Front Page News Site Polls
2005 Chevrolet Cobalt SS Supercharged Coupe
Old Nov 11, 2004 | 07:59 PM
JonyyB's Avatar
Site Founder
<img src="https://www.cobaltss.net/articles/info1.jpg" align="left" border="0" hspace="5" vspace="5">The 2005 Chevrolet Cobalt SS Supercharged Coupe is the high-performance model in the Cobalt family of coupes and sedans that will debut in the fourth quarter of 2004. The Cobalt SS Supercharged builds upon the expressive design and dynamic driving experience of the Cobalt Coupe and Coupe SS. “The Cobalt SS Supercharged Coupe was developed to appeal to the tuner enthusiast,” said Pete Langenhorst, Chevrolet Cobalt marketing director. “We engineered from the very beginning all the key components to deliver an exciting driver’s high performance sport coupe – straight from the factory.”
Body structure, chassis, suspension The Cobalt was created on a strong foundation. The rigid lower-dominant body structure is engineered as a single unit for mass efficiency and stiffness. The underbody uses high-strength steel as welded members in strategic locations for maximum strength, structural integrity, mass optimization and crashworthiness.
The Cobalt’s suspension tuning was refined at Germany’s famous Nurburgring, one of the world’s most challenging road courses with more than 170 turns in nearly 13 miles...
Cobalt SS Supercharged features a strut-type front suspension, semi-independent torsion beam rear suspension, and increased diameter front and rear stabilizer bars with tuned suspension bushings. In addition, the chassis and springs were stiffened, the spring rates and damping were specially tuned and the shock strut valving was modified for a responsive, sport suspension feel. The monotube rear shocks with 33-millimeter pistons are larger in diameter than those found on standard Cobalts. The coupe’s ride height also has been reduced by 10 millimeters. The electric power steering also is tuned for increased driver feedback.
The SS Supercharged features larger, five-bolt wheel hubs, brake calipers and brake pads. The larger calipers and brake pads allow greater braking capacity and are proven performance parts found in other high-performance GM vehicles. Cobalt SS Supercharged features the segment’s leading wheel size with 18-inch forged-steel alloy wheels and P215/45R18 Z-rated performance tires.
High-Performance Powertrain
The Cobalt SS Supercharged Coupe features a race-inspired Ecotec 2.0-liter supercharged four-cylinder engine and five-speed manual transmission. Cobalt benefited from GM Racing’s successful Ecotec-powered cars competing in the NHRA Summit Sport Compact Racing Series with significant learnings transferred during the development of the Cobalt.
The Ecotec 2.0L SC four-cylinder engine delivers 205 horsepower at 5600 rpm and 200 lb.-ft. of torque at 4400 rpm. Compared to the Ecotec 2.2-liter I-4, the cam timing was altered significantly to raise the mid-range torque and to match it with the top-end power.
The engine includes an Eaton M62 helical roots-type supercharger and features an air-to-water intercooler to reduce the temperature of air entering the engine. The supercharger produces a maximum boost pressure of 12 pounds per square inch (psi). The Ecotec 2.0L SC is mated to a five-speed manual transmission. The 240-millimeter clutch assembly is larger on the 2.0-liter supercharged I-4 than the other naturally aspirated Ecotecs. The five-speed has close-ratio gearing that is tailored to the power band of the 2.0-liter engine. To improve acceleration the final drive ratio is also shorter at 4.05:1. A short-throw shifter quickens the shifts and provides a more positive feel as well. The shifter’s travel is approximately 1 inch shorter than the shifter found in standard Cobalt models. Equal length transmission half shafts are also utilized to address torque steer in this front-drive car.
Distinctive Design and Features
The exterior styling of the Cobalt SS Supercharged complements the performance aspects of the car. The front fascia features a large, deep air inlet and the rear fascia has a cutout for the large, chromed exhaust tip. Along with revised rocker moldings, the enhanced bodywork of the SS Supercharged visually lowers the coupe 1 inch. Halogen fog lamps are also included.
The interior was also modified to complement the performance characteristics of the Cobalt SS Supercharged Coupe. The accelerator pedal was redesigned to enable heel-and-toe driving to improve driver feedback and response. The interior also features titanium-faced speedometer, tachometer and gauges in the instrument cluster, and an A pillar-mounted boost gauge to monitor supercharger performance.
Article credit: CarzUnlimired.com
GaryGibblez
Jan 14, 2020 10:35 AM
Hill1513
Sep 21, 2015 07:18 AM
Josh@ottp
Sep 8, 2015 10:18 AM
medic710
Sep 6, 2015 08:53 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
