Is this an ECOTEC?
Old Dec 21, 2007 | 07:14 PM
Onyxd04Redline's Avatar
Is this an ECOTEC?
Says Vortec but looks like a regular 4cyl ecotec motor.
Old Dec 21, 2007 | 07:19 PM
articzap's Avatar
Vortec I believe has different head designs and are only found in trucks. Usually based off of another motor.
06rallyss's Avatar
nope just a vortec truck engine
Old Dec 21, 2007 | 07:20 PM
Coblt ss super's Avatar
thats weird
Old Dec 21, 2007 | 07:21 PM
Pity. If it was an eco it probably could have been adapted. Imagine the M62 setup from the SS on that beast.
BLKLS's Avatar
the oil pan looks cloe but i don't think so
what a blob of an intake manifold, i like the crazy long oil dip stick.
Old Dec 21, 2007 | 07:25 PM
nhcobalt's Avatar
not an ecotec but that would be sweet if installed on a cobalt.
Old Dec 21, 2007 | 07:26 PM
I'm going to the junk yard tomorrow to find trans am seats. Will see if they have any colorado's to snap a pic of the part numbers on the head
UmeNNis's Avatar
Don't all ecotecs have the drop in filters? If so, that's a giveaway right there.
Old Dec 21, 2007 | 07:28 PM
InfinityzeN's Avatar
Thats actually an Atlas, which is GMs current family of straight engines for trucks and other high torque/low rpm usage. There are a lot of similarities between them and the ecos. evolutionary divergence basicly.
Old Dec 21, 2007 | 07:30 PM
THATS the engine chevrolet should have used in the SS
Imagine the torque that engine would put down supercharged.
It has a 3.8 X 4.0 Bore/Stroke
What are the major differences between the two infin?
Old Dec 21, 2007 | 07:32 PM
articzap's Avatar
I wonder what the rod to stroke ratio is. Probably couldn't rev high enough for the SS.
Old Dec 21, 2007 | 07:34 PM
06rallyss's Avatar
and the weight
Old Dec 21, 2007 | 07:47 PM
Originally Posted by LLV
The straight-4 LLV engine is sold as the Vortec 2900 in GM trucks. It shares the same 95.5 mm bore and 102 mm stoke as the LLR Vortec 3700. The LLV displaces 2.9 L and produces 185 hp (138 kW) @ 5600 RPM and 195 ftˇlbf (263 Nˇm) @ 2800 RPM. Engine redline is 6300 RPM.
Thats what it is. Basically a slight bump up in size and power from the LK5 (the 2.8L I4). Their a little higher reving them the V8s, but still limited by their design.
But they do produce a hell of a lot of torque in a very flat curve. From ~2k all the way to 5.5k rpms the engine is putting out 175+ lbs of torque.
Originally Posted by Atlas Engine Family
Atlas is a name for a family of modern inline piston engines for trucks from General Motors. In production, the engines use GM's Vortec name, and I4, I5, and I6 engines are all part of the same family, sharing the same manufacturing equipment, rods, pistons, valves, and other parts. They feature variable valve timing on the exhaust side, electronic throttle control, and a special oil pan with a pass-through for the half shafts in four-wheel drive vehicles.
The Atlas program began in 1995 along with the planning for GM's next-generation mid-size SUVs and pickup trucks. These vehicles were designed around the I6 engine. The I6 version was used in a Baja 2000 racing truck, winning its first race in a class that also included V8 engines. Another I6-powered truck won the truck class at the Pikes Peak International Hillclimb.
Oh yea, although they rev higher, 5.5~5.6k is the top of their cam. The grind they use is designed to start building lots of torque down low and hold it.
However, if you built one out of aluminum, balanced it a little better to rev higher, put a cam that traded some torque for more top end in there, etc... well... you would pretty much have a 2.9L eco with only half way VVT. Well, close but not quiet, since they have been developing separately for over 10 years now.
Old Dec 22, 2007 | 01:34 AM
**** trading low end torque for top end power. If you could supercharge this engine with an M62 you could easily see gobs and gobs of low end torque. Make 260-280lbs of torque at 2000-5250 and like 260-280 at 6000rpm would be PERFECT.
Old Dec 22, 2007 | 01:38 AM
Admiral Jedi's Avatar
Nope. Look at the oil filter. It's on the bottom.
On the Eco...well the 2.2 and 2.4's, the belt only goes around the crank, alternator, a/c, and tensioner. The power steering pump is driven off the intake cam. On that motor...not so much.
Old Dec 22, 2007 | 03:34 AM
GULLABLE0NE's Avatar
isnt that the 5 cylinder chevy uses?
Old Dec 22, 2007 | 03:36 AM
The pictures says "I4" on the bottom right.
Old Dec 22, 2007 | 08:07 AM
OzzyruleZ's Avatar
They have an I4 and an I5. Actually when I went up to pick up my Cobalt Wednesday, my tech buddy had the head off of one of the I4's. I got a chance to check it out. They are pretty simalar to our Eco's but they surely aren't the same.
Old Dec 22, 2007 | 11:47 AM
I wonder if head is just different or the blocks could be interchanged.
Old Dec 22, 2007 | 03:58 PM
Sharkey's Avatar
the atlas series includes an I4 I5 and I6. they are all very simular to each other
Old Dec 22, 2007 | 04:30 PM
The Atlas and Ecotec are divergences of the same family as I said earlier. One of the big differences though is that the Atlas is designed for RWD applications, while the Ecotec is designed for FWD applications.
And trust me, if you want to make it a performance engine your going to change the cams and push the torque curve higher up the RPM band. Plus do a whole lot of work to help the engine rev better. As it is now, it doesn't rev nearly fast enough to be a performance engine and really you won't take it above about 3.5~4k rpms.
Also, their a whole lot taller then the Ecotecs.
Old Dec 22, 2007 | 04:54 PM
tkosmen's Avatar
that is the 3.5 liter in-line 5 engine out of the chevy colorado. it is also used in the hummer h3. it is rated at 220 hp.
Old Dec 22, 2007 | 05:01 PM
Notice how it says 4cyl 2.9L on the bottom of the picture?
Old Dec 24, 2007 | 06:32 PM
They just don't read before they post is all...
