2.2 L61 Engine: Intake Mod for 2.2L Cobalts with pictures!!
Old 06-27-2007, 11:42 AM
fivepointohman's Avatar
Well, I got an answer to all you 2.2L guys looking to get a little more HP and Throttle response out of you 2.2L's that won't cost you a penny. Basically I removed the factory silencer out of the front of the air box which i didnt think was so big until I pulled it out of there. Looks stock, But It made a huge difference in throttle response, no more sluggish delayed response when you hit the gas, and it sounds better with a nice deep tone when you get on it. hope you all enjoy it, next will be a cheap custom pipe from the other side of the box to the throttle body.
1. remove headlight and headlight bracket:
2. remove the entire silencer assembly from the car, which you then have a huge open space.
3. This is the air silencer. Very restrictive...
4. This is the stock base of the factory airbox.
5. This is the whole on which the factory silencer tube was running though. Now it is just in the open space which if you have factory fog lights the grates will allow cold air to rush in there. If not there is plenty of cold are coming in from the side of the radiator and the body.
finally re-install the headlight bracket and the factory airbox and it looks perfectly stock it will not void any warranties that I know of.
Hope this help everyone, like I said the sound and the throttle response alone is pretty amazing. As far as mileage not sure yet, but I will comment on that as soon as I see what it does.
Old 07-22-2007, 05:20 PM
06 LS's Avatar
awsome mod thanx for the time works really good
Old 07-22-2007, 05:23 PM
DarkCobalt13's Avatar
works great. good how to!!! now ya gotta get rid of the plastic crap on top or the throttle body, that will help out as well
Moza13-'s Avatar
about to do this to my car tonight.
Old 07-22-2007, 05:42 PM
g5mike's Avatar
nice easy mod,let us know how it feels afterwords
Old 07-22-2007, 05:46 PM
Moza13-'s Avatar
will do. actually im in the mood, ill go do it to my car right now
edit: Im working on it right now, and the opening seems too small to get this peice of **** out of there. the place where it connects to the intake is like stick in that little hole since it doesnt want to go down any further
Old 07-22-2007, 07:30 PM
tonio5555's Avatar
I got this far the other night and then the sun went down so I couldn't finish. Let me know how you manage to get it out.
Old 07-22-2007, 09:52 PM
HatedCobalt's Avatar
isnt there a bolt in the fender well under the inner fender that hold that piece in. actully i know these is.....maybe im wrong....
Old 07-22-2007, 10:11 PM
gtxsport11's Avatar
will this mod do any good for the GMPP Intake?
Old 07-22-2007, 10:14 PM
Belto's Avatar
it can help too... check it out,, if you dont like it you can always put it back on
Old 07-22-2007, 10:16 PM
gtxsport11's Avatar
what about now that i have the fog lights will that allow more cold air to pass through than before with the ls bumper
Old 07-22-2007, 10:20 PM
Belto's Avatar
hummm? IDK,, with the ss/sc bumper, you can do a custom ram, in that part by using the passenger side fog light hole, but, with the fog in,, I think is the same flow of air, maybe a lil more, maybe
Old 07-22-2007, 10:23 PM
gtxsport11's Avatar
thanks bro i am hopefully goin to go pick up the balt 2 morrow it will have a new SS/SC Bumper and the GM Lip kit on it along with what needed to be replaced
Old 07-22-2007, 10:25 PM
Belto's Avatar
Ill be waiting for the pics
Old 07-22-2007, 10:27 PM
gtxsport11's Avatar
then it will be off to get the new radio and the led underglow kit installed
Old 07-28-2007, 10:06 AM
th0ughtless's Avatar
I want to do this to my car, but I was wondering...are there any risks involved in this mod?
Old 07-28-2007, 11:03 AM
none, unless you like driving through puddles up to your bumper. Otherwise its 100% worth taking off!
Old 07-28-2007, 11:51 AM
Also, would it suck in hot air?
Old 07-28-2007, 12:03 PM
xCobalt05x's Avatar
I removed that plastic thing down below when i had to pull off the front bumper to put on the bodykit front bumper, was really easy to take off when my bumper was removed.
Old 07-28-2007, 03:26 PM
I just took mine off. Gives it a better throttle response and sounds neat...lol
Old 08-01-2007, 09:27 AM
Gotenks's Avatar
This mod was way harder then it looks.. I ended up having to cut out the silencer, as I would have had to take off the bumper to get it unbolted and then out of the engine compartment. This silencer is huge too btw
Old 08-02-2007, 12:38 PM
kingmike06's Avatar
Omg, I just finished removing mine. It was really hard. for starters its a screw thats under the silencer and and bolt that has to be pull out thats behind the silencer and below the intake filter. It was a pain tring to remove the screws and then tring to remove the silencer without out removing the bumper is hard. You have to take the top part off and then twist and bend the wheel base and bumper.
Old 08-02-2007, 12:49 PM
blktrax's Avatar
Revised how-to With Options
Yes you can get the resonator out without taking the bumper off.
Its MUCH easier to do with a set of wheel ramps and getting the front end up.
Remove the splashguard inside the wheel well and the headlight and headlight bracket, then its very simple.
Be sure to put the splash guard Back on.
GM's Service Instructions:
Air Cleaner Inlet Duct Replacement
Removal Procedure
Remove the right front tire and wheel. Refer to Tire and Wheel Removal and Installation .
Remove the right front fender liner. Refer to Front Fender Liner Replacement .
Remove the air cleaner intake duct retainer.
Remove the air cleaner intake duct bolt.
Remove the air cleaner intake duct.
Installation Procedure
Position the air cleaner intake duct.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the air cleaner intake duct bolt.
Tighten
Tighten the bolt to 10 N·m (89 lb ft).
Install the air cleaner intake duct retainer.
Install the right front fender liner. Refer to Front Fender Liner Replacement .
Install the right front tire and wheel. Refer to Tire and Wheel Removal and Installation .
My cooler air inlet option - Its 3-1/2 Stainless Steel Truck Exhaust Stack Pipe, NOT dryer hose form Home Depot.
Old 08-03-2007, 12:59 PM
Wow, thanks blktrax for the idea. I'm going to get that pipe for mine today.
Old 08-03-2007, 03:13 PM
Broke EF's Avatar
Blktrax, I cant help but notice this in youre sig
"2007 Cobalt LS $12,385 New, Go ahead and try to do it cheaper."
I just have to bust youre ***** and tell you I got my 2007 LS for $11,900 brand new still in the plastic
Sean
Quick Reply: 2.2 L61 Engine: Intake Mod for 2.2L Cobalts with pictures!!
