Struts and Shocks
Struts and Shocks
I am wondering if there are any non adjustable struts and shocks for use on lowered vehicles. Konis are way out of my price range and I figure non adjustable will be a bit less expensive. Any advice?
Well i mean the whole thing where the spring seats and its attached to the knuckle since the koni fronts are inserts. i just need to go to a scrap yard and get some, cut those since if i screw up i wouldnt be able to drive if i use the ones on the car
General rule of thumb is that struts and shocks are only designed for a set amount of travel, and that any time you lower the spring height, you reduce that travel. Coilovers are the only true way to maintain properly shock travel while lowering you ride. That being said, acdelco FE5 replacement struts and shocks are your best bet as an upgrade which they sell on rockauto.com . Just be sure to consider how low you are going, as even the FE5 struts can only handle so much lowering before the travel is reduced to the point where the strut becomes useless and ride quality suffers. All struts and shocks on cobalts are of exactly the same height and have exactly the same amounts of travel. Im sure powell would argue that the YYZ springs are probably the minimum recommended amount of lowering while maintaining acceptable travel of the shock/strut, and he would be right.
DANRICKARD
10-01-2015 12:08 AM
