So am I the only one that got a flawed B&M shifter
Old Sep 14, 2005 | 01:06 PM
SilverSS/SC's Avatar
The install went great up until I started moving thru the gears . 1-4 is fine , but on the shifter I got , the B&M reverse lockout collar TOTALLY interferes with the stock plastic shift plate retainer . I had to grind down the entire wall on the retainer and reshape the grove for reverese to get the shifter in 5th and reverese . Theres nothing I really could done wrong on the install to cause that kinda condition . It looks like the guide pegs for the lockout collar were possible set to low , causing the collar to sit to low and interfere with the stock retainer plate .
Has anyone else had this problem on their B&M shifter for the SS/SC or Redline . Now that I "made " the stock retainer work , the shifter is awesome . Im pretty peeved I had to do alot hacking to get 5th and reverse though . I havent called B&M yet , the last time I talked to tech there a aftermarket company ended up knowing more about what I needed to know they he did .
Old Feb 24, 2006 | 10:05 PM
Ern's Avatar
Ern
I know this thread is old but I wanna comment. I just installed my B&M and I had to do the grinding too. My reverse was fine but when I tried to go into 5th it would hit the gate. I mean I could get it in but it took some nudging so I ground the inside wall of the stock holder and now its fine.
I am like you though, ticks me off I had to grind on my stuff. Kinda honks me off.
Old Feb 24, 2006 | 10:37 PM
Cobalt_Supercharged's Avatar
I think I remember Vendian saying he had the same problem. He just lifted the collar like you would to go into reverse and it would go into 5th.
Old Feb 26, 2006 | 11:03 AM
ninja44's Avatar
The shifter needs a liitle adjustment closer toward your right leg. I had the same problem at first and a wee adjustment fixed it, going into reverse was a little rough but after a few weeks the shifter wore down the retainer and it's not a problem anymore.
Old Jul 6, 2006 | 09:56 PM
arsenal21's Avatar
I had this probelm too. Just groud the ****** down. Soo fustrating started at 530 and gonna be done probably by 1030. So annoying.
007Buff
Jun 11, 2017 03:04 PM
biniecki
Oct 25, 2015 02:23 PM
Cptnslo
Sep 24, 2015 09:32 AM
007Buff
Sep 22, 2015 09:48 AM
The Rookie24
Sep 20, 2015 04:33 PM
