JBP Stage 2 Cylinder Head Kit Sale
Stage 2 Cylinder Head Kit Spring Opener Sale
Our stage 2 head package is on sale until the end of March. Purchasable from any dealer at the reduced price!
Stage 2 Cylinder Head Kit Information
Originally Posted by 06black
good lookin guys.
the 10-13% increase is over the stock head flow numbers correct?
so about 60-78 extra CFM(thats 10-13% of 600CFM)
sound correct? any flow sheets for this head?
We've got flow sheets for our Stage 3 head handy, would you like to see those?
Redline for our springs are 7500RPM. For results on the Stage 2 head kit, read a little further down...
Close approximation 06black and in some cases you are correct. The percentage increase we list is HP. It's not feasible to list a finite horse power gain as our head kits will react differently on a vehicle with cams, with intake, with exhaust respectively. Hence a percentage increase is listed as a guideline as the increase of power in relation to your current HP standings.
i figured it would be flow numbers based of a "base case" scenario car.
my mistake, as for the stge3 head results, i'm ALWAYS up for some flow numbers!
I might(
also, after some lookin around i would say that if any thing your power gain percentages may be a bit low, from the numbers i've seen from other sources on your big money head, its well over the max of 19% gain you say it to have.
but ****, overachieving is never a bad thing huh!
with the stg2 head, on my motor, with it being naturally more efficient (turbo vs blower, drag,ect,ect) and capable of begin supplied with a larger airflow i can see a larger then 13% gain. but this would be more specific mine and pauls application.
ohhh, ok!
I might(
) have some stuff i'm gonna send to Rod next week, make sure he sends it to ya.
I might(
What "might" you have coming our way?
Right, its better to post a reduction and to use a percentage gain in a case-by-case basis. Albeit it is entirely possible to achieve a higher percentage gain and this has been done by other customers with this head package, albeit we are conservative in the % gain.
how bout' them flow sheets?
This is Rod's head... Stage 2 is great.. but not this great.
have you guys ever done a stock head just for some comparison.
i have 1 stock flow sheet but i'm not sure what i think about its accuracy.
i'm all for head porting, and i have some quite specific flow goals, and i know the exhaust side will be the limitation, however with that stg3 head flow sheet i see it can be done and beaten by you guys.
basically i require a minimum of 800CFM (total) head flow for my power goals plus a margin of "safety"
so aprox 200cfm per cylinder. the intake side should require minimal work to hit that number, but with out a stock sheet i'll never know how far off it is, my sheet puts its dam close to that, how ever the exhaust side, the side that truly matters will take some work.
so basically, does your stage2 head boast that flow rate?
let me know what you think.
man that scan was terrible, I can't believe you could read it.
and yes, hot is the only way to go for accuracy.
well, your flow rate is dictated by port size, contour, valve obstruction/lift/duration and the short radius of the runner to name a few variables... Pending the camshaft that you couple to our stage 2 head kit is not overly aggressive in duration and similar to stock, you'll have ample CFM to supply your needs of 200cfm / hole.
I've PMd them to you, i'd like your thoughts on "overly aggressive" and the convo can become much more open that way.
thanks for all the information to date, vary nice to run across this.
Getaway_Driver
Sep 8, 2015 09:41 AM
