is the 2.4 gonna be a good engine to turbo?
i am currently looking for an automatic car with a good ammount of tq like the 2.4 liter that can be turboed with no problem. i have a celica right now that cant be turboed due to its vvtl-i causing misfires and back fires and a huge power loss in hiogh rpms. so i need a car that i can tune easily and boost easily, is this a good choice?
well the deal isnt gonna go thru like i wanted or else i would get the g35 but they want 550 a month for that car which is way more than i wqanna spend 400 is my max since i want money left over to turbo the car i get.
Get a couple year old S4 with the 2.7 TT and you would be ready to go. I was about 5 min away from getting one but it was just a little to expensive at the time. But the amount of after market parts for it is insane. Goapr.com
so, right now there is no turbo kit that will fit it? i was thinking the 2.2 kit would fit but i guess not
Only issue might be the higher compression ratio (10.4) that might limit boost levels somewhat, but it's still not so bad.A decent intercooler will help. And dont let anyone scare you with the fact that the piston "is only" of the hypereutectic variety- thats all the LSJ is using as well and it seems pretty good! The only concern would be getting the correct tune.
WHO'S GOING TO BE THE FIRST TURBO 2.4 VVT???!!!
WopOnTour
10.4 is very high comp to be great with boost. its not impossible but harder to tune and more chance of the big bang effect. hypercraptectic pistons are junk... they are full of silicon to prolong life and for environmental control reasons. knowing first hand how weak these pistons are. i would be very scared to run boost over 9 #. but i think that 6-7# would be assuming u have a good tune and very reserved timming any knock and kabooom at high rpm/boost
WopOnTour
hypercraptectic pistons when used as they were intended to be, hyper pistons provide excellent trouble free performance while aiding in reduced emissions numbers. Unless the intended use involves high compression / big NOS / high boost or sustained high RPM, opting for forged pistons is a waste of the extra dollars spent. In the hands of a careless driver that does not pay attention to oil changes or is perhaps prone to getting on it a bit before the engines properly warmed up, forged pistons will usually wear out / fail long before a hyper one would. It has to do with how tight they are able to fit a hyper piston as opposed the wide clearances needed for a forged unit.
Hyper pistons have a high silicone content to aid in the casting process, it sure doesn't help with durability though. If you do a cross section of a hyper piston you will often find silicone pockets, basically looks like swiss cheese
i've worked in a mustang performance shop for a couple years i'm sure the quality of the mustang pistons is much lower, and a mustang piston is much larger which adds to its weakness.
that being said, i'm saying running 6-8psi is safe, run more if u'd like i've seen guys run 12psi on stock mustang motors, some fail, some don't.
i've never seen or worked on a 2.0 compared to a 2.4. everything i state even the emissions statement was correct so go and OMG yourself.
and 10.4 : 1 is very high for a boosted ap, has anyone boosted a 2.4 VVT motor cause the 2.0 doesn't have VVT does it???
WopOnTour what are you laughing about? have you ever boosted a 2.4? what mechanical back ground do you have?
well i do feel kinda dumb now thinking that the vvt would be bad for boosting since , 1: the twin turbo supra has vvt and its one of the best engines around. 2: all the honda turbo fine with v-tec so i have nothing to woory about, but i dont really understand this piston thing you guys are talking about, i need to make sure because i will be buying the car this week
the 2.4 is the only vvt motor in the cobalts
and the vvt that is used is variable cam timing , not a change in valve lift like vtec
it is alot harder to boost a the vvt motor , because of the cam changes arent as predicable , like the change to vtec is
it is possible , but harder
how does the supra use the vvt so well?
i see so i would need a vvt controller to effectively turbo this car then, is that what u are saying?
