Bad ZZP PCM, ZZP refusing to refund or fix
I will say that i was having issues similar to yours except I was getting a P0300 (which was hell to track down) and also i was getting P0171 (too lean). Mind you i have an LE5, but its now S/Ced and i did the tune with ZZP.... So, i hopped on here and asked people what could be the issue. I got every answer under the sun and after i went through all of that, peeps said it was likely the tune. Now, i called ZZP and left a message prior to all of this, i cant remember who called me back but they called me back like after a day. Getting to the point here, it turns out that AFTER EEEEEVVVEERRRYYY single thing i tried (you name it, and believe me i did it probably at least a handful of times) it turns out with a bit of intuition i had a feeling it was the valves leaking. Specifically the valve seats. ZZP told me the same thing they told you "Its the car not the tune.." etc etc.. Turns out, it was the car! Something so small and yet a massive headache along with heartache. I stand by ZZP, they have not done me wrong. Even when i think its them.
Just my 2cents is all.
Well I just picked my car up from the shop after being there all day. They tested fuel pressure, boost leak test, vacuum leaks, compression, and did a case learn.
They basically told me what I already knew and that was that it's running really rich in top end. They pointed at the tune.
At this point I really don't know. It was shooting fireballs all night last night. It's rich as ****. Haha.
I did move to a step hotter plug (back to factory heat range) and that seemed to help a little bit but it's still breaking up and blowing fire.
Find someone with HPTuners to do a datalog, surely there is someone near by that can one. They don't cost credits so anyone with HPTuners can do one. You can even buy cheap OBDII data logging devices from amazon and use that to data log.
I don't know if ZZP lock their tunes, but if not, and you find someone with HPTuners, then get screen shots of the injector scaling tables, PE fuel tables, and any other fuel tables (don't remember all the LSJ fuel tables off the top of my head). If there is something wrong with the tune then a datalog and the fueling tables should make it easier to pick out.
If you log, make sure you log everything possible. VE, MAF, Fuel pressure, commanded PE, and injector pulse width are probably most important but the more you can log the easier to find an issue.
I doubt my clutch is slipping if it's blowing second gear out of the water on a decent tire.
Secondly, I would go back to my old PCM, but damn wouldn't it make sense that I didn't have it if it was a core?
Third, if I could go back to the old PCM via a flash would I be having these issues or even boughten a tune from ZZP, no. I could write the tune file myself.
Still have not explained why my car revs 7500 when it "should only rev 7200". And only revs too high on this PCM. Let alone the bank 1 too rich.
Sum up for those not not paying attention:
car ran fine before just had a engine light for the ZZP header.
Buys zzp tune, cars running rich, popping, shooting flames, revving too high.
Ways ive tried to resolve with ZZP:
full refund and return my original PCM
offer a new pcm with a new tune using a ZZP intake, and I buy the ZZP intake, to help with MAF calibration.
Yes. Steve from ZZP and I have been working on this together. He's been great. I would be rest-assured something is solved soon!
I have heard of people taking a piece of wire and grounding the ECM. Apparently some crazy things happen because for some reason internally it's shorting out to the outside. Like I said just a thought. I did it to mine to be safe...
#36
I'm definetly going to keep trying on my side. Im not sure what it could be, but I'm determined.
If i drive it real easy for a few key turns the engine light will go off until I get on it again. So I wouldn't say that it "too" rich under 3k rpms.
I'm going to keep playing.
#37
So got together with a guy who has an HPTUNER and tweaked the tune a little bit mostly with the MAF chart and peak rpm. Everything seems to be working good, haven't had a light through a few miles of driving. Will just have to see. Car is running really strong.
#38
Nice. >fingers crossed< Put some miles on it and report back. Gotta hear how it turns out.
#40
So your buddy just tuned a bit with the MAF? Did you guys have to do a few pulls to get it all straight or did he just go right in to your tables and change some numbers??
Did you let ZZP know what went down?? Sucks you spent all day with them and they couldn't figure anything out for ya and then your bud hooks up and all is well.
#41
Basically I was watching the MAF readings and they seemed a little high at idle. It was reading like .750lbs/min or something like that. So I swapped MAFs with my buddies stock SS and it was reading nearly the same, so we took a look at the tables and adjusted them a little bit. Got the reading at idle much closer to stock and the fuel trims reduced by over 15%. The light did come on today after filling up but was only on for a few miles and is back off. I didn't even get a chance to pull the code. I would have to say now that I'm very happy with the tune now. The car does exactly what it needs and should do. I feel confident in being able to move on to other things with the car such as a quieter exhaust!
#42
#43
You must have ZZPs dick so far down your throat that you can see or think straight.
I noticed at idle they were off, and made adjustments to the whole curve.
You see, the car was running rich, and -20.7 stft and ltft would tell me that it was far off.
You must work for ZZP being such a hard rider and believing that they are perfect.
Have we forgot that my rev limiter in gear was set too high too? Lol
I still want my refund, I had to make adjustments to their tune to fix their silly mistakes.
#44
That moment you realize other people have your issues (not the only one I can keep post screenshots for ZZP since this thread I'm sure will attract new customers) and ZZP treats them the same way.
#45
If we figure in o2 sensor, terrible tune, spark plugs and numerous tests I'm out over 70$ in parts, 109$ in the tune, and 10$ in shipping, plus two weeks of my time trying to figure out what is wrong with my car instead of fixing the tune like the actual problem was. Remember in their emails, they're perfect, they cannot be wrong. It's impossible for ZZP to make a mistake *rollseyes*.
They even had me run a fuel pressure gauge with an extended line through my hood and into my window hahaha.
Company is a joke and needs to stop trying to tune cars if their going to act like they perfect and can do no wrong when all you can do is find complaint after complaint on them.
Dont ever expect a refund from a shitty tune, their resident tuner is the one who decides if you get a refund or not, and of course he's perfect inside his head, can do no wrong, Cobalt tuning god.
I even requested a refund with them sendinf sending me back my original PCM and I'd send them back theirs, but that was not good enough for the tuning god.
Either way, I and many others will be avoiding ZZP. I'd hate to get something with a shitty weld and get blamed for the weld.
stone4779 (05-13-2021)
#47
From what you told us your fuel trims were fine all the time, except at high RPMS.... You story here keeps changing.... Either way glad you figured out your issue. The only thing I don't understand is why would you order a ZZP tune if your buddy has HPT wouldn't it have just made more sense to have him tune from the start?
#48
