5x114.3 Conversion and SS/TC Brake Swap - Cobalt SS Network
Sponsored by CARiD
Click Here
LinkBack Thread Tools Search this Thread
Old 02-08-2009, 06:08 AM   #1
Haz l33t wheelz.
ls1fbody's Avatar
Images: 120
Exclamation 5x114.3 Conversion and SS/TC Brake Swap
Due to the amount of PM's i am recieving about how i will be mounting the 19" Axis Super Hiros, with their 5x114.3 Lug pattern on my 06 Cobalt SS, I am releasing the information on my full hub swap and brake conversion.
The brakes do not need to be converted, but i chose to go that route because, well, better brakes can never be overlooked.
I will post pictures as the build continues, and do a full How-To
SPECIAL THANKS TO JOHN AT POWELL MOTORSPORTS, AND BRAD(MAVEN) FOR HIS AWESOME GENUINE GM PARTS. NOT TO MENTION BOTH FOR THEIR OUTSTANDING SUPPORT OF MY RELATIVE IGNORANCE
SCOPE:
Ok, i got sick and tired of the cruddy selection of attractive wheels for our factory 5x110. Actually, i didn't find ANY that I liked, so i decided to swap to 5x114.3, which is one of the most common 5 lug hub patterns. I remembered hearing someplace that the Grand Am Time Attack Cobalts were all running a 5x114.3 Grand Am hub conversion. I got into contact with the Powell Motorsports crew that was responsible for building the Time Attack cars for GMPerformanceDivision back in 05. We discussed the multiple angles with which we could approach this situation, and ended up settling on Grand Am hubs. These hubs, along with an LNF Brembo front brake conversion, and LNF knuckles and axles (which are considerably stronger that the production LSJ versions) make up the front hub conversion. The rear consists of a modified rear TWB, with an adjustable chromoly sway bar, transplanted from the Time Attack car, and revised end plates for the rear hubs.
Also included in this build are the OTTPerfomance CnC'd "Rotato Potato" mounts as i like to call them and OTTPerformance steering rack shims.
Also, there will be stainless steel braided brake lines all around (Also from OTT)
PARTS LIST:
Time attack Twisting Beam
Rear Caliper plate
front wheel bearings 5x114.3
rear wheel bearings 5x114.3
Rear caliper set used with pads and handbrake mechanism
Rotated Motor mounts
Shipped as a complete axle with bearings, brake hoses, calipers, pads, bolt in.
Front Knuckles TC
Front Axles TC
Brembo calipers 4 piston
Brembo rotors Solid, new
Steering Rack Spacers
SS/SC Rear Calipers Remanufactured
PICTURES:
Brembo Calipers before yellow powder coat
Yellow Paint!
TWB Bearing Plate
SS/TC Knuckle
Rear Hub/brake Assembly
Subframe w/Steering Rack Shims
THREAD WILL BE UPDATED WHEN PROGRESS IS MADE, AND AGAIN WHEN THE INSTALLATION IS DONE
NEW PICTURES POST #92
ls1fbody is offline   Reply With Quote
Old 02-08-2009, 06:17 AM   #2
SlowBalt_06's Avatar
Images: 286
awsome job buddy keep it up..i'm also putting my front brembo kit together...any tips i should look out for i bought the rotors and front calipers already..i need to order the lines and what not
SlowBalt_06 is offline   Reply With Quote
Old 02-08-2009, 06:19 AM   #3
Haz l33t wheelz.
ls1fbody's Avatar
Images: 120
yeah, all you need other that that is a pin kit. Check the sticky in the suspension area, theres a parts list embedded in there.
Old 02-08-2009, 06:20 AM   #4
Images: 34
wow....im impressed a little...lol
mrsilent13 is offline   Reply With Quote
Old 02-08-2009, 06:21 AM   #5
Jbernal4368's Avatar
Images: 11
I love my Brembo's... now I need to find some for the rears, and Ill be all set... another set of four pistons sound great to me.
Jbernal4368 is offline   Reply With Quote
Old 02-08-2009, 06:50 AM   #6
Haz l33t wheelz.
ls1fbody's Avatar
Images: 120
the TC brakes are about the same size in the rear, as the LSJ fronts, rotor wise, but we are sticking with the SS/SC calipers for the back because of the e-brake linkage, which is different on the TC, and because parts or more readily available.
Quote:
the rears need to be smaller than the fronts, there is a balance that has to be mainatained, you can't just slap thr brembo calipers on all four corners and be fine.
Old 02-08-2009, 07:04 AM   #7
Administrator
Black SS/SC 06's Avatar
Images: 41
Man you are gonna have some work cut out when you get back from deployment lol.
Black SS/SC 06 is offline   Reply With Quote
Old 02-08-2009, 07:06 AM   #8
Images: 2
seriously. he has like 27495.4 projects to do when he's back
HunterKiller89 is offline   Reply With Quote
Old 02-08-2009, 07:54 AM   #9
Haz l33t wheelz.
ls1fbody's Avatar
Images: 120
haha, i do have a lot of work t do, but the suspension parts are coming all bolted to gether, and i just have to replace it as if it were a kit.
The TVS is on the backburner until the car moves to North Carolina.
Quote:
I have some good buddies to help me, and plenty of time off.
Quote:
gee, thanks.
Old 02-08-2009, 12:17 PM   #10
Maven's Avatar
Images: 77
Quote:
First of all, WTF sig plagirism?!?!?!?! Sig and avatar theft seems to be running rampant here as of late
You need calipers, rotors, pads, and pin kits. You dont need the TC bolts unless you change your knuckles. you dont need new hoses, the stock ones will work.
General Beckmiester: Youre cunning attempt at geting me to expose my hand has failed. Your Sir, looze.
Maven is offline   Reply With Quote
Old 02-08-2009, 12:31 PM   #11
Images: 20
sig plagarism? ralliartist stole Beckmeister's, who probably stole it from someone else. I like yours the good/evil one. you dont use it anymore here....
The General is now being kept in here on a "need to know" basis, and all photo transmissions will cease
qwikredline is offline   Reply With Quote
Old 02-08-2009, 12:41 PM   #12
Maven's Avatar
Images: 77
The Good/Evil one was never used here Qwik
Yeah you cant give him photos anymore, just send him pics of your assistant.
Old 02-08-2009, 12:54 PM   #13
Images: 20
really? i thought it was briefly...gthen you went red but kept the other elsewhere maybe it was on RLF and 10-4 on the assistant....
Old 02-08-2009, 12:58 PM   #14
StreetDreamz's Avatar
Images: 50
All that just for some wheels to fit? No thanks.
StreetDreamz is offline   Reply With Quote
Old 02-08-2009, 12:59 PM   #15
Images: 20
Quote:
note the last pic DOES NOT have a 'rotated potato" mount it has an LNF MOUNT out of the magic GM WHEEL HOP KIT that is FAIL in testing. Cant show all the cards Beckmeister. Sir. Yes Sir...yellow calipers out of the oven time for the 4th VHT coat...
Old 02-08-2009, 01:15 PM   #16
Maven's Avatar
Images: 77
Fixed it just for you. Plus i was getting tired of random PMs asking who the girl in my sig was, LOL.
Old 02-08-2009, 01:30 PM   #17
Haz l33t wheelz.
ls1fbody's Avatar
Images: 120
I do not like that says sam i am.
I will edit the post, you won't have to fear JohnnyBoy.
Please, please keep sending me pictures, and if you want i will post up the picutre of your "wife" for all to see
Old 02-08-2009, 01:43 PM   #18
who was that girl in your sig and what was she saying ha
paul1588 is offline   Reply With Quote
Old 02-08-2009, 01:45 PM   #19
Finally somone actualy does it
nice job plus you got pix
berto is offline   Reply With Quote
Old 02-08-2009, 02:04 PM   #20
RooTBeeR's Avatar
Images: 176
yay, i get to be one of the ******* that was stupid enough to get suckered into this mess and help with the install/how to! lmao
jk will
you know you already owe me like 2 things, now with all these installs, your gonna end up oweing me like a ba-gillion things haha
ps thos pics are tiny
RooTBeeR is offline   Reply With Quote
Old 02-08-2009, 02:20 PM   #21
Images: 20
much lawlz ;off to the gym, watch qualifying from the treadmill
Old 02-08-2009, 02:45 PM   #22
People need to use the thread rating tool more.
5 star!
rocketpunch1221 is offline   Reply With Quote
Old 02-08-2009, 02:46 PM   #23
RooTBeeR's Avatar
Images: 176
Quote:
5 star!
actually, this should get a sticky...once all the info is posted
Old 02-08-2009, 02:51 PM   #24
06blackg85ss's Avatar
Images: 65
very nice man, can't wait to see it completed
06blackg85ss is offline   Reply With Quote
Old 02-08-2009, 03:16 PM   #25
Haz l33t wheelz.
ls1fbody's Avatar
Images: 120
i can't wait either, and i vote for sticky.
Andrew, this is going to be a bolt on i am going to enjoy rocking that in my sig haha.
Thanks for the support guys, this has been in the process for a while, and you know what Paul, i have you to thatnk. So here's to being too lazy to take measurements, resulting in my abandonment of custom forged wheels
Thread Thread Starter Forum Replies Last Post
LNF Redemption Build taintedred07 2.0L LNF Performance Tech 31 04-24-2016 01:10 PM
KMO43 Oct FCOTM KMO43 Front Page News 34 01-12-2016 01:01 AM
Insurance OBD-II Tracker Device exninja The Lounge 39 12-14-2015 01:51 PM
Clicking Noise biniecki Problems/Service/Maintenance 8 10-25-2015 03:23 PM
KMO43 FCOTM + Build Thread KMO43 Featured Car Showcase 37 09-27-2015 09:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
