LDK install
LDK install
Hey all,
my number piston cracked and im looking into the LDK long block swap from zzp.
while looking it over all the sudden i see a review posted 7/16/2014 saying,
"talked to someone at ZZ when i ordered the engine and was told all i would need was the fuel rail, it was missing the injectors and the o-rings are imposible to find at any dealer or parts store, also the intake gasket had to be ordered from dealer because no part store carries it. oil pan is different so the dip stick does not fit correct, did not come with the oil cooler and the oil pan hits the cross member on one side even with new mounts."
does anyone know anything about what is going on here? is this a special case? no one else have this issue?
any help or guidance would be a big help, Thanks.
Delta coupe
09-30-2015 08:11 AM
