HP Tuners Tire Size
got my speedo calibrated with the 4.45 trans. entered gear ratio of 4.45 then adjusted vss in increments of 100 till I hot 72000- Then fine tuned to a final 72050. Pretty much right on with GPS
SO if you have a 4.45 trans with 225/40/18 wheels- it should RATIO- 4.45 VSS-72050
if it is reading to fast still adjust the VSS UP more in increments of 100. IF you are reading slow adjust down. Pretty simple!
blueLNFftw (06-11-2016)
If you're changing the final drive ratio in a fwd car, nothing needs to be changed within the tune what so ever. Not even the final drive settings.
If you're changing tire sizes though, all be it not absolutely necessary, you can adjust some of the vss settings to get your speedo a little closer to exact. In most case though, people tend to go wider more so than taller or shorter so changes are generally not needed. If they do go taller/shorter, it's usually pretty minimal.
dz302 (07-24-2016)
metroplex
05-06-2016 10:25 PM
carid
04-13-2016 09:18 AM
