BWoody Front sway bar end links?
Get low
i searched and couldnt find any answer to this, everyone uses the traction bars..... i need to replace my front endlinks and came across these but realized it said it was for the SS.... will the bwoody front sway bar end links fit a 2.2 base?
I sent them an e-mail about this and they replied back saying that it would work. 2.2's may have a smaller bar, but the hole the end-link bolts thru is the same size on both. i'll be ordering these next week. I'll let you know how it turns out
I have those on my 2.2 Ion and they fit perfect...they were worth the buy too btw.
the 2.0 may have a bigger sway bar but that shouldn't effect the position of the links since it is the same suspension setup.
Get low
ya i need some stronger , better quality ones, my factory ones held up good but the passenger side one finally decided it ditn like the airride and its creaking rlly loud when i turn right now lol so i figured to upgrade instead of factory parts, candy red anodizing is in mind too
The creaking is probably the bushings on the drive train cradle. its a common problem. When you put your new links on (they will fit), loosen the bushings up and grease them.
Dennis
Dennis
I'm getting a set for my b-day from my boyfriend, and biohazard, he ordered the anodized candy red so I can put pics up if you want. No idea when they'll be here, hopefully soon!!!!!!
Get low
which bushings r these? what kinda grease
The rubber bushings under the U shaped brackets that the bar goes through on the cradle. I don't know what grease they recommend, but we just use white grease. When you remove the links you should be able to slide the sway bar one way enough to grease it and then slide the bar back into position. When the bushings get dry, they creak when the sway bar twists in them.
Dennis
Dennis
Get low
Dennis
Dennis
DANRICKARD
10-01-2015 12:08 AM
