Powell's take on replacing bad control arm bushings.
#77
A warning to others: dropping the frame for a siezed bolt to CAB sleeve is the only way, cutting the bolt out worked for me but lots of heat (acetylene).
freeze your spherical cabs before install! with a little grease they go in butter smooth.
Thanks to john for this thread and being such a great guy! Really helped me out today, wouldn't have been able to deal with this POS car without him lol.
#80
It's really not too bad at all, assuming you have access to a shop press. If not, I would take the control arms and bushings to a local machine shop or dealership that you might be in with. Throw $20 their way and call it a day. About 10-15 min of work, if that.
#83
Well Im here at Ft Lee and luckily they have a press in their auto craft area. So it appears that next weekend ill be driving over there and replacing my bushings, sway bar end links, and rotors/pads. Could be a long day Im assuming I should try to get a shroud on the press that just hits the outside metal parts of the bushing but not the arm. As opposed to cutting out the rubber and then attacking the metal. Fingers crossed my bolts arent seized... the car did just spend 3 years as a DD in michigan for 35k miles.
#86
Says $900 a pair here
https://www.cobaltss.net/forums/gene...powell-296456/
You can buy replacement steel arms, but lately on Rock Auto they have been priced higher than alloy arms.
you can put in solid malibu bushings but they dont fit right ; you can buy Moog ball joints cheaply as well if you want to do the work yourself. But no one can find trailing cabs like ours we are the only folks who make them. A typical production run costs 10,000 dollars so please dont be surprised if I summarise the costs so you can see this is not a high margin rip off.
Amazon may have control arms cheaper, it seems to depend on the moon or something. If I could predict it, I would buy from Amazon . But day in /day out I buy GM parts from Crate Engine Depot. I pay about the same you pay, but I can depend on the GM parts quality and Tom@ced has great customer service.
that is all....lol
#89
On a saturday, get ready and drop cradle. make sure you have a sawzall. cut the bolt out as Noor did. Then insert the new arms and bolts if you purchased from me with lots of anti seize and you will be good.
you will need 15, 16 19 and 21 mm sockets for this job. an angle torque wrench or a black sharpie. So where 25 degrees is called for in the torque specs mark the nut the arm and the socket and after torqueing to the correct spec, tighten the nut ONE FLAT of the hex in travel= 25 degrees
#90
Yeah add the bolts to my order. Ill actually have access to a lift(thank goodness for army auto craft) so hopefully that helps things. I am currently working with Gloria to order the CABs. I sent a confusing email sorry. But yes ill be sure to do this early in the morning so I have plenty of time if it gives me trouble.
#91
$400 sounds much more reasonable than $900. lol
fwiw, I've changed a ton of control arms at work here in the salt belt, and i've only had one bolt get seized inside a cab sleeve.
#93
Looks like I need to start saving now John if i where to mail you a set of LSJ alloy arms for the whole CAB set up would that change the cost? Not sure if the ball joint would need to be changed, I'll leave that one up to your opinion (I have a LNF).
#99
Salt damage is incredible bad. They now wash the freakin roads with brine from tanker trucks. For stupid people who want bare pavement in winter, get killed because they dont buy good snow tires and keep driving and cant drive worth crap anyway, and the families sue the roads dept. for not getting rid of the snow and ice off the roads. Oh and studs are banned as they wreck the roads.
salt damage? a scandal.
texas? bunch of pansy's get ice and the interstate closes down for 100 car wrecks coz
driver mod.
lol
end rant
#100
talk to her I be busy
