Customer Ride
Old Dec 29, 2007 | 10:20 PM
Turbo Wax's Avatar
Customer Ride
Got an email with some pictures from a customer after using our entire line, you be the judge.
Old Dec 29, 2007 | 10:21 PM
Raven SS's Avatar
a mirror paint job after wax is always nice...whats the run down on ur products?
Old Dec 29, 2007 | 11:08 PM
Turbo Wax's Avatar
Thank you for your interest,
Background
Our Company Turbo Wax Products www.turbowax.com a Florida based company and the makers of Turbo Wax, a line of car care products especially formulated for today’s Cars.
Product Line
Turbo Wax Paint Protection,
lLquid Wax, we created this unique water-based tri-polymer emulsion that shines and shimmers like the finest of carnauba based waxes while having the durability of a polymer sealant, Turbo Wax Paint Protection is formulated especially for today's cars paints, Turbo Wax uses the best ingredients in the market, creating the best blending of a polymers for a high gloss finish, Will not stain trim and no powder residue.
Turbo Wax Shampoo
With its slick gentle suds safely removes dirt and grime without removing waxes or sealants. Especially formulated for today’s painted and clear coated finishes. This highly lubricated formula with its unique foaming quality and quick rinse characteristics safely lifts dirt and grime while helping to prevent swirls from washing.
Turbo Wax Pre Cleanser
Was especially formulated to be used prior to applying Turbo Wax Paint Protection. Use Turbo Wax Paint Cleanser to create a surface condusive to polymers properly adhering to the finish,safely removes most embedded dirt, bugs, tar, road film and mild oxidation.
Turbo Wax Tire Gel
This unique gel formula clings to the tires surface, unlike sprays and foams that end up on wheels and painted body panels. Our Tire Protectant Gel also prevents premature sidewall dry rot and cracking. Will not sling
Turbo Wax 3 Amigos, Vinyl, leather and rubber protectant was formulated to tackle vinyl, leather and rubber all in one. This formula protects extremely well on all 3 surfaces, without the need of additional products while producing a UV barrier that prevents premature cracking, fading and hardening.
Turbo Wax Last Minute Detailer
Formulated especially for that important moment when time is of the essence, quickly produces a slick and wet glossy Appearance while extending the life of your paint sealant, removes light dust and finger prints without scratching your paint.
Turbo Wax Swirl Remover and Final Polish
When used properly quickly removes swirl marks and leaves a clear glossy finish. It contains no silicones or fillers. Works well on all painted surfaces and equally as well on clear coats.
Turbo Wax Wheel Cleaner and Brightener
Actually cleans the wheels without acids or other harmful chemicals, some of which can and will cause spotting or peeling of the clear coat on the wheels. Works well on plastic wheel coverings as well. If accidentally sprayed onto vehicle finish, just wash off, no harm done. Product is also pH-balanced and formula will not stain clear coats.
Turbo Wax Spray-N-Wax
the true definition of a spray wax: ease of use & produces a noticeable slicker finish. Keep a good coat of this on your vehicle & when it comes time to wash the bugs & grit off, the task is much easier. Contains no powders, so there is no fear of staining rubber or plastic mouldings if it gets on them. Safe for all painted surfaces, chrome, painted plastics & glass. Put a good coat on your clean wheels & then when it comes time to wash the brake dust off, the job is so much easier.
Other Products
Headlight Restoration System
Bug Removal Bar
Body Shop Line
Right now I have a 2004 VW-R32/ 12,000 miles from a dealer, the thing is a mess and soon I will provide the results.
Old Dec 29, 2007 | 11:27 PM
red07g5's Avatar
I wish I could get a mirror like surface like that.
Damn GM and there orangepeel...
Old Dec 29, 2007 | 11:43 PM
Turbo Wax's Avatar
There's a lot of products on the market, some are real good some are not, some deliver some don't, theres no secrets, if you take your time with the right tools and the right product you can do wonders, heres an old example Mitsu Evo
Fearedbynone
Apr 14, 2016 03:25 AM
riceburner
Oct 2, 2015 05:47 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Cobalt_Daddy
Sep 27, 2015 06:59 PM
Sep 26, 2015 06:44 PM
