clunking noise when hitting bumps
Old 09-20-2010, 11:33 AM
defo98's Avatar
Whenever I am driving and I hit a bump or even small bumps there is a clunking noise coming from the suspension. When the road is flat it is fine but any bump big or small it makes the noise.
Old 09-20-2010, 11:35 AM
Permafried-'s Avatar
I'd guess control arm bushings or strut, both of which make a distinct noise to help track it down. When you go over smaller bumps and listen do u still hear a faint thud?
Old 09-20-2010, 11:37 AM
ecot3c inside's Avatar
exhaust is possibly hitting your cross member. try violently shaking your exhaust to check the sound.
defo98's Avatar
yup its actually pretty loud even on small bumps but when its a big bump its really loud
i will check my exhaust today thanks
Old 09-22-2010, 01:06 AM
08ShowbaltLS's Avatar
same exact thing happens to me...
im changing the cabs and struts to see if it will help.
Old 09-22-2010, 01:15 PM
redcblt265's Avatar
same thing happened here, it was the control arm. get it checked out.
Old 09-22-2010, 09:39 PM
MaxVQ35DE's Avatar
had mine in for the steering recall. i mentioned the noise that had been bugging me for the last year. They found that the swaybar bushings were toast. They replaced the endlinks and the car is so much quieter, what i hadnt realized is that the front end was a little sloppy, and now its SNUG!
Old 09-23-2010, 12:39 AM
arman14's Avatar
I had the same problem, I just replaced the endlinks and the noise is gone now.
Old 09-23-2010, 12:45 AM
chris88z24's Avatar
Swaybar endlinks. Either replace them or do what I did and slam the car into a cement divider at 60mph and get the whole front end replaced instead.
Old 09-23-2010, 08:00 PM
defo98's Avatar
hahaha i will probably just check they swaybar endlinks and the control arm bushings instead of the divider but thanks for the advice lol
Old 09-23-2010, 11:41 PM
FraGmE's Avatar
I had a bunch of noises. It was the CAB's, an almost blown left strut and crazy enough the front swaybar bushings were toast. don't ask me how that happens at 80k which is about 50k miles i believe.
I still have one more noise and the dealer said its the steering column which i'm guessing is the i-shaft. decided to ignore it since I don't want to pay for that right now.
biniecki
10-25-2015 02:23 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
jimbofug007
10-02-2015 12:06 PM
DANRICKARD
10-01-2015 12:08 AM
Tupp
09-30-2015 08:18 PM
Quick Reply: clunking noise when hitting bumps
