Gravana Tuning Gravana Tuning is a proud Supporting Vendor
GRAVANA BG COIL-OVER SUSPENSION Pre-Order Sale
Old Dec 20, 2006 | 02:03 PM
Gravana1's Avatar
Chevrolet Cobalt & Pontiac G5 enthusiasts constantly tell us that they currently suffer the pain of not being able to find a true engineered adjustable suspension solution at a reasonable price for a car that begs to be driven hard. From the first day we received our pr-production Cobalt from GM in 2004, we knew that this was a unique suspension system upgrade opportunity. After two years of testing various suspension products, Gravana is announcing the release of the new B+G Coil-Overs for the Cobalt & G5. This is the ultimate coil-over system for the Cobalt, Cobalt SS and Pontiac G5. Hands-Down! Designed for street and track use, B+G Coil-Overs offer the best of both worlds in terms of ride quality and performance. Designed in the USA and manufactured in Europe by B+G exclusively for Gravana, this system is superior to anything else on the market!
Finally, a complete engineered coil-over suspension solution that offers performance AND value is available from Gravana! Introducing, the B+G Coilover System!
CLICK HERE TO ORDER!
  • Double Ride Height Adjustability
  • 32-Level Damping Adjustability
  • High Quality European Design
  • Anodized Threaded Steel Bodies and Lower Brackets
  • 6061 T6 Aluminum Components
  • Works with Optional Adjustable Pillowball Camber Plates
  • Revalvable & Rebuildable
  • Lifetime Warranty! (Yeah, that's forever!)
Most coil-overs force you to lower the spring perch to adjust height, which reduces the shock travel and performance. The B+G Coil-Overs allow you to lower the car without reducing the shock performance. How? Each shock body is fully-threaded for precise ride height and weight transfer, and inserts into threaded steel lower brackets. Thus, the stroke of the shock rod does not change. Additionally, the B+G coil-over has billet adjustable spring perches which can be lowered, giving these Coil-Overs Double Ride Height Adjustability. This separate height adjustability via spring perches allows you to fine-tune your stance and ride or even slam the car for shows. For those who have been torn trying to figure out which suspension is best, Gravana has the Answer! The shock bodies, perches and brackets are all anodized steel for maximum strength and corrosion resistance. Component pieces are made from 6061 T6 aluminum alloy for a combination of strength and light weight.
Each shock body houses a Monotube Gas Charged damper for quick response and steering control without loss of performance during high stress use. Unlike twin-tube dampers that experience oil-foaming, the monotube design provides a reliable and consistent level of damping force. Each shock incorporates 32 levels of bump & rebound damping adjustment (16 clicks adjusting both compression & rebound simultaneously on each click), allowing you to dial in the best combination of rebound and compression for any driving environment. In our testing, click settings 1-5 are excellent for most street environments. 6-9 are for the more aggressive drivers, looking for the competitive edge yet still street friendly. 10-12 is for the driver who wants track-level performance for that smooth mountain road or even Autocross. Levels 13-16 are for those of us who like to wake up on a Saturday morning, bypass breakfast and coffee, and load our helmets in the car for a day at the track. Most people will end up in the 4-12 range to achieve the ultimate combination of comfort and performance for daily driving!
The coil springs included in the kit are specifically designed to work with the Gravana/B+G Coil-Overs to provide the best combination of performance and ride quality in an effort to provide you with a finely-tuned coil-over suspension system. Similar to GTO and BMW applications, the rear set-up includes an adjustable shock, with a separate height-adjustable spring and perch kit. As a policy set forth by B+G, we do not publish spring rates until the product is released for obvious reasons. Higher and lower rate springs will be available for those who want to fine-tune your race set-up. Once you have tested the system, email us your rate requests and we will gladly accomodate. For the serious competitor, the shock bodies can be custom valved to your specifications. There is no additional charge if the shocks are valved at the factory via special order. We can also re-valve your existing shock bodies, which is what most people want. Run them as-is for a few sessions and then have us make adjustments from there. The cost varies depending on the changes required. As with all special orders, custom-valved orders must be pre-paid. As with most racing products, custom valved bodies are not returnable except under warranty. Ride height will range from 0" - 3.0" and can vary slightly from car to car.
Pillow Ball Camber Plate Top Mounts (Shown here) will be available separately subsequent to the release of the coil-overs! The B+G Coil-Over System is a direct bolt-in for all Chevrolet Cobalt and Pontiac G5 models.
WHAT'S THE DEAL?
MSRP is $1599.99. This kit is sold exclusively by Gravana. However, even though we have the exclusive, we are currently offering the kit for only $1200.00 (USD).
PRE-ORDER TODAY AND LOCK-IN YOUR NO-RISK PRIORITY ON THIS LOW PRICE AND
FREE SHIPPING!!!
Your credit card will not be processed until the item ships.
Old Dec 20, 2006 | 02:11 PM
2K5SS/SC?'s Avatar
Damn if I had the money I would definitely be in on this one! That's a steal for B&G quality coilovers! Grrrr... Why does everyone have to have sales when I'm broke!!!!
Old Dec 20, 2006 | 02:14 PM
alleycat58's Avatar
THANK YOU!!!!!!!!!!! Looks like these are the best out there and the price is fantastic. Any idea how long you will be offering them for that price? I'd love to have a set but money is pretty tight right now.
Old Dec 20, 2006 | 02:32 PM
SS_Canuck's Avatar
^^ Agreed. This is the type of coilover system I have been waiting on. Unfortunately your timing on this deal is bad. I to would like to know the time frame for this price. Being in the holiday season, this type of purchase will have to wait at least 1-2 months for me.
Old Dec 20, 2006 | 02:33 PM
Gravana1's Avatar
Pre-Sale = We don't authorize or charge your card until they are ready ship! It just holds your priority. Plus, it weeds out the tie kickers. We notify you before shipping to make sure the card information is correct and your shipping address is current.
Old Dec 20, 2006 | 02:51 PM
YellowLT's Avatar
Are the Pillow Mounts available Now?
In addition, You wanna Sponsor a east Coast 2.2.
Old Dec 20, 2006 | 02:59 PM
Gravana1's Avatar
The PBM will be available once the coil-overs are out. We are also working on an EDFC. Stay tuned!
Regarding sponsorship, mail a proposal to us for consideration. We do not respond to sponsorship requests that come via email or phone.
Thx!
Jim
Old Dec 20, 2006 | 03:07 PM
YellowLT's Avatar
Sounds good.
Old Dec 20, 2006 | 03:12 PM
Mercury's Avatar
Wow, I want....
Old Dec 20, 2006 | 03:55 PM
uthinkimodd's Avatar
so I can see that the front shocks are adjustable but what about the rear?
Old Dec 20, 2006 | 06:50 PM
an0malous's Avatar
forgive me for noob questions....but I live in ALberta canada and i want to be able to lower my car in summer, but wintertime it cant be low....so i have 3 options....
changing springs every season, which sounds like a nightmare, but springs are cheap
Coilovers
or airbags....which is expensive...and from what i hear not condusive to daily driving, and can scrub tires pretty bad.
my question is....does this kit bolt right onto your car and then your done?
you can adjust ride height and damping and everything is good?
Will this scrub tires without camber and allignment every time i adjust height?
basically im asking how will this work with someone who isnt savvy on suspension engineering, and just wants a nice shock setup that i can alter during the seasons, and maybe jack up the rear and lower the front for track days.
also 1 more question.....tax time is coming soon and im sure myself and alot of other buyers will have money to spend at that time.
will this price be available in feb march?
Old Dec 20, 2006 | 11:10 PM
DWK5150's Avatar
Looks like a very nice setup. When will these be shipping?
Old Dec 20, 2006 | 11:59 PM
Badmunky's Avatar
Vary nice.
How much will the mounts be and when will these be shipping?
Same as most IM broke for a month or 2.
Later
Old Dec 21, 2006 | 12:01 AM
Shortbus's Avatar
Nice setup, bad timing, so much to buy, so little funds.
Old Dec 21, 2006 | 12:33 AM
jimbos'ss's Avatar
man i want those. i guess power mods are out the window for a while, until i get those.
Old Dec 22, 2006 | 10:26 AM
an0malous's Avatar
Coilovers
bump for questions
Old Dec 22, 2006 | 10:37 AM
Gravana1's Avatar
Yes, they are adjustable like the fronts..
Old Dec 22, 2006 | 10:43 AM
cawpin's Avatar
I would also like to know how long this deal is good for. I understand that I won't be charged until they ship but I don't want to get an email in 3 weeks saying they are shipping. My tax return may cover these. Will you delay shipping until funds come through if I commit now?
Old Dec 22, 2006 | 11:01 AM
Gravana1's Avatar
No problem.
Old Dec 23, 2006 | 01:21 PM
an0malous's Avatar
questions for you gravana
i guess im really asking....will this kit work for a commuter/daily driver
Old Dec 23, 2006 | 01:45 PM
BooSSted's Avatar
I can't find them on your website!
Old Dec 30, 2006 | 10:35 AM
Maybe this link will work.
Old Dec 30, 2006 | 12:56 PM
Gravana1's Avatar
Select your year, make and model, then suspension. They are listed under Coil-Over Suspension.
Jim
Old Dec 31, 2006 | 12:49 PM
I am in! Can't wait till I get them.
Old Dec 31, 2006 | 01:19 PM
Tung's Avatar
Coilovers
bump ive got the same questions
