SSC/CM lowering springs
Old 11-22-2013, 11:39 AM
  #401
andrewcarr1993's Avatar
About what the ss lowers + ~1.5 in. The base model will be as low as the ss but there isn't the same ground effects so it'll look a bit higher.
Old 11-22-2013, 12:05 PM
  #402
Originally Posted by SS89
My SSC springs looks just like the CM springs on the picture... weird
edit: here's a picture
those look completely different what are you talking about lol
Old 11-22-2013, 12:07 PM
  #403
Those look like SSC springs and FE5 springs.
Old 12-04-2013, 04:16 PM
  #404
Jedi Master
Tsbbzm's Avatar
Before
After
Pretty sure my tank was close to empty too on the after pics lol
Pros: Lower, looks 10x better, very good price for what you get, ride quality is the exact same, smooth install, better handling
Cons: None
Old 12-04-2013, 04:33 PM
  #405
chevygirl2006's Avatar
the rear still looks kinda high to be honest, but it still looks better than it did.
Old 12-04-2013, 04:53 PM
  #406
Jedi Master
Tsbbzm's Avatar
Yeah it goes down a little more with a full tank but im happy with it
Old 12-04-2013, 05:00 PM
  #407
you like the ride?
Old 12-04-2013, 05:08 PM
  #408
Jedi Master
Tsbbzm's Avatar
you like the ride?
The roads in Bg are not that bad so i dont know how well they would fill on rough roads but on decent roads i cant tell a difference at all. Thought going into it i would lose a little ride quality but that was not the case
Old 12-04-2013, 05:16 PM
  #409
Mine used to ride awesome but not so much anymore.The springs are killing my struts and shocks. It's almost time for new ones.
Old 12-04-2013, 05:17 PM
  #410
Jedi Master
Tsbbzm's Avatar
How long hve you had them on?
Old 12-04-2013, 05:21 PM
  #411
may 2012. They have about 8k miles on them. My stock fe3 struts/shocks are about to hit 100k
Old 12-04-2013, 05:24 PM
  #412
Jedi Master
Tsbbzm's Avatar
when they go out what are you going to get?
  #413
ss/tc fe5
Old 12-04-2013, 05:28 PM
  #414
Jedi Master
Tsbbzm's Avatar
thats probably what i will go with when/if mine go out
Old 12-04-2013, 05:29 PM
  #415
koni is a little bit too much for me.
Old 12-04-2013, 05:30 PM
  #416
Jedi Master
Tsbbzm's Avatar
yea ideally id want konis but a bit out of my price range
Old 06-27-2014, 04:59 PM
  #417
wol-shiver's Avatar
SSC cm are the same. I just spoke to Leanna at ssc\cm. She says zzps site is wrong in mentioning 1.5 in the back, so is the SSC website which is not updated/obsolete.
I want these springs but have no idea how to make sure I end up OK in the back vs others who have it horrible.
Old 06-27-2014, 07:47 PM
  #418
Then why do the springs look different?
Old 06-27-2014, 10:21 PM
  #419
wol-shiver's Avatar
Unsure CG2006. Maybe someone ordered or was sent the incorrect spring ( SS vs non SS) And took pics. Leanna told me rvw is the parent, SSC the wholesale and cm is the retail. All is tesame
Old 07-17-2014, 05:36 PM
  #420
GBRunner24's Avatar
Can anyone grab me a measurement from ground to fender on their CM's? Specifically if you have 17's. I'm always curious what others is because I feel like my drop is not the same as everyone else who posts up on CM's. It's likely just me always wanting them to be lower haha
Old 07-17-2014, 06:56 PM
  #421
Vtec Rep
BPacak's Avatar
its probably because your on 17's haha.
Old 07-17-2014, 08:40 PM
  #422
The measurement from the fender to the ground doesn't have anything to do with the size of the wheel. The wheel gap does though.
The front of mine is 25.5 inches from the fender to the ground.
bigdeertz
11-17-2016 09:41 AM
ineedacobaltss
11-07-2015 02:25 PM
dennis69
10-20-2015 04:49 PM
Dylan Johnson
09-30-2015 08:57 AM
09-26-2015 06:44 PM
Quick Reply: SSC/CM lowering springs
