Drivetrain: How-To: Install B&M Shiftplus
Old 11-17-2006, 04:47 PM
HackAbuse's Avatar
Step 1: Order your Shiftplus from CobaltPerformanceParts, TurboTech, Gravana.
Step 2: Wire the end of B&M thru the firewall from the inside, there is a rubber grommet directly behind the gas pedal, pop it out, and stick the wire thru.
Step 3: Locate the wire, and pull it on out on the engine side (it comes out behind the fuse box, so it is kind of difficult to get to)
Step 4: Locate the transmission harness. (It is between the valve cover and fuse box about one foot down; It is a 2" diameter gray plug, plugged into a large aluminum block, you cant miss it!)
Step 5: Pull the wires out of the wiring loom, locate the Light Blue wire with a white stripe, and the Red Wire with a Black stripe ---- IMPORTANT ---- there are two red wires with black stripes, you want the one that is NOT twisted with another wire! ----
Step 6: Mate the Black wire on the Shiftplus with the Light Blue wire, and the Red Shiftplus wire with the Red wire with either a wire tap, or solder them directly.
Step 7: Tape it up, make it look pretty, close the hood, and VIOLA, you're done!
Step 8: Leave me positive rep by clicking here
With Stage II activated, shift from 'P' into 'D' will give you a nasty lurch, but I wouldnt worry about it since our tranny's are rated for 230 ft/lbs of torque! The shifts are much more solid and sound feeling. The only thing I dislike is there should be a third setting which is all out nuts, 100% pressure strictly for track use only. I have no problem cruising around with Stage II all day.
FYI - Once you select a setting, you cannot bump it back down until the car is turned off and restarted.
Old 11-17-2006, 06:41 PM
ocp04's Avatar
wtf
i never heard of this, what does it do/ suppose to do? j/w
Old 11-17-2006, 06:43 PM
HackAbuse's Avatar
Automatic Transmissions Only!
Old 11-18-2006, 08:26 AM
BlackLS's Avatar
So can you chirp the tires now
Old 11-18-2006, 10:01 AM
HackAbuse's Avatar
Not on dry pavement, I think if I had the stock continentals i'd be able to do it, but I have brand new Pirelli P6's
Old 11-18-2006, 09:48 PM
red_wing_2121's Avatar
How will the internal transmission seals hold up to this type of pressure? The mechanicals may hold up to it, but what about the rubber seals and such?
Old 11-18-2006, 10:35 PM
HackAbuse's Avatar
The j-body's have long tens of thousands of miles on theirs without problems
Old 11-18-2006, 10:52 PM
Ever hear anyhting bad about them at all though?
This is something I would definitely be interested in, but kinda worried about durability.
Old 11-18-2006, 11:04 PM
HackAbuse's Avatar
Keep in mind these transmissions were Designed for a 3.1L V6, we make far less power than that.
In fact, you will be prolonging the life of your transmission with one of these, since you will be reducing the amount of friction in the tranny
Old 11-19-2006, 10:55 AM
BlackLS's Avatar
So have you had any problems with it yet like it not shifting right or cel's ect.
Old 11-19-2006, 03:17 PM
HackAbuse's Avatar
Lot's of Jbody guys said Stage 2 gave them CELs
I've been running Stage 2 since it was installed in my car, and no CELs yet
Old 11-19-2006, 03:22 PM
BlackLS's Avatar
So how many miles do you have with the shiftplus installed and how hard are the shifts?
Old 11-19-2006, 04:55 PM
And can this be used as the final version, or is that still in the process of being made?
Old 11-19-2006, 06:28 PM
HackAbuse's Avatar
About 100 so far, the shifts aren't as hard as I'd like them to be for the track, but its nice for daily driving.
Keep in mind my definition of a "hard shift" is metal clanging, chassis twisting all out shift lol
Old 11-19-2006, 06:29 PM
HackAbuse's Avatar
That's it, just order one, CPP is on back order for a day or two, but they will be back in stock soon
Old 11-19-2006, 06:42 PM
RedCavyRS99's Avatar
turbotech has them aswell they work on MOST electronic GM autos very nice little toy and makes a big difference in how the car feels. Plus its only what under $50 shipped? A good investment if you ask me.
Old 11-19-2006, 06:44 PM
HackAbuse's Avatar
TurboTech does in fact have them, but when I ordered mine, it took them 5 days alone to ship it, and another 3 for it to arrive.
8 Days total
Old 11-19-2006, 06:48 PM
That Cobalt LT Guy's Avatar
I still like my autotrans intercepter I like the tuning capabilitys. But I like how the b&m can be turned on and off in the car. If only the Intercepter was like that.
Nice job Hack Us autos are fighting back
Old 11-19-2006, 06:50 PM
HackAbuse's Avatar
Did I mention I'm going to be in the 14's by this summer?
Auto FTW!
Old 11-19-2006, 06:51 PM
Auto FTW!
Your getting that 75 shot arent ya if so good luck, Im saveing for the turbo
Old 11-19-2006, 06:53 PM
HackAbuse's Avatar
I like the idea of having a cheap, universal product, that, when I dont want it, I dont have to use it, it's as easy as the flip of a switch
Old 11-19-2006, 06:55 PM
I have a nos wet system heading my way I might set it up for a 35 shot with the TURBO
Old 11-20-2006, 07:30 AM
BlackLS's Avatar
Hey Hack can you take a pic of the plug that you have to tap in to?
Old 11-20-2006, 08:45 AM
HackAbuse's Avatar
Will get one later today possibly
Old 11-20-2006, 09:16 AM
wdsoccer's Avatar
how many stages does it have? the stages can only be changed when the vehicle is off? oh well at least it can be changed. lol
Quick Reply: Drivetrain: How-To: Install B&M Shiftplus
