Vac no Boost
Old 02-22-2017, 08:42 PM
triggers's Avatar
Vac no Boost
Alright guys, here it is.
1.I got a loud howl coming from under the hood that only "howls" as i watch the boost gage go from negative to just below 0. and does NOT build boost....when it should
2. have some white smoke coming out of the exhaust, smells like oil.
3. i have zzp charge pipe upper and lower and zzp IC and the connections were good.
4. at idle, no "howl" but on engine start-up with the higher idle get the louder "howl"
5. I'm not getting ANY misfires but getting the MAP sensor codes.
I'm guessing because the turbo was already leaking oil into the upper charge pipe(not much)
that the turbo has a broken impeller, letting this oil leak into the hot exhaust and burn out.
currently running zzp upper and lower charge pipes and IC 3inch exhaust, catless downpipe, no res, no muffler. and still rocking the K04 stock turbo at 25psi
i do NOT have a 3 bar MAP
only thing i can do i think at this point is just to take it into a shop to have it checked out unless you guys have insight into this issue.
thanks guys, take care
Old 02-23-2017, 12:33 AM
Prior to the howl did you hear a loud pop during a WOT pull?
Or is the howl like a metal on metal type?
Old 02-23-2017, 07:55 AM
triggers's Avatar
More of a metal on metal, never got a loud pop
Old 02-23-2017, 09:32 AM
umrdyldo's Avatar
can you get a video of it? It does sound like a screwed up turbo, but maybe it's something else.
Old 02-23-2017, 10:11 AM
triggers's Avatar
Yes but the best time for a video would be tomorrow morning if you don't mind waiting. I still have to drive kids to and from school so the engine will be warm till then.
Old 02-23-2017, 10:14 AM
umrdyldo's Avatar
Got nothing but time.
Old 02-23-2017, 10:43 AM
CudaJoe's Avatar
no intake? THe description of a "howl" sound from negative vac to 0 psi sounds like what a K&N intake makes normally.
Old 02-23-2017, 11:10 AM
triggers's Avatar
Yes, k&n typhoon intake, thanks for asking and pointing that out
Old 02-23-2017, 11:12 AM
CudaJoe's Avatar
I was gonna say lol. When I first heard that in my car, I also noted that it sounded kind of like metal grinding sound. I didnt realize that the howl was actually air sucking into the turbo through the intake. Had no idea it would be that loud. Coming from an N/A car with an intake, its completely different sounding. With that said and you saying you have a K&N intake, Id say the howl sound is not a symptom of your problem and is actually normal.
As for the no boost thing. Any CELs? What CELs do you have
Old 02-23-2017, 11:53 AM
triggers's Avatar
I am fully aware of the sound that it makes when it is not broken this is a lot different. I agree a na sounds a lot different but trust me, this is a broken sound
Old 02-23-2017, 12:59 PM
triggers's Avatar
hope this link works....
Old 02-23-2017, 02:02 PM
CudaJoe's Avatar
That sounds like a whine. definately check the turbo for shaft play.
Old 02-23-2017, 02:05 PM
umrdyldo's Avatar
Wow i have never heard that ever. Pretty creepy.
can you pinpoint the sound when you have the hood open?
Is it coming from the engine, turbo area?
Doesn't sound metallic in the video but it's hard to tell. Sounds like a giant ass boost leak at first.
Old 02-23-2017, 06:21 PM
triggers's Avatar
i can't locate the sound, I'm going to take the intake off this weekend and have a look....
Old 02-23-2017, 07:06 PM
blu3_v1p3r's Avatar
Have you checked over all the piping and the intercooler for a coupler that has come off, or cracks in the chargepipes or intercooler endtanks?
Old 02-23-2017, 07:08 PM
triggers's Avatar
yes, all connections are good
Old 02-23-2017, 07:13 PM
blu3_v1p3r's Avatar
Sorry didn't read the mods at the bottom of the post. It looked like a signature lol, I tend to skip them.
Old 02-23-2017, 07:28 PM
triggers's Avatar
np
Old 02-24-2017, 01:20 PM
triggers's Avatar
As stated, connections are good.
Old 02-25-2017, 06:59 AM
63 Nova SS's Avatar
If you had a power steering pump I would say you are out of fluid, that's the way it sounds to me. I haven't heard a boost leak that sounds like that so you may check the shaft play on the turbo like others have suggested.
Old 05-14-2018, 12:20 AM
ionit2004's Avatar
I know this is old but did you you figure out what the problem was?
