Technical Articles A central location for technical articles gathered from throughout the community and internet.
Air Filter Testing
Old 01-21-2015, 10:35 AM
  #126
UnkleRaRa's Avatar
I increased my mileage with my airbox setup, and def felt a vast improvement over the sad ass Injen intake I used to have.
I also had the AEM intake. It is the same thing as running a modifed airbox. Just much more expensive.
I felt more power while running the factory ac delco than the K&N drop in filter. My car made 299.45whp with the factory filter.
I might figure out a way to use the AEM SRI with the stock AC filter, and make a modified box of some type..... sounds like a spring project though...... -17C today lol.
UnkleRaRa is offline
Old 01-21-2015, 11:01 AM
  #127
umrdyldo's Avatar
Probably just better to get the ZZP Intake Tube with stock air box and stock filter. That's what ZZP used on their setups.
umrdyldo is offline
Old 01-21-2015, 11:17 AM
  #128
Administrator
Administrator
Staged07SS's Avatar
He has an SS/SC. If I had an SS/TC, thats what I would do though.
I wouldnt waste your time. The AEM intake is no larger than the stock airbox inlet pipe at the MAF sensor.
All you might gain is some sound, because the filter would be 100% exposed.
Staged07SS is offline
Old 01-21-2015, 11:21 AM
  #129
Its not a bad setup, the bypass valve is so quiet though...
ECaulk is offline
Old 01-21-2015, 01:38 PM
  #130
UnkleRaRa's Avatar
Maybe ill just drive a little longer and wait until the weather is a little better to make a proper judgment on the fuel economy, lol. Not worried about the sound as much as having a clean engine and spend as little on gas as possible!
Old 01-21-2015, 01:42 PM
  #131
Administrator
Administrator
Staged07SS's Avatar
I can care less about gas mileage, lol. Even though my car gets 22 on avg around town with a heavy foot.
I changed back to the stock air filter to protect my engine and it actually provided more get up and go than the K&N drop in (believe it or not). More than likely because it is a much larger filter.
Old 01-21-2015, 01:50 PM
  #132
UnkleRaRa's Avatar
I started a new job last year and drive 100km everyday back and forth to work :S
The last job I had was less than 2 km from my place. I cared a lot less about mpg back then
Old 02-16-2015, 12:35 PM
  #133
syclone01's Avatar
I've known that the K&N's don't filter the fine particles for years. On one of my Grand Nationals back in the early 90's I had a cold air kit with a scoop mounted right under the bumper. I had one of the K&N cone filters that was prob 8-9" long and after maybe 15k miles I took it off to put on a longer one after upgrading the turbo. I stuck my finger inside the filter and ran it around the inside step/ledge where the filter is the largest and this area obviously had some filter oil finely misted over it after all the miles and there was a real fine grit all around the lip area. I could feel it on my fingers, it wasn't as coarse as sand but more like a flour/fine consistency. You can hold a brand new K&N up to the sunlight and look through it and see many small areas of direct white light, thats nothing but small/minute holes in the media. Pretty much nothing filters as well as the stock filter material. Heck, the K&N prob filters better as all the small/minute holes start getting clogged up....at the cost of airflow. Too bad someone couldn't come up with a different type of airbox that used one of the largest style flat filters that GM has, or use 2 large GM filters on the sides of the airbox etc..
syclone01 is offline
no_ss
10-18-2015 11:58 PM
Trav3480
10-01-2015 08:17 PM
grampss
09-27-2015 08:51 PM
DocSvensk
09-27-2015 02:24 PM
OrangeCoba
09-25-2015 06:06 PM
Quick Reply: Air Filter Testing
