Coilovers installed- rear bottoming out?
Old 06-23-2016, 03:37 PM
Supercharged06SS's Avatar
Recently installed my set of BC coilovers and everything went well, but now when I hit a larger bump, the rear of my car makes a bottoming out-clunking type of noise. It's been driving me nuts and I can't seem to figure it out. Nothing else is hitting like my exhaust so I figure it has to be something with the coilovers. Has anyone had something like this happen to them? Do I need a stiffer spring in the back?? Thanks for any input. It is all the way maxed out and the shocks are on full stiffness
Old 06-23-2016, 03:40 PM
I wouldn't be surprised if it's your shocks since they are maxed, maybe not going so aggressive will help
Old 06-23-2016, 09:45 PM
Yeah, I was thinking that too. I didn't really want to raise it because it's already higher than the back. I know there's a bunch of guys lower than me so I'm wondering if I'm missing something. Thanks
Old 06-24-2016, 12:48 PM
johvans's Avatar
I would try going full soft and see if that fixes it. Then work your way back to see where it starts.
Old 06-24-2016, 05:20 PM
I've messed with It a bunch. But don't think I've had it all the way at full soft. I'll try that and see what happens
Old 06-24-2016, 05:23 PM
ItalianJoe1's Avatar
Yeah once it's lowered you run into all kinds of weird issues. Exhaust hits the axle/body mostly, but it can bottom out as well.
Old 06-24-2016, 09:15 PM
rocco11189's Avatar
Had this problem with my car. Your shocks may need to be adjusted as they don't have enough room to travel
Old 06-26-2016, 04:25 PM
Adjusted what way?
Old 06-26-2016, 05:49 PM
Go softer
Old 06-26-2016, 07:28 PM
double clutch's Avatar
Originally Posted by Supercharged06SS
Adjusted what way?
You have to adjust the length of the shock, not just the stiffness.
Old 06-28-2016, 08:18 PM
I know. Just didn't think making them longer would help. But I'll try and see. Pretty annoying to listen to
Old 06-28-2016, 08:42 PM
Theyre all the way short? Are you sure you have the right springs?
Old 06-29-2016, 09:04 PM
Yes. And almost positive, it was a new set from Bc racing
Old 06-29-2016, 09:09 PM
no_ss's Avatar
It's the shock bud. I have my rear springs maxed but my shocks aren't. No bottoming out. BCRacing Type BR
Old 06-29-2016, 09:25 PM
Thanks, same kind here. How much do you have the shock up if you had to guess? Halfway?
Old 07-01-2016, 12:41 PM
no_ss's Avatar
This is the only pic I have of them set up before I installed. If this doesn't help I can go try and take a pic of them on the car. But if you look at the bottom shock in the picture you may be able to get an idea
Old 08-09-2016, 09:13 PM
Messed with the shock and it's still doing it. Contacted bc and probably going to order the extreme low springs for the rear
Old 08-24-2016, 06:48 AM
Anyone running a different spring in the back with Bc coils?
coltonjohnbutler
02-08-2020 04:02 AM
mikeluis92
06-02-2016 10:14 PM
BlueBalt1113
05-23-2016 03:52 PM
INTENSEL61
05-17-2016 07:16 AM
Quick Reply: Coilovers installed- rear bottoming out?
