trunk release
Old 01-23-2017, 06:35 AM
Corrinaannajo's Avatar
Trunk release
My trunk button isn't working right. Suggestions?
Old 01-23-2017, 09:04 AM
FLASH1970's Avatar
use a voltage tester to make sure the power is getting to the wires in the trunk that pop it. if so, check connections. if connections are good, replace the latch.
use your key fob
use your key
keep your back seats down and army crawl to get what you need in the trunk
Old 01-23-2017, 02:36 PM
umrdyldo's Avatar
When mine did that, it was a fuse.
Had the dealer replace it so don't remember which one.
Old 01-23-2017, 07:41 PM
Wouldn't it completely stop working if it was a fuse tho? I will Have someone check the wires.
Old 01-24-2017, 05:05 PM
CannonBalt's Avatar
If the fuse is too small, It will prevent enough current getting through.
Old 01-24-2017, 05:39 PM
umrdyldo's Avatar
are you saying that your button under the dash works sometimes or are you saying sometimes your trunk button on your key remote only works sometimes?
I need clarification here.
Old 01-24-2017, 05:45 PM
FoxTail SS's Avatar
My button doesn't work and I checked the fuse. Don't have the key fob and the physical lock won't turn. I fought to get into my trunk from the back seats and gave up lol. I'm going to bite the bullet and pay to have someone replace the locking mechanism on it.
Old 01-24-2017, 06:04 PM
izcain's Avatar
When it gold into the 20's mine froze and would not release. Said ta heck with it. I didn't need anything out of there when it was this cold anyways lol
Once it warmed up bam she works like a charm.
Old 01-25-2017, 12:56 PM
I have to move my key around a bit to get it to open the trunk. Try lock de-icer and then moving the key a bit in and out while trying to turn.
Also it's pretty easy to pull the panel off that the button is in, then you can check the wiring easy or make sure the button is actually hitting the switch.
Old 01-26-2017, 07:37 AM
It's my button in my car that don't work sometimes, lost my remote and key hole is also rusted.
Old 01-26-2017, 11:41 AM
cluelessk's Avatar
You really need to learn how to write better. Your posts hurt to read.
Old 01-28-2017, 06:55 PM
Who needs to learn how to write????!!!! Are you talking about me????!!!!
Old 01-29-2017, 10:47 AM
umrdyldo's Avatar
Yeah he was. Your sentence structure is terrible. Your grammar is even worse and we were having a hard time figuring out what you were talking about.
Old 01-30-2017, 10:37 AM
All I did was ask about my trunk not opening properly and your all just being rude! Just stay out of my thread instead of being insulting! Just wanted some help!
Old 01-30-2017, 10:49 AM
You're not helping your case with all of those exclamation points.
Old 01-30-2017, 12:50 PM
cluelessk's Avatar
Relax. It's hard help when we can't make out what you're trying to get across.
I know it's easy to ramble on and understand your own text but from our point of view we can't make out what you're trying to say.
RauLiTo SS/SC
04-20-2011 06:32 PM
brickloaf
02-05-2011 12:47 PM
ECOTEC06SS
07-12-2010 11:49 PM
bboyfreeflow
08-31-2009 09:13 PM
RednBlack
04-27-2009 07:50 PM
Quick Reply: Trunk release
