PLX Gauges | new gauging sensation
Old May 24, 2007 | 02:59 PM
thmotorsports's Avatar
Thumbs up PLX Gauges | new gauging sensation
HERE IS A NEW KICK @$$ PRODUCT. THESE GAUGES ARE SWEET. CHECK THEM OUT. MANY FEATURES. VERY PRETTY.
PLX iMFD DM-100 Gauge + SM-AFR Wideband O2 Sensor
$377 SHIPPED!!!!
PM US FOR SUPPER SHIPPED PRICES FOR ALL THE OTHER MODULES AND COMBO DISCOUNTS!!!!
DM-100
Intelligent Multi-Functional Display (iMFD)
Universal 2 1/16" (52mm) OLED Color Display for all Sensor Modules
* Real Time Plotting
* Customizable Gauge Styles, Backgrounds and Colors
* Digital Display
* Organic LED
* Set Peak and Hold Points
* Can Display Data from 4 Modules at Once
* Daisy Chain up to 32 Sensor Modules for One Display
* Simple to Install
* PC Interface Software Included for Analyzing Data
* Comes with Remote Control
WATCH IMFD VIDEO: CLICK TO WATCH
DESCRIPTION:
The iMFD DM-100 is a 52mm (2 1/16") universal gauge designed specifically to display a wide variety of automotive information far superior to that of a standard automotive gauge. The DM-100 can display up to 4 different sensors simultaneously and can be connected in a daisy-chain with up to 32 sensor modules and 32 other display modules.
KEY FEATURES:
1. Color Organic LED Technology (OLED)
2. 180 Deg Viewing Angle
3. High Contrast, Daytime visible
4. Multiple gauge styles (gauge, numeric, plot, 4 param, x-y scatter, custom)
5. Peak and hold (4 parameters, high and low)
6. Intelligent warning (4 parameter comparison)
7. Custom gauge design
8. 4 button remote
9. Daisy chain topology
10. Custom wallpaper upload
11. Automatic sensor detection
12. Extruded aluminum construction
STANDARD GAUGES:
Unlike other automotive displays on the market where the user has no choice but to view data presented only in one form, the DM-100 has the capability of displaying data in multiple forms. As seen above in the state diagram, each parameter can be viewed in a gauge style, a numeric style, a plot style, and simultaneously in the 4 parameter style. Each style offers its unique advantages.
The plot style is a unique feature in automotive displays. Now data can be viewed as a trend, instead of just it's instantaneous value. This gives the user quicker access to information without the use of a data logger.
Some additional user customizations are also available in the standard gauges. Colors can be customized, and background wallpapers of your choice can be uploaded from the PC making each gauge unique to your own taste.
CUSTOM GAUGE:
The custom gauge design is one of the many unique features found on the DM-100. In state 1-4, the user has the absolute freedom to design your own gauge on the PC and upload it to the DM-100 via USB. You will have full control over every pixel, every pixel color and every displayed frame. It's only up to your imagination what you want to design and display to represent your automotive sensor data. You may also visit our Custom Gauge Library where you can download already made custom gauges.
PEAK AND HOLD:
The user can set the DM-100 to remember both high or low values for each parameter. Peak values can be viewed in state 2-3 and can be reset on command at any time.
INTEGRATED WARNING:
1-4 parameters can be setup to trigger a warning condition. When a warning is triggered, the parameter's value will be displayed on the screen giving the user immediate information. Multiple warning schemes are available. This feature can prove to be extremely vital in monitoring the health of your vehicle.
TECHNOLOGY:
The DM-100 employs several new patent pending technological breakthroughs in digital design. At the core of this technology is a 32 bit CPU coupled with a PLX designed GPU (graphics processor unit). Just has high end video graphic cards are designed for PC games, the PLX GPU was designed specifically for automotive display applications, making the OLED color display possible at an affordable price. Ram, flash and USB technologies are also incorporated.
INCLUDED ITEMS:
1.DM-100 Module
2.HDD-100 52mm Universal OLED Display
3.6ft 4 button remote
4.4ft power wire with 2.1mm connector
5.1ft Serial Cable
6.6ft USB Cable
7.CD includes User Guide, DM-100 Utility, USB Device Driver
8.Comprehensice User Guide
SPECIFICATIONS:
Physical Dimensions (Box) 4" x 2.875" x 1.125" (104mm x 75mm x 28mm) L x W x H
Physical Dimensions (Gauge) Standard 2 1/16" (52mm) x 0.7" (18mm)
Power Consumption 1.5 Watts
Compatible HDD HDD-100
Processors Custom PLX 32 Bit Processor, Custom PLX GPU (Graphics Processor Unit)
Operating Temperature 0 - 85 Deg C
Operating Voltage 10V-18V
Automatic Sensor Detection YES
Human Interface 4 Button Remote
PC Interface USB 2.0
# Sensor Modules 1-32
Firmware Upgradeable Yes
Enclosure Extruded Aluminum
$377 SHIPPED!!!!
Call 1-800-959-0145 ext 3 (Adam K) toll free and mention the sale
**Master Card, Visa, Discover, AMEX** OR PM US!!!!!!!
EMAIL: AdamK@thmotorsports.com
WE ALSO USE AIM: adamkthm
SM-AFR
Sensor Module - Air/Fuel Ratio
Digital Wideband Air/Fuel Sensor
DESCRIPTION:
SM-AFR accurately measures the precise air/fuel ratio (AFR) of any internal combustion engine. Up to 32 SM-AFR modules can be daisy chained together in the iMFD system. SM-AFR can also be used as a stand alone unit capable of interfacing with 3rd party hardware. All Sensor Modules are housed in high quality extruded aluminum designed to operate even in the most extreme conditions. In addition, all SM modules offer outstanding digital accuracy, response and resolution which far exceeds that of a standard gauge.
SM-EGT
Sensor Module - Exhaust Gas Temp
Digital EGT Sensor
DESCRIPTION:
SM-EGT accurately measures the exhaust gas temperature or cylinder head temperature of any internal combustion engine. Any K-Type thermocouple is compatible. Up to 32 SM-EGT modules can be daisy chained together in the iMFD system. SM-EGT can also be used as a stand alone unit capable of interfacing with 3rd party hardware. All Sensor Modules are housed in high quality extruded aluminum designed to operate even in the most extreme conditions. In addition, all SM modules offer outstanding digital accuracy, response and resolution which far exceeds that of a standard gauge.
SM-FluidTemp
Sensor Module - FluidTemp
Digital Fluid TempSensor
DESCRIPTION:
SM-FluidTemp accurately measures the the temperature of any liquid. This is ideal for coolant temp, transmission temp, oil temp and any other fluid temp monitoring. Up to 32 SM-FluidTemp modules can be daisy chained together in the iMFD system. SM-FluidTemp can also be used as a stand alone unit capable of interfacing with 3rd party hardware. All Sensor Modules are housed in high quality extruded aluminum designed to operate even in the most extreme conditions. In addition, all SM modules offer outstanding digital accuracy, response and resolution which far exceeds that of a standard gauge.
$377 SHIPPED!!!!
Last edited by thmotorsports; Jun 4, 2007 at 02:27 PM. Reason: Automerged Doublepost
Old May 24, 2007 | 03:04 PM
johnkb8's Avatar
looks cheesy
Old May 24, 2007 | 03:07 PM
Originally Posted by johnkb8
looks cheesy
They look pretty sick in the car actually. All digital. Very different from anything out there. Check out the video.
Old May 24, 2007 | 03:09 PM
Moza13-'s Avatar
i kinda like em, the first one kinda color matches the g5 with the orange and green
Old May 24, 2007 | 03:13 PM
06_SS_S/C's Avatar
That actually does look pretty cool in the car...so he was saying in the video you just daisy chain them together. Lets say you had 3 displays and 4 sensors. You could change it so any display could display any sensor just by pushing some buttons?
Old May 24, 2007 | 03:23 PM
You can totally customize the color and display. Endless possibilities!!!
That is correct. Or you can have one display and simply many sensors. Its pretty cool!!
Old May 24, 2007 | 03:29 PM
06_SS_S/C's Avatar
Hmmm, that is pretty neat. What do the little sensor units cost by themself?
Old May 24, 2007 | 03:39 PM
PM'd ya with pricing
Old May 24, 2007 | 03:57 PM
IMADreamer's Avatar
that might be kind of cool. What's the price on the EGT and a wideband AFR? Plus whatever else is needed to run them.
Old May 24, 2007 | 04:04 PM
oldsskool's Avatar
Ya id be interestead to find out what the pricing is on the DM-100 kit as well as the additional sensors. Also how big are those red boxes, where are people mounting them?
Old May 24, 2007 | 04:22 PM
PM'd ya
PM'd ya
The dimensions are in the post. They are pretty small. You can mount them where ever you want as long as there is no direct heat on them...like under the seats or somewhere hidden in the dash....and just connect up the wiring.
let me know guys
Old May 24, 2007 | 04:25 PM
Witt's Avatar
Shoot me a PM with pricing. I'm interested in 3 displays, a wideband box, boost/vacuum box and EGT box.
Old May 24, 2007 | 04:35 PM
06_SS_S/C's Avatar
they don't offer the gauge face in white do they?
Old May 24, 2007 | 04:38 PM
Exclamation
PM'd ya with what you need!!!
Old May 24, 2007 | 04:40 PM
RuSSo-29's Avatar
Subscribed. I can't watch vid's at work so I'll see it when I get home.
Old May 24, 2007 | 04:47 PM
yel-low's Avatar
yeah what do they cost and how accurate are they
Old May 24, 2007 | 04:53 PM
PM'd ya with pricing. They are very accurate. A computer manages all the signals and you can get the readouts digitally with great precision. You can see the signals in many readouts.
Watch it later and let me know what you think.
Old May 24, 2007 | 05:11 PM
SS SCHGD's Avatar
That looks pretty cool, I see my boost gauge being jumpy, I should fix that....Can you PM a boost and AFR package price? Thanks
Old May 24, 2007 | 05:18 PM
PM'd ya....this boost gauge is 100% accurate. And you have many ways of viewing the data.
Old May 24, 2007 | 05:22 PM
SS SCHGD's Avatar
thanks for the quick reply....this is something I'll have to look into a little later in the summer, just got back from Vacation...
Old May 24, 2007 | 05:31 PM
pimpnwink's Avatar
PM me with pricing becuase I am really intereted since its either these the interceptors or the nexus ones from autometer.
Old May 24, 2007 | 05:34 PM
CJ BadBlackSS's Avatar
Why can't a set of prices just be listed in here on the first post? seems silly that you need to keep PMing people...but thats just me.
Old May 24, 2007 | 05:54 PM
Sounds good....let me know. Vacation > Gauges. lol
PM'd ya
PM'd ya with pricing....we are the only ones that carry these and we have to be a bit secretive...lol
Old May 24, 2007 | 06:23 PM
shawns94's Avatar
pricing please.
Old May 24, 2007 | 06:55 PM
camarokiller's Avatar
I would like the prices on the boost, and afr sets, with everything i need please
