Went to the track
Went to the track
Hey guys, this is my first post here.
Took the car to the track for my f-body club's rental. I no longer own a Camaro but I'm still a member/mod on their board. Car is a bone stock stripper '07 LS with a 5sp. I'll just list the times up to the best pass. Times got progressively better as I experimented with launch RPMs and shift points.
15.92 @ 87.50 (2.48)
15.55 @ 88.29 (2.32)
15.59 @ 88.68 (2.33)
15.49 @ 88.94 (2.33)
15.59 @ 88.16 (2.28)
15.40 @ 89.51 (2.28)
The rest of the passes were done during bracket racing (which I won), so on some of the passes I was on the breaks and they are not worth listing. The passes were made in early November at Cordova, IL. The air was very good and DA was around sea level. How do these runs compare with other stock cars? I did better that I thought I would, would have been happy with a 15.7.
If I remember right, I was leaving at about 4k, slipping the clutch but letting it up quickly, there is a fine line between bog and spin. I found that the best shift point (not surprisingly), was right before redline 6300-6400ish. I tried short shifting at 6k but slowed.
So you are saying there are stock SS's that regularly run in the 14's? I highly doubt that.
no i was saying that on average the 2.4's are running the times he put in the first thread. im running those times. so when i said the 2.4's are on average a second faster then the 2.2's i meant that the 2.2's were in the 16's. thats what i meant by that. also this is based on complete stock times.
for who?
here's my time slip for a stock 2.4L in calgary, alberta. due to altitude and all the like i run a 16.6 up here but if i were to run down in some of the tracks you guys run i would be roughly a second faster due to the change in altitude and density. oh and im car 438
Those are definitely some solid times on a 2.2. Good for you man. To the guy that posted a slip...your 60s are way high man. 2.4 & 2.6 isn't an impressive 60. I'm not bashing, just informing. I have a disgusting 60ft average as well. I think with a 2.49 when I was stock netted me a 15.8@89. It will show in the sig.
ya i know by the time i started getting the hang of quick shifting the race season up here came to an end this year was my first year at the drag track so i still have alot of practicing ahead. that and i kept losing traction going from 1st to 2nd
ya it was an ss/sc he had a bad launch and left his ac on full blast so he bogged it a little off the tree. he's a buddy of mine and i laughed so hard at him when he told he that he had left the ac on lol.
https://www.cobaltss.net/forums/drag-racing-52/official-cobalt-1-4-mile-list-65389/
All depends on driver and elevation (that and auto or manual).
Looks like some good times though. I can't wait to go to Cordova one of these times and see what my 07 LS will run
ya thats why i always say roughly or an estimate as there are always some variable's to screw around with the times namely driver, elevation and air density.
that and the 06 ss/na are slightly faster then the 07 ss/na's. i have an 07 and my brother has an 06 and we always raced each other and he was consistently .3 seconds faster then i was.
Here is my crappy picture of my time slip, sorry its so hard to read. I'll have to scan it at work Wednesday, maybe it will come out better.
Later in the day I tried taking the spare and jack out but by that time the air got worse and I went no faster. In the spring maybe I'll try taking out the seats and whatnot to trim some weight and try again.
On my Camaro I even went so far as to take out the bumper supports but I won't be doing that with this car.
