Timing
Old Nov 11, 2006 | 09:10 PM
bdwarr6's Avatar
Timing
Anybody know how to set the timing on a LSJ.
Old Nov 11, 2006 | 09:14 PM
3fo893013L's Avatar
oh man... this is what is holding you up?
Old Nov 11, 2006 | 09:18 PM
3fo893013L's Avatar
according to the build book
To adjust the timing chain tensioner turn the engine to TDC. (cylinder number 4) and tighten ...
looking for more info on how to setup without killing
Old Nov 11, 2006 | 09:26 PM
3fo893013L's Avatar
http://www.gm.com/company/gmtunersou..._250-600hp.pdf
GM Build book tells you when you take **** apart to mark the TDC before removing timing chain so you can put it back to normal timing before buttoning the system back up. Shows you in pictures how to put on and off. Did you mark your timing before taking apart?
Old Nov 11, 2006 | 09:34 PM
mike25's Avatar
lmao concerning all his desperate and anxious post i will have to say no
Old Nov 11, 2006 | 09:37 PM
3fo893013L's Avatar
all LSJ's have the same stock timing marker (most part) sooo... it comes down to him looking at a picture or setup.
Old Nov 12, 2006 | 01:33 AM
bdwarr6's Avatar
i didnt post this lol i have a bit more detailed question
how to time the lsj
for referance
timing chain - 1 -2 -3 -4 thats how im going
the valvles currently in cylander 2 are slightyl open when the ramshaft is rotated the both pop out, i know this is incorrect i just put them both on the same cyalnder for referance purposes
if cylander 2 exhaust is slightly down then cylander 3 should be slightly down on intake?
then they should swap to 1-4 then 3-2 then 4-1 correct?
the motor has been completely reassembled, i just had to take the head back off to get this timing worked out dont worry nothing has been bolted down yet
diamond pistons require the stock cylander thingy inside the connecting rods and are a bitch to get the holders into the sides of it. Bear with me im running on no sleep so ill call things weird names
We ran into alot of problems the machine shop lost 2 bolts so i have to pick those up tommorrow
and also when u remove the oil shooters good luck putting them back in they dont go back in they just strip out
So i have left them out? is this a huge deal we had a 4 man debate on it and all pretty much are clueless as this is the first lsj we have worked
and i did mark them but the **** got washed off at the machine shop
Old Nov 12, 2006 | 11:52 PM
Red07SSNA's Avatar
Go to the crateenginedepot website and save the 4 Part 300hp Ecotec how-to. Part 2 shows excellent pictures of the timing chain. This 4-part manual is about building a LSJ motor. Should really help as the performance book does not have detailed pictures.
I found it was easiest to save them to my computer and use adobe reader to open them once you save them. Good luck.
http://www.crateenginedepot.com/stor...ions-C194.aspx
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
