My Tune, opinons and help wanted/needed
Old Nov 26, 2006 | 12:47 PM
bdwarr6's Avatar
I have attached a log file and my tune
also what do i need to do to monitor KR, i added it to my scan screen but its not showing anything, Im just honestly stunned i have 0 knock from all this and am worried its not right
My tune
http://www.sharebigfile.com/file/25900/my-tune.hpt.html
my log
http://www.sharebigfile.com/file/25901/laz.hpl.html
Old Nov 26, 2006 | 12:59 PM
bdwarr6's Avatar
Also mods are
2.6
60lb injectors
10:1 pistons
my af/r is about 16.3.17.4 at idle and normal driving is 15.8-16.8
i have hit about 3/4th throttle and its 12.1-13.0
i havent hit WOT yet
Old Nov 26, 2006 | 01:03 PM
Your config file for your logging is hosed. You aren't logging Total Knock Retard and your LTFT aren't configured right either. Don't log ANYTHING that is labeled as bank 2 it will through off all your sensor/hitsograms.
Also your tune, why is your AFR Stioch 14.79, it should be 14.69, do you like your car running lean?
You are running extra timing, on top of stock and higher compression. Not a good idea since you aren't logging knock.
Why are you running a 2.6, why not get it working with a safe pulley size?
Old Nov 26, 2006 | 01:34 PM
bdwarr6's Avatar
Ill go throw my 2.8 on
i have also edited a few other things im going to get out and check some stuff with a log around the block and post the results
Old Nov 26, 2006 | 01:35 PM
bdwarr6's Avatar
here is a copy of my new tune file, I was using the wrong one
http://www.sharebigfile.com/file/25932/my-tune.hpt.html
Old Nov 26, 2006 | 01:42 PM
Seriously I would put on the stock file or stage 1 flash and start from there. Do you have 42# injectors?
Baby steps
Old Nov 26, 2006 | 02:15 PM
2K5SS/SC?'s Avatar
BD, get a tune from someone on here that has an 05' with 60LB injectors and the 2.6" pulley. Then tweak it to your specs needed. Most likely like Zinner said, you will have to pull some timing due to the higher compression pistons.
Old Nov 26, 2006 | 02:26 PM
bdwarr6's Avatar
http://www.sharebigfile.com/file/25966/new.hpl.html
new log
bdwarr6's Avatar
I am running a tweaked intense stage 5 tune
Old Nov 26, 2006 | 02:59 PM
tweaked how? Not to state the obvious but didn't your car fail running that same calibration ? I think you need to take a step back to stock or stage 2, they are both safe calibrations. I hate to say it but the one you are using is not designed to be safe, it's designed to produce power.
Old Nov 26, 2006 | 03:04 PM
Also you need to log "Total Knock Retard" it's a PID, the KR sensor variable is not correct on your PCM and will always read zero.
It's a PID, under engine, Retard, Total Knock Retard
Old Nov 26, 2006 | 03:41 PM
bdwarr6's Avatar
i got it working
i also took the timing out of a stock 05 tune and put it into my file i was getting a hell of alot of knock at idle
My next questions is, how do i adjust my a/f while cruising and idleing
I know pe enrichment vs rpms adjusts it at WOt
but im in need of cruising and idle
bdwarr6's Avatar
No I was running Robs tune
there is differance there
I think its timing and some a/f differances
Old Nov 26, 2006 | 03:42 PM
bdwarr6's Avatar
Zinner would i tbe possible for you to send me a gm stage 2 file that is setup to run 60lb injectors?
I am honestly just trying to find a safe tune so that I can drive it around town and break in the motor.
I will tweak it on a dyno next month sometime
Old Nov 26, 2006 | 03:49 PM
You need to talk to Dan, I don't have a 60# file cause I don't have 60# injectors so I don't know how to make them work.
Cruise and IDLE AFR's are controlled automagically with the Stioch AFR variable and the Bank 1 Sensor 1 O2 sensor, maf, and LTFT/STFT's. I would set it to 14.69 and work on your injectors. You want your LTFT between -5 and 5
Old Nov 26, 2006 | 03:58 PM
bdwarr6's Avatar
In hptuners scanner I dont get any o2 readings, im guessing that would be part of my idle problem
Old Nov 26, 2006 | 04:06 PM
Bika's Avatar
Fail Less.
great. and i thought my tuning was just good when i was seeing no KR. i was probably knocking like a **** and it just wasnt reading it im damn lucky i didnt break the damn thing.
Old Nov 26, 2006 | 05:01 PM
bdwarr6's Avatar
welcome to the club i just got 8* of knock
Old Nov 26, 2006 | 05:23 PM
an0malous's Avatar
I assume your running colder plugs and 94 octane?
Old Nov 26, 2006 | 05:41 PM
06blackg85ss's Avatar
hey bd I can send you some config files for 60's and some other goodies if you want
Old Nov 26, 2006 | 06:02 PM
bdwarr6's Avatar
please do
bdwarr6@gmail.com
Check out my new log guys only 4.9* of knock and it was a long run major improvement!!!!!!
http://www.sharebigfile.com/file/26103/wot.hpl.html
bdwarr6's Avatar
colder plugs and 93 octang I dont want to chance driving to sonoco its about 15 min away yet
but i will be
Old Nov 26, 2006 | 06:11 PM
bdwarr6's Avatar
here is my current tune file aswell
http://www.sharebigfile.com/file/261...r-Laz.hpt.html
Im thinking 5* of timing above 5k should fix the know, larenzo suggested this and im thinking it should work pretty good
Old Nov 26, 2006 | 06:12 PM
That is the max amout of knock retard the PCM can add, thats really bad.
Old Nov 26, 2006 | 06:16 PM
bdwarr6's Avatar
Yea, I fixed it
im now down to 4.9* at wot and that 8 was at like 35% throttle
My timing was freaking insane
