Nitrous Oxide N20
Largest, Safest Shot?
Old Nov 13, 2005 | 11:54 PM
bdwarr6's Avatar
What would be the largest shot you could give the SS S/C Safely,(IE when on the street) maybe 5-6times a motnth, and what would be the safest shot for it at the track maybe once a month.
Remember stock engine.
Links are very nice
Old Nov 14, 2005 | 01:43 AM
Xenozx's Avatar
you talking Nitrous? IM no troll, but there is no safe shot on the street, its completely illegal! Then again we all drive cars way too fast then they need to be already, so how can I complain....
Anyway I have no idea, but save your money and buy a staged kit, not nitrous.... You could probably get away with an 85 shot on stock engine, but I wouldnt go over a 50 shot.
Old Nov 16, 2005 | 10:04 PM
SloBaltSS's Avatar
Its not illegal in florida.
Old Nov 16, 2005 | 10:29 PM
Xenozx's Avatar
IM not going to say your wrong, although I think you are.
You cant pop nitrious on a residential road. Come on dude, speeding is illegal, and theres no way your going to pop nitrous and not be speeding so I call BS on that man. Prove me other wise.
Until then I am calling you wrong, and if it is legal in Florida, then they are a bunch of noob asshats....
Old Nov 16, 2005 | 10:34 PM
mikekoz's Avatar
haha he just said asshat.
Old Nov 16, 2005 | 11:16 PM
Kritter's Avatar
I'm no nitrous guy by any stretch, but unless I'm mistaken, you can't shoot nitrous unless you're running wide open, correct? By that factor alone, it's use on public roadways may not itself be illegal in Florida, but the manner by which you get to the point you can use it is illegal, making the whole point mute. In the end, i personally think running nitrous period is stupid, especially on a stock motor.
Old Nov 17, 2005 | 03:57 AM
IonNinja's Avatar
who gives a **** whether its legal or not
what a way to not answer the question
just for being safe, pick up some colder plugs and run a 50 shot max.
:edit:
actually I just noticed you had an SS/SC...I don't know about nitrous on that car. They are having enough problems with intakes and headers.
Old Nov 17, 2005 | 06:30 AM
Brian MP5T's Avatar
Well the original question was..
SAFE SHOT....
My Answer is ZERO for a Safe Shot...
Here is "Colder Plug" if you didn't know
Nitrous should only be used at Wide Open Throttle. Limit yourself to 50 At Most.
Be careful with the shifting, if you spray during shifts, you will have a problem. it's totally up to you.
Old Nov 17, 2005 | 07:07 AM
Brian MP5T's Avatar
If you must Spray, Get Control of the Nitrous. Don't just spray with a Red Button.
Description
The Venom400 performance control module is an add on control unit that features it's own micro-controller. This module is connected to the throttle position sensor and the Manifold absolute pressure sensor, and by monitoring the sensors output characteristics and modifying the input signal to the vehicles existing ECU.
Old Nov 17, 2005 | 02:07 PM
BlAckOnBLaCK's Avatar
There is a guy that runs a 75 wet shot in his SS and has had no problems. I believe that the build book even says 75 is ok. BUT....you WILL need to upgrade your clutch, probably even with the 50 shot.
Old Nov 17, 2005 | 02:14 PM
c7015's Avatar
A Flu Shot
Old Nov 17, 2005 | 02:36 PM
Brian MP5T's Avatar
Is this "Guy" going to buy a new engine when it blows up?
I'm not trying to be a H8TR.
I want nobody to bitch if something goes BOOM, that's all.
Nitrous is not ever "Safe", there is always the risk that it will break ****.
There, End of My Thread Jack... Everyone has been warned.
Old Nov 17, 2005 | 04:49 PM
IonNinja's Avatar
get a WOT switch (which most have anyway) and a window switch so that you can control when nitrous engages and disengages. that way you can open the bottle and be on your way...
Old Nov 18, 2005 | 12:37 AM
Per GM's various publication we can run up to 300 HP safely on the LSJ.
That would probably be about 75 shot.
Old Nov 18, 2005 | 02:50 AM
No...he will probably replace it with a used ford festiva engine.
No, but really, a 75 is ok. Come on...if GM says it is ok, then you know that it is safe enogh. Nitrous is only bad if you put too big of a shot on that your internals can handle. What would be the differnce between a car that has other mods that equal 300 on stock internals and n2o on a motor with stock internals....keeping in mind that both are not running too lean or rich.
Old Nov 18, 2005 | 07:08 AM
Brian MP5T's Avatar
Ok, as long as the criteria of the discussion is that the car never goes lean, then yes I will agree with you. The thing is that **** Happens and ECU's go crazy sometimes when things happen that they were never expecting... like 75+ HP
Old Nov 18, 2005 | 08:21 AM
R33P3R007's Avatar
360 L337 User
if you go to nitrous express they have all sorts of kits. anywhere from 25 shots to 1000. On stock internals I personally would run a 25 or 50 to be so called "safe" and for the track an occasional 75 I would use the 75 sparingly, even though the performance build book says the 75 is ok. I wouldn't want to push it.
Old Nov 18, 2005 | 08:42 AM
CobaltBurst's Avatar
Dont Use Nitrous on the street, your going to kill yourself, or worse, you will kill someone else...
Old Nov 18, 2005 | 08:43 AM
and if you even think to use nitrous on the streets in FL, you should be slapped. Ive lived here my whole life, people CANT drive its a society handicap down here...
Old Nov 18, 2005 | 08:51 AM
Hello's Avatar
75 is perfectly fine as long as you have the system installed correctly and have all safety backups working properly. With a manual tranny car, you must install a window switch incase you miss a shift. A WOT switch used in inconjuction with the window switch will offer added protection so you dont have the nitrous engaged outside of WOT conditions. Keep the bottle at a consistent temperature, keep the lines purged, and keep everything in 100% operable condition. Nitrous use is all about safety. Break one of the safety rules and the chances of engine damage from nitrous use increase dramatically.
With that said, it is 100% safe to run a 75 shot if all rules are followed. Even CoBoltz007 idea of running a 50 shot and a 75 shot sparingly is an ok idea and would save a bit of wear and tear on the engine.
Any critic of nitrous can and should be classified as uneducated and scared of something they dont understand
Old Nov 18, 2005 | 08:57 AM
Brian MP5T's Avatar
Originally Posted by Hello
75 is perfectly fine as long as you have the system installed correctly and have all safety backups working properly....
Well read and spoken. I like how you mentioned that it has to be built and incorperated into the car in a planed way.
Old Nov 18, 2005 | 05:51 PM
05YELLOWSS's Avatar
Who is that guy that runs the 75hp wet shot? O wait that's me, nevermind, yeah I will agree with the last 2 posts, if planned into the motor and all safety precautions are taken, nitrous is a proven, reliable and yes, Safe, way for a quick boost in power. Yes that clutch guy is also me, I did however leave that out of my planning stage, so I forgot, sue me, but that has since been taken care of with a stage 2 from SPEC. It kicks ass!!! Also a good suggestion is the 255/50/16 BFG G-force drag radials I run at 6-8psi, instant grip and NO wheel hop, I love the whole setup right now, very satisfied with the car and I have had no problems that others seem to have right now, maybe I got the over-inspected one from the factory I don't know, no codes, great boost (16-18 when on the spray), and still excellent gas mileage, word of warning, treat a nitrous car right though, thorough inspections after each track night or night of heavy spraying, I'm an aircraft mechanic so that comes seond nature to me on everything, I've seen some crazy stuff on planes you don't want to know about that people are lazy and just don't want to bother looking at, just be careful. Jon
Old Nov 18, 2005 | 06:50 PM
vB00STw's Avatar
A little off topic but..Say you have a nitrous kit and a WOT switch. You're street racing and you get to WOT and the nitrous engages. You're zooming along and a car cuts in front of you. You take your foot off the gas*, and then apply the brake.**
Now for my questions:
* If you take your foot off the gas while the nitrous is engaged, does it disengage since you arent at WOT? Also, would the car keep accelerating if the nitrous stayed engaged for a few seconds?
** If you apply the brake with nitrous is engaged, does it disengage?
Thanks guys
Old Nov 19, 2005 | 10:30 AM
Lil Blue SC's Avatar
:edit:
I AGREE WITH U ON THAT ONE who cares if its legal... its all about the speed and adrlin
i couldnt tell u personaly what to use. i know that the piston are forged steel and the bottom end is pretty strong with the bullite crank shaft so id do what he just said 1 range colder spark plugs and a 50 shot
Old Nov 19, 2005 | 05:42 PM
GTPsRule's Avatar
Thanks guys
If you have a WOT switch then the nitrous is only spraying when the throttle is wide open. There is no nitrous cut off switch for the brakes. If youre on the brakes and at wide open throttle then youre probably on LSD or smokin too much of the happy grass and shouldnt be driving anyways
