Dual Pass intercooler
Old 11-13-2006, 12:12 AM
Blown 4-banger's Avatar
I'm uploading pics to photobucket right now
Old 11-13-2006, 12:18 AM
Here you go, I'll have more in a few minutes.
Old 11-13-2006, 12:22 AM
heres the end plate when finished
And this is it all buttoned up and installed
Old 11-13-2006, 12:47 AM
The parts I used was a 1/2 NPT fitting with a 3/4" hose barb (hard to find). The hole was 1/2 inch, we tapped it, but couldn't get it to seal so we just had it welded. The middle fitting goes up to the filler tube. Oh you also need a T or Y fitting with a 3/4" hose barb on all sides.
Old 11-13-2006, 01:14 AM
2K5SS/SC?'s Avatar
Could you post pics on the ss.net gallery for me to see? I can see pics from other sites and I'm really interested in this. All I have to do is drill a hole, add a 3/4" hose barb, and reinstall to have a dual pass setup? If that's it, I'm doing this when I get home! Thanks for the info!
Old 11-13-2006, 01:18 AM
Cobalt_Supercharged's Avatar
here is a poor rendering of how to place the T-fitting after the pump. Although I would recomend using a Y-fitting for ease of bending the lines and less flow restriction.
Old 11-13-2006, 01:34 AM
Besure to take the intake manifold off and switch the top 2 cores like in the image above. They are directional.
Originally Posted by M88ArRamadi
Good Thread!!
I was going to do all 3 (CA Heat Exchanger, Dual Pass, Meth inj.) But I was going to start with Meth.
Will the IC pump be enough for the dual pass?
It should be but if not JBP has a higher flowing pump, not sure if they will sell it without the rest of their "4 pass" IC setup.
Old 11-13-2006, 01:58 AM
Pull the cores out and flip them around, Blown 4-banger should still have the before and after pics he just has to upload them.
The JBP "4 pass" is really a dual pass with supposedly "custom laminova cores" and fancy stainless steel braided lines. You have to root through all the junk to get the real info. Post#86 is the most usefull IMO. https://www.cobaltss.net/forums/show...t=35670&page=5
Old 11-13-2006, 03:05 AM
Originally Posted by 2K5SS/SC?
I'll take this project over the headgasket replacement I did any day! Plus, it'll benefit my car greatly being in Charleston 100+ degree weather in the summer time. Can someone make a flow diagram (with paint or something as it doesn't have to be too detailed) and post it? I think that would help us all out getting a idea of how it works.
Good point. It won't be too bad compared to that I'm sure. Here is what I think you wanted, let me know if it is not.
Old 11-13-2006, 05:14 AM
2K5SS/SC?'s Avatar
Is this an accurate picture of the overall idea here? I thought this visual might help out even more if it is indeed correct.
Old 11-13-2006, 07:38 AM
This is sticky worth. Great info.
Old 11-13-2006, 08:27 AM
Yes thats accurate.
YES!!! FINALLY I GOT A STICKY THREAD!!!! My life is now complete, I can die and have no regrets about my life
Old 11-13-2006, 08:59 AM
2K5SS/SC?'s Avatar
^^^I got my sticky thread last month IIRC. It was great! Congrats on yours! I'm glad my diagram is is right on the money too!
Old 11-16-2006, 01:11 PM
NGalaxyTimmyo's Avatar
Congrates to both of you. I was very surprised the other day when I found out that my oil change how to was a sticky. best moment in my life
Old 11-21-2006, 10:16 AM
JANNETTYRACING's Avatar
Your instructions are great, I just recieved the GM kit but it says to run the flow opposite to your instructions.
GM says install the small orifice tubes in the 2 middle holes and the large ones top and bottom, they also are runing the water in the oposite direction, the center port is IN and the top and bottom Ports are OUTS.
The also talk about adding a second surge tank to better purge the air from the system and add capacity using a Saturn Red Line Surge tank, another T and a 0.040 bleed orifice to the other end of the intercooler.
Would you care to elaborate?
Old 11-21-2006, 10:45 AM
2K5SS/SC?'s Avatar
I suppose you could do it that way too. I think it might actually keep the coolant cooler that way too because it would separate the heated cores even further until it exits the manifold. Mmmm..... Interesting. Someone needs to do a test to see which one is better.
Old 11-23-2006, 03:43 AM
phlatcav's Avatar
do you have to remove the manifold to pull the cores?
Old 11-23-2006, 04:00 AM
We had to because the canister for the oil filter was in the way. It is also difficult to reach all the bolts for the end plate with the manifold still in the car because of the oil filter.
Old 11-23-2006, 04:09 AM
That would explain why they went with this design for the Y fitting.
http://www.crateenginedepot.com/stor...P1693C196.aspx
The extra surge tank and bleed orfice would have made things a world easier. Blown 4-banger spent several hours slowly purged the air by repeatedly starting the IC pump, stoping the pump and adding fluid as needed. I would recommend doing this while you install a new or additional HE just to prevent having to bleed the system twice.
Old 11-24-2006, 03:08 PM
Serpico's Avatar
is this just a pilot hole ? seems kinda small if its not, wouldnt you want the hole the same diameter of the inside diameter of the aluminum anadized fitting that you are installing?
Old 11-24-2006, 04:22 PM
tcolli17's Avatar
Yeah, it is a pilot hole.
Old 12-17-2006, 10:41 PM
chipmonk212121's Avatar
so how big of a difference do you think this mod makes?
Old 12-17-2006, 10:44 PM
20-30 degree drop in IAT2
Old 12-17-2006, 11:40 PM
hmm.... i dont know that much about that.... but that sounds like a lot haha
Old 12-17-2006, 11:52 PM
Ljavy17's Avatar
deff a lot, for every degree is about a hp!
Quick Reply: Dual Pass intercooler
