60lb and tune interest thread
Hi everyone,
I've been approached by a member for setting up a GB on FLOW MATCHED 60LB injectors and a tune to go along with it.
Depending on how many are interested I will work out a price.
1. Matty
2. Meatball
3. SSpartan
4.
1. Matty
2. Meatball
3. SSpartan
4.
with a 2.6 both mods would be great, but im noticing a trend where the dual pass works the best out of the 2, i will be installing the gm dual pass endplate (option B) at tag in the spring to compare temps, but with the heat a 2.6 generates, its good to have some supporting cooling mods before you start to get on her
if that isnt the route you wanna go check out tags water/meth kit, it drops intake temps and gives you an increase in power.
we can send you a 2.6" tune if you wish.
We prefer everyone to send their own PCM's in, this way we don't have to do the whole core charge thing and you don't have to go get harassed by the dealer to get a case learn.
But if you absolutely can't have any downtime we can send you one of our PCM's on a core exchange.
yes you can
yes you can
Last edited by Sales@Tagracecraft; Mar 6, 2007 at 11:54 PM. Reason: Automerged Doublepost
So you don't send the tune but need the PCM ? I was under the impression we could flash our own with HPT with a tune sent to us. Then a little back and forth tweaking.
