Lnf Tranny
Old Oct 29, 2007 | 01:48 AM
RacerX114's Avatar
Lnf Tranny
Ok guys before I get flamed for starting a new LNF thread, here me out. I've been reading the other threads and have noticed that no one really talks about the tranny. Ok as I understand from all of the threads that the new balt shares the exact same engine and tranny as the hhr ss. Well the tranny has the "NO-LIFT SHIFT" thing that most think just means you can stay on the gas while shiffting. But if you look at no lift shifting in drag cars it means theres no clutch involved and basically you just shift. So I looked at some pics from the hhr ss interior and sure enough theres no clutch pedal. Take a look let me know what you think.-----http://www.hhrclub.org/galleries/2008-chevy-hhr-ss/-------at the bottom theres a pic looking at the steering wheel and theres no clutch.
Old Oct 29, 2007 | 01:50 AM
VolklSkiier's Avatar
theres 3. the gas pedal is kind of shadowed and looks like part of the floor mat.
Old Oct 29, 2007 | 01:52 AM
RacerX114's Avatar
See thats what I thought but that looked really big for a gas pedal.
Old Oct 29, 2007 | 01:54 AM
D4u2s0t's Avatar
the gas pedal is almost always bigger than the brake and clutch though. also, i'm pretty sure that we knew that the hhr was coming in an auto tranny as well as manual.
Old Oct 29, 2007 | 01:57 AM
REIGN SS's Avatar
Original Hayden Fanatic
Originally Posted by THE BIG SITE STICKY
Transmission
Backing the turbocharged engine is a standard GM Powertrain Sweden F35 five-speed manual transmission. Semi-synthetic transmission fluid is used for its capability of absorbing heat and resisting breakdown during high-performance driving.
A performance-oriented feature referred to as “no-lift shift” allows maximum performance – upshifts can be performed very quickly without lifting the throttle. An algorithm in the engine’s controller enables this high-performance feature, which helps maximize acceleration and gear changes.
A short-throw shifter with stiffened shifter bushings and modified cables and attachments enhances confidence behind the wheel, giving the driver a firmer, more direct and quicker shift feel. A limited-slip differential is available with the manual transmission.
...please, continue your discussion
how can you not see the 3 pedels? You need to up the brightness on your monitor if you cant see them:
I have to say that the gauge cluster is NUTS!
redlineblueline's Avatar
is the no lift shift a hardware or a software thing
Old Oct 29, 2007 | 02:00 AM
RacerX114's Avatar
Sorry guys just had to make sure, guess i need to go get some glasses.
Old Oct 29, 2007 | 02:01 AM
REIGN SS's Avatar
lets try this again: A performance-oriented feature referred to as “no-lift shift” allows maximum performance – upshifts can be performed very quickly without lifting the throttle. An algorithm in the engine’s controller enables this high-performance feature, which helps maximize acceleration and gear changes.
Basically the computer cuts the throttle when you engauge the cutch under heavy acceleration.
Old Oct 29, 2007 | 02:02 AM
2fastSS's Avatar
i actually love that interior, and the seats look well done...
ItalianJoe1's Avatar
Software. Same way dodge adds it as part of the Stage kit for the SRT-4.
Old Oct 29, 2007 | 02:03 AM
so could this be added through HPT
Old Oct 29, 2007 | 02:05 AM
REIGN SS's Avatar
probably not, im sure there are some extra sensors involved.
Old Oct 29, 2007 | 02:11 AM
thats what i want to know if its any hardware differences or if its all software
Old Oct 29, 2007 | 02:15 AM
As far as I know, it basically is just a rev-limiter type thing, it allows the car to keep the power up, its not as harsh as the stock rev limiter but lets the car hold boost and therefore torque while you shift. Its really nothing special, but I'm hoping that the clutch is much stronger than the SS/SC or they won't be lasting too long. Besides, every new kid who wants to try that feature out while driving every day is going to burn out a clutch pretty fast. Its just powershifting with a soft-touch rev limiter.
Old Oct 29, 2007 | 02:17 AM
i am looking into for an entirely different reason...I want it for some of the hills i get stuck in traffic on and dont like slipping the clutch as much i could just keep the throttle down and go
Old Oct 29, 2007 | 02:20 AM
What? I don't think that would be a good idea. Picture powershifting, thats no-lift shifting. They just tune the ECU to not be as harsh when you do it.
Old Oct 29, 2007 | 02:22 AM
so basically i'm looking at it for a way to use it that doesnt work the same way
Old Oct 29, 2007 | 02:24 AM
Right, its not what you want. You need hill-assist control, which holds the brakes for you until you get the car going forward, I think Saab offers it and maybe some others, but you will still be using the clutch as much as any decent driver who just has his foot on the brakes. LIGHT slipping of the clutch on a hill isn't going to hurt anything, unless you are using the clutch to hold the car on the slant, not the brakes. That could cause issues with heat buildup.
Old Oct 29, 2007 | 02:33 AM
i'm just overly paranoid about slipping it too much i just get stuck on 60* slopes in traffic and i just think that the clutch is slowly getting ripped apart
Old Oct 29, 2007 | 03:18 AM
MaJ's Avatar
MaJ
I don't know all that much about the no-lift shift system, but what I have been able to figure out (from a fair amount of reading) is that most people that talk about this feature don't have a damn clue what they are talking about.... /rant
Keep in mind the following is pure speculation, and not necessarily factual in any way.
From the way the system is described, it sounds as though the computer will adjust the amount of fuel dependant on the clutch pedal depression. This would basically mean that as you put your foot on the clutch, the throttle body closes as if you were releasing the accelator. As you release the clutch, the throttle body opens again at a set ratio which is compared to the clutch pedal position.
This would do a lot of things to improve the quality and precession/speed of the shifts. Firstly, it would eliminate the need for the driver to learn the clutch/accelator ratio for a clean shift. Secondly, by having the computer system control how much fuel is delivered to the engine, this will prevent the engine RPM from climbing between shifts and help eliminate common wear and tear caused by "power shifting".
Powershifting (a.k.a. flat shifting, full throttle shift, or clutchless shift) is a method of shifting used with manual transmissions to reduce the time where the driving wheels are not powered.
Since the accelator, brake and clutch pedals are all electronic, this system is very possible. But again.. pure speculation on my part.
Old Oct 29, 2007 | 03:24 AM
greekss's Avatar
i kno for a fact the new bmws have the hill assist feature on their manual cars
REIGN SS's Avatar
sounds logical
Old Oct 29, 2007 | 12:25 PM
DaREDss's Avatar
wtf is with that rpm gauge
Old Oct 29, 2007 | 12:29 PM
MaJ's Avatar
MaJ
What do you mean? Looks normal to me... just small..
Old Oct 29, 2007 | 08:00 PM
I agree, without knowing the exact method, what you describe is most likely what will be going on. It is just computer controlled protection that enables powershifting=like behavior. I think you are correct in that it will use the ETC to reduce throttle opening during shifting, but it could also just retard timing and pull fuel. Closing the throttle will still cause a loss of turbo speed and boost, which could be avoided by not closing the throttle but using a basic torque management type algorithm to allow less wear on the drivetrain during shifting and it would be faster to resume full torque because you wouldn't loose any boost during the shift. Thats how Dodge does it on the SRT-4, they don't have an electric throttle but they have the same feature with the Stage 1 and up computers.
