Is this a thing with Dynojets???
I apologize if this isn't the right section. Anyway, a shop had my car for 2 weeks trying to get a tune done (they had the flu run thru the shop and a guy quit hence the long time). I get a call when it's done and of course I couldn't make it out before they closed. I asked the guy the numbers and he said he'd talk to me when I picked it up. He then sends me a graph with just MPH and HP. I figured that was just something to show me a number before I picked it up. Nope, that's all they had. The guy that tuned it said he couldn't get an RPM reading because of the coil design (something about 2 wire vs 4) so the dyno would read it was at like 20k rpm. They use a dynojet 224x. Is this really a thing? I'm not really happy about the whole thing since he didn't do a baseline, they were supposed to record the dyno, and then all I get is that weak ass graph. I understand the dyno is just a tool but it would have been nice to see what the gain was and also be able to see where it makes the best power.
It's not an uncommon thing for a shop to not be able to record torque, just depends on the level of **** giving and knowledge the operator has.
Sounds like the shop has other issues taking precedent over their customers cars.
it shouldnt be an issue as long as they have a low voltage induction pickup. i had to play around with both my cobalt and 944 to get it to pick up the rpm, and then had to change the multiplier in the dyno program, but once you get it, it reads correctly. hell, you can even pull the coil out and use a plug wire from a 240 between the coil and plug and use the spark plug wire pickup. we do that to so you can use a timing light when setting up a stand alone, but you can use it for the dyno pickup.
jmix (03-14-2017)
Thanks everyone for the responses.
jmix (03-14-2017)
Well I just received an email back from them about trying what was said before (clamping the wire and adjusting the multiplier on the dyno) and this was their response.
"This Friday at 3:15 will be good. We do have a C7 that will be tuning that day but we can squeeze in for the dyno pull at 3:15. I did speak with Justin and he is able to provide you with Boost and AFR at the time of the dyno run. In order to provide a proper tach signal from a GM coil is a lot change to our standard dyno program set up. We have the latest Dyno Jet hardware and software and it is not in the best interest of our set up to make these changes."
They make it seem like it's not easy (really just seems like it's not like a vette) so they don't want to make the change. The boost info they are talking about is I requested they turn it up in first some more.
There is only 3 in my area and one of them basically blew me off. I ended up going with this one over the third because for $100 more they road tune after the dyno. In hindsight I would have chose the third but now I'm $750 into this shop. I even emailed dynojet and this is what they said:
"Without knowing the specific equipment or the dyno control program this shop was running I can’t speak to what this shop may or may not be able to do. However, with a primary inductive pickup on the coil trigger wire or an ECM signal wire you should be able to get an RPM source on this car. Yes, you are correct we need RPM in order to calculate torque, it could be that they are use to only sampling from a spark plug wire with a secondary inductive and may not have had the primary inductive available, or perhaps they were using a third party system or program in order to read RPM some other way. We know not every car is going to have RPM sampled in the same way every time, for this reason we offer several ways of picking up RPM. Thank you for your time, please let us know if we can be of any further assistance.".
"...it is not in the best interest of our set up to make these changes." in other words we don't want to make any effort. Screw them. I'd let them finish what they can, then time for some bad reviews everywhere you can think of (yelp, bookface, etc.)
Sharkey, can you please explain exactly what you did? Do they just need a low voltage induction pickup clamped directly around the coil pack wires for number 1 cylinder and then adjust the multiplier (by how much or does it vary) in hp tuners? They agreed to let me bring the car back and give me a couple more runs for free so I'd like to help out as much as possible to get the dyno to read torque and rpm. Again, it's a dynojet 224x dyno.
in our shop we only use the primary inductive pickup unless the car has a distributor.
jmix (03-14-2017)
I gave them money one time and this thread is basically the results. Me going back is for free. If I knew how to tune than I wouldn't take my car anywhere since I do pretty much everything else. They did tune the car and it runs good but I didn't like paying $750 for a graph that just shows an incline from 50 mph to 123 mph with a HP number.
This shizz makes me mad. What's it to them what kind of car you drive? "We do have a C7 that will be tuning that day..." why the eff should you care???
we used the primary inductive pickup on one of the 4 wires at the coil. sometimes you can even clamp around all 4 and get the reading. with the lsj coils i got a signal pretty easy, however i know i had to fiddle around more with the lnf/2.2/2/4 style coils. once it gets a signal on the dyno computer they just need to change the multiplier so the rpm on the dyno computer matches the tach. its a drop down menu, options are something like 1x, 2x 4x and 8x. its really simple, if these guys have ever dynoed a mod motor mustang or new hemi they should know how to hook it up.
Mods are 2.9 pulley, full zzp exhaust (shorty header, catted 2.5" exit DP, catback), 60's, walbro 255, zzp HE, dual pass and option B. The engine also has 157k miles so it's not new or anything.
some shops prefer to use uncorrected numbers. correction factors just tell you what it would make under different conditions. myself, i prefer to know what the cars making right here right now. all correction factors are good for is trying to compare with another car.
as it comes down to, the dyno is a tuning tool and the numbers tell you if your going in the right direction or not. its primary use isn't to see who's car has the bigger d!@#
