The OFFICIAL Coilover Thread
#301
So figure this is a decent place to ask coilover questions lol. There are some Ksports local with 4k miles for $600. Seems like a steal. Are they a form>function kind of deal though? I have pedders with the stock tc fe5 shocks and struts, how would ksports effect my handling? Not planning on slamming it. My driveway aint about dat hella flush life... lol
#302
It depends completely on how they're setup. When I bought my used Ksports, they were adjusted horribly and it rode like garbage and handled like garbage. Now that they're adjusted properly, it rides only a little firmer than stock and handles very well.
#304
I rub the same as you. I'm on Megan Ez Coils. Maxed out with rear locking rings removed. Need to lift the front up a tad so I don't rub the fronts every time I hit a bump.
#311
On phone at work so if its been awnsered judt don't reply hahabor maybe link me the thread.
I have bc coilovers, can't figure out best setup with height and the dampening etc. Doesnt ride to bad right now, pretty low. Just wondering if there's anything I should look for or adjust.
#320
How much clearance is there between the road and the bottom of your sway bar? I feel like mine doesn't have much clearance. Also have you ever scrapped your bar on the ground?
#321
#323
Thanks for the replies. Maybe I'm just paranoid lol. Also if I'm thinking correctly shouldn't the distance with the bar installed from the bar to the ground be the same if you were lowered 3" or if you were at stock height? Cause you are lowering the car and not the rear axle
#325
