ottp vs powell spherical bushing
I didn't see those on the site but doing the install isn't a big deal for me
There is no comparison to powell's bushings. The price for his bushing is reflected in the quality and material. The ottp are cheap replacements for a reason, you get what you pay for. My ottp busing was torn only a couple months of use, where as the powell bushings I've had for over a year look new.
Same here, you're not the only 1! I did contacted Josh from OTTP. I had it for like 1 year then the rubber piece is torn. I told Josh about it and he told me that something is loose. I had it torque it down to 145ft lbs, tight as a bitch! Then I waited 1 week just to make sure it stayed there and not let it unloosen. It's still tight ever since I had replaced it. How can it be loose when I torque to spec everything to make sure my car is in working order. Josh did told me that I can take it off and send it back to him. He will give me another 1 since it's lifetime warranty. The only reason I haven't took them off cause it will mess up my alignment again and I will have to pay for alignment $85 bucks a pop! Each time! But if it get worse then I will have to get it off and send it back to him. SMH
Lifetime alignment, $140 bucks. Protip.
#37
Tanks guys for your comments, it helped a lot to take my decision!
After taintedred07 and YelCal7 experience issue with ottp cabs, it seems they don't hold more than the others oem cabs brands. From what I read nobody has bad things to say about powell's one except for the price.
I prefer paying more but doing it once!
Do you think it will be necessary to put spherical cabs and leading cabs now or could I only buy the spherical cabs ones now and the leading cabs later.(budget concern)
#39
For the record, I was comparing the mount bushings. I do have Powell's spherical trailing cabs and you get what you pay for and then some. Rarely people upgrade the leading cabs. You'll be fine just doing the rears. I immediately noticed tighter steering feel and response. Powell has been working with this platform for many years with gm engineers ect. His products cost a lot because of what is put into them. They're not a bargain piece, they're a legitimate upgrade from the real deal.
#41
Tanks guys for your comments, it helped a lot to take my decision! After taintedred07 and YelCal7 experience issue with ottp cabs, it seems they don't hold more than the others oem cabs brands. From what I read nobody has bad things to say about powell's one except for the price. I prefer paying more but doing it once! Do you think it will be necessary to put spherical cabs and leading cabs now or could I only buy the spherical cabs ones now and the leading cabs later.(budget concern)
#47
I just ordered a set of the Ottp bushings I can't wait to through them on!
#48
Just got my OTTP bushings. 55k and my stock rubber ones were torn badly. I have them pressed into the arm but going to get my ball joints as I feel like replacing them before reinstalling. It was a breeze to install, but definitely pay attention when pressing! Getting it to the half way point, it tends to press uneven. So I would press it and if it started to creep off, I would reposition to straighten it out and line back up center. But fit was great and flush with arm.
#49
Just FYI, I had to adjust the alignment on my 09 SS/TC after I did the Powell CABs. The toe on the passenger side was off by a bit. I can get tire spin in 1st and 2nd gear, but it is more of a light squeel and not extreme rearview-mirror-changing-positions wheelhop/vibration. It also seems to grip a LOT better at WOT/speed in 2nd gear, and I've always had the factory Quaife LSD.
#50
If the original bushings are torn, definitely always need an alignment. Technically, it should be done anyways since you are going from a voided rubber to far more rigid bushing. The spherical bushings are not going to have the give that rubber have, so even stationary the alignment can be affected.
I can attest to the car putting power down. Car is staying planted on hard acceleration now. I also feel my car needs more power now. I was completely content before, but now my car isn't throwing me all over the road under heavy acceleration, so I want more power. I had the hardest time controlling the car if I had to pass someone, but it is so much more stable now. Still lacking my alignment but should be getting that done Saturday.
