5x114.3 Conversion and SS/TC Brake Swap
Haz l33t wheelz.
Due to the amount of PM's i am recieving about how i will be mounting the 19" Axis Super Hiros, with their 5x114.3 Lug pattern on my 06 Cobalt SS, I am releasing the information on my full hub swap and brake conversion.
The brakes do not need to be converted, but i chose to go that route because, well, better brakes can never be overlooked.
I will post pictures as the build continues, and do a full How-To
SPECIAL THANKS TO JOHN AT POWELL MOTORSPORTS, AND BRAD(MAVEN) FOR HIS AWESOME GENUINE GM PARTS. NOT TO MENTION BOTH FOR THEIR OUTSTANDING SUPPORT OF MY RELATIVE IGNORANCE
SCOPE:
Ok, i got sick and tired of the cruddy selection of attractive wheels for our factory 5x110. Actually, i didn't find ANY that I liked, so i decided to swap to 5x114.3, which is one of the most common 5 lug hub patterns. I remembered hearing someplace that the Grand Am Time Attack Cobalts were all running a 5x114.3 Grand Am hub conversion. I got into contact with the Powell Motorsports crew that was responsible for building the Time Attack cars for GMPerformanceDivision back in 05. We discussed the multiple angles with which we could approach this situation, and ended up settling on Grand Am hubs. These hubs, along with an LNF Brembo front brake conversion, and LNF knuckles and axles (which are considerably stronger that the production LSJ versions) make up the front hub conversion. The rear consists of a modified rear TWB, with an adjustable chromoly sway bar, transplanted from the Time Attack car, and revised end plates for the rear hubs.
Also included in this build are the OTTPerfomance CnC'd "Rotato Potato" mounts as i like to call them and OTTPerformance steering rack shims.
Also, there will be stainless steel braided brake lines all around (Also from OTT)
PARTS LIST:
Time attack Twisting Beam
Rear Caliper plate
front wheel bearings 5x114.3
rear wheel bearings 5x114.3
Rear caliper set used with pads and handbrake mechanism
Rotated Motor mounts
Shipped as a complete axle with bearings, brake hoses, calipers, pads, bolt in.
Front Knuckles TC
Front Axles TC
Brembo calipers 4 piston
Brembo rotors Solid, new
Steering Rack Spacers
SS/SC Rear Calipers Remanufactured
PICTURES:
Brembo Calipers before yellow powder coat
Yellow Paint!
TWB Bearing Plate
SS/TC Knuckle
Rear Hub/brake Assembly
Subframe w/Steering Rack Shims
THREAD WILL BE UPDATED WHEN PROGRESS IS MADE, AND AGAIN WHEN THE INSTALLATION IS DONE
NEW PICTURES POST #92
SCOPE:
PARTS LIST:
Rear Caliper plate
Front Knuckles TC
Front Axles TC
PICTURES:
Yellow Paint!
TWB Bearing Plate
SS/TC Knuckle
awsome job buddy keep it up..i'm also putting my front brembo kit together...any tips i should look out for i bought the rotors and front calipers already..i need to order the lines and what not
Haz l33t wheelz.
the TC brakes are about the same size in the rear, as the LSJ fronts, rotor wise, but we are sticking with the SS/SC calipers for the back because of the e-brake linkage, which is different on the TC, and because parts or more readily available.
the rears need to be smaller than the fronts, there is a balance that has to be mainatained, you can't just slap thr brembo calipers on all four corners and be fine.
Haz l33t wheelz.
haha, i do have a lot of work t do, but the suspension parts are coming all bolted to gether, and i just have to replace it as if it were a kit.
The TVS is on the backburner until the car moves to North Carolina.
I have some good buddies to help me, and plenty of time off.
gee, thanks.
gee, thanks.
You need calipers, rotors, pads, and pin kits. You dont need the TC bolts unless you change your knuckles. you dont need new hoses, the stock ones will work.
General Beckmiester: Youre cunning attempt at geting me to expose my hand has failed. Your Sir, looze.
First of all, WTF sig plagirism?!?!?!?! Sig and avatar theft seems to be running rampant here as of late
The General is now being kept in here on a "need to know" basis, and all photo transmissions will cease
note the last pic DOES NOT have a 'rotated potato" mount it has an LNF MOUNT out of the magic GM WHEEL HOP KIT that is FAIL in testing. Cant show all the cards Beckmeister. Sir. Yes Sir...yellow calipers out of the oven time for the 4th VHT coat...
Haz l33t wheelz.
I will edit the post, you won't have to fear JohnnyBoy.
Please, please keep sending me pictures, and if you want i will post up the picutre of your "wife" for all to see
yay, i get to be one of the ******* that was stupid enough to get suckered into this mess and help with the install/how to! lmao
jk will
you know you already owe me like 2 things, now with all these installs, your gonna end up oweing me like a ba-gillion things haha
ps thos pics are tiny
jk will
Haz l33t wheelz.
i can't wait either, and i vote for sticky.
Andrew, this is going to be a bolt on i am going to enjoy rocking that in my sig haha.
Thanks for the support guys, this has been in the process for a while, and you know what Paul, i have you to thatnk. So here's to being too lazy to take measurements, resulting in my abandonment of custom forged wheels
