MAF Frequency / Tuning Questions .... READ ME! Need help!
Old Nov 20, 2006 | 09:36 PM
sethallen's Avatar
Hey guys I know nothing about KR, timing, tuning, or MAF
I am getting knock at WOT above 4k in 2nd, 3rd, 4th, and possibly 5th. At first I thought it was only 4th, but a little more testing revealed otherwise.
I have Stg 2, 2.8", Injen CAI, Interceptor
NgkBrk7e's set at .40 gap
Would the MAF Freq. off of the Interceptor have anything to do with my KR i'm getting?
What should the MAF be at, idle, or WOT?
Should I shorten or lengthen the gap on my plugs to help stop the KR???
How can i get rid of this damn knock?
Old Nov 20, 2006 | 09:44 PM
patathSS's Avatar
What MAFF are you seeing at WOT?
The easiest way to correct this is bettr gas, less boost, or less timing. I would also try putting the stock airbox on and seeing if that changes things.
Old Nov 20, 2006 | 09:58 PM
Blown 4-banger's Avatar
I was able to get another 2 degrees of timing by calibrating my MAF table. Do a run and scan the car, then take the MAF histogram, and put those values into your MAF table. I took the average of 3 runs for mine. It worked great.
Old Nov 20, 2006 | 10:32 PM
sethallen's Avatar
how do u change timing? and how do you record runs with the interceptor
thanks for the help guys ive been trying to figure this stuff out for awhile now
sethallen's Avatar
and what are good MAFF numbers????
Old Nov 20, 2006 | 10:40 PM
Helps your car to know how much air your car is sucking. You add timing by changing the spark map.
Old Nov 20, 2006 | 10:43 PM
sethallen's Avatar
do u change the spark map with HP tuners?
and what are good MAFF numbers to be reading???
Old Nov 20, 2006 | 10:44 PM
I don't know its car spacific! Yes you change the spark map with HPT.
Old Nov 20, 2006 | 10:45 PM
sethallen's Avatar
hey thanks for the help blown
Old Nov 20, 2006 | 10:52 PM
What are your typical LTFT. My first thought is that your maf is reading less air than is actually entering the car, this would result in a leaner afr and more timing since it thinks it's under less load than it is.
Old Nov 20, 2006 | 10:58 PM
You want all your trims to be between + or - 5
Old Nov 20, 2006 | 11:32 PM
DWK5150's Avatar
Your better off getting your LTFT at 0 to -4. Positive LTFT means your adding fuel negatives mean the computer is pulling fuel. I got my car down to 0 to -3 just takes time to get them there.
Old Nov 20, 2006 | 11:47 PM
Actually your BEST off just getting a wideband.
Old Nov 21, 2006 | 05:38 PM
sethallen's Avatar
should know this by now but what is LTFT
Old Nov 21, 2006 | 05:39 PM
Long Term Fuel Trim
and STFT is Short Term Fuel Trim
Old Nov 21, 2006 | 05:45 PM
sethallen's Avatar
and those are viewable on the Interceptor right?
how can you change LTFT?
taking off my intake?
Old Nov 21, 2006 | 06:24 PM
Witt's Avatar
Long term fuel trims are minor corrections the PCM makes to compensate for things such as weather, wear and tear, incorrect fueling values, etc. It determines these values by fueling the car the way it has been tuned and then comparing the a/f by using the oxygen sensors and making adjustments to the values to achieve the deisred a/f.
Adding aftermarket equipment, ie. larger intake tube, will cause large trims if you don't recalibrate the MAF. Its a sort of countermeasure used to keep the car running at peak efficiency.
Old Nov 21, 2006 | 07:57 PM
Yeah, thats why calirbating the MAF table helps so much. My LTFT used to be between +1 and -5. All over the place, recalibrated the MAF table and the LTFT went to between 0 and -3
Old Nov 21, 2006 | 08:29 PM
bigworm's Avatar
think of the maf table as the baseline that your ecm uses to find 14.7.
LT/ST fuel trim are the means to change that baseline.
You want those LTFT's 0 to -4 because when you goto PE, this baseline is used alone without LTFT's to correct it.
In a long about way, my calibrating your maf your giving yourself a strong stable baseline for fuel at PE/WOT, part throttle cruise is always balenced out by LT/ST fuel trims.
Old Nov 21, 2006 | 09:59 PM
Witt's Avatar
Very true, however in PE fuel trims will be calculated into fueling if the trims in those cells are positive. If they are negative, they will default to 0 for that cell. As always, trim measurements/corrections will always lock anytime any type of enrichment is introduced.
Old Nov 21, 2006 | 10:03 PM
sethallen's Avatar
and you adjust ltft with hptuners
Old Nov 21, 2006 | 10:14 PM
You don't tune the LTFT directly, you tune other things so the computer knows how to make your car run more efficiently.
Old Nov 23, 2006 | 01:52 AM
sethallen's Avatar
my "long trim B1" as read on the interceptor, was all over the place during normal driving....from -2 to 14
at WOT it was between 1.5 and 8
wtf????
Old Nov 23, 2006 | 02:14 AM
You need some tuning.
Old Nov 23, 2006 | 11:53 AM
sethallen's Avatar
definitely but i don't know enough about tuning to do it...and i don't know anyone around here that is knowledgeable enough for me to trust...dammit
maybe il just go back to stage 2 setup and take off my cai
