Help!!!!
Old Sep 26, 2007 | 05:21 AM
Atreyu's Avatar
Help!!!!
ok, ive looked for like an hour and i know there has to be a how-to for it... how do you take off the door panels? ive wanted to paint them for a long time but i heard you have take them off a certain way??? any help would be fantastic...
Old Sep 26, 2007 | 05:32 AM
M-Dub's Avatar
Sorry man, I wish I could help... Welcome to the site... My fellow Mizzerian!
Old Sep 26, 2007 | 05:53 AM
skymynx's Avatar
oh well still dont like your state but thanks for the neg rep. bad military experince. weather sucked. anyways first off there are three screws you gotta take out. one behind your door handle and two in the little arm rest. these screws are underneath removable trim pieces. you can use a small flathead to remove them. be patient it might take more then one try to get them out. once the screws are out then start to pull the panel out on the bottom of the door. work your way up pushing the panel up. i find it easier to have the window down good luck
Old Sep 26, 2007 | 06:10 AM
REIGN SS's Avatar
Original Hayden Fanatic
https://www.cobaltss.net/forums/show...25&postcount=4
try this next time you search:
Being new to the forums can be overwhelming & the search function can be very difficult to find information at first glance, but here are some tips to get better more accurate results.
When you use the “Search” function at the top of the page and type in your request you will get 50000 threads that have nothing to do with nothing. This is because the forum defaults to searching for your key words in the entire thread.
So what is one to do, sift through 49995 uninformative threads? No, instead this is how to get some more accurate results.
Click Search: Advanced Search
This will bring you to this screen here:
Now, there are lots of options available to you here to get the best results possible. Lets use as an example you are searching for: Turbo information on your 2.2 Cobalt.
Using the “regular” search method you will get about 1000 threads, now let’s use some of the Advanced Search features.
The two key options you want to change in the Advanced Search are:
1.) Change “Search Entire Posts” to “Search Titles Only” in the Keyword area.
2.) In the “Search in Forum(s)” option select “2.2L Performance”.
Now your screen should look like this:
Click the “Search Now” button and you will find more topic specific results & hopefully you should find all the info you need.
You can also select multiple parts of the forum in the “Search in Forum(s)” section by holding down the Ctrl button on your keyboard and clicking the parts of the forum you want to search in the list.
CASol's Avatar
what he said^plus becareful with all the wire connections, some are short
Old Sep 26, 2007 | 06:12 AM
skymynx's Avatar
there you go a much more informative write up
Old Sep 26, 2007 | 03:30 PM
Atreyu's Avatar
thanks for the door help. got one of them painted today....pics soon
Old Sep 26, 2007 | 03:54 PM
thedub784's Avatar
subscribed, good luck!
