2.0L Supercharged Specs
Engine: Ecotec 2.0L SC (LSJ)
Type: 2.0L supercharged/intercooled inline 4-cylinder
Displacement (cu in / cc): 122 / 1998
Bore & stroke (in / mm): 3.39 x 3.39 / 86 x 86
Block material: cast aluminum with cast iron cylinder liners
Cylinder head material: cast aluminum
Valvetrain: chain-driven dual overhead camshafts with roller followers, 4 valves per cylinder, dual rotating balance shafts
Ignition system: coil-on-plug coil-on-plug
Fuel delivery: sequential fuel injection
Compression ratio: 9.5:1
Horsepower (hp / kw @ rpm): 205 / 153 @ 5600
Torque (lb-ft / Nm @ rpm): 200 / 271 @ 4400
Recommended fuel: 91 octane unleaded
Maximum engine speed (rpm): 6450 fuel cutoff
Emissions controls: 3-way catalyst (Tier 2 LEV 2 Bin 8 )
Estimated fuel economy(mpg city / hwy / combined): TBD
SCC only pulled a 15.3 with the ION Redline, but they had quite a few problems with their preproduction model, mostly a bad tack. Hopefully all these get fixed for the Cobalt and it can run mid to high 14's at least.
