Need Tuning Help - Middle TN, S. KY or N. AL
I just replaced my ECU with one from ZZP. I need to do the crankshaft relearn as a result. I also just switched from the OEM LSJ injectors to the ZZP Bosch 42 lb/hr ones. I'm about to put in the 2.8 pulley from OEM size, when I find a hydraulic press to use.
Oh, and I get a code for air/fuel ration being too rich.
Slowbalt, I think you could be right. At first, I thought the supercharger integrated bypass valve only opens when you get into boost. And otherwise the engine runs with the valve closed - in naturally aspirated move. But I have been watching my Long Term Fuel Trim. And it mostly runs at -20 at idle. And it climbs to 0 as I approach 0 vacuum. So now, I think you are right. Do you know anyone in Franklin that has a hydraulic press?
Are you doing your own tuning with HP Tuners? The last few tunes I've seen from ZZP have closed loop disabled, which would throw the code you mention if the airflow isn't fine tuned. IMO it is better to leave closed loop enabled unless you have good reasons not to.
Do you know anyone with HP tuners that do remote tunes?
and you shouldnt be that far off from going up in pulley sizes. maybe during power enrichment, but not during closed loop cruise and idle
did zzp send you the tune for 42s, or did they send you a tune for stock injectors?
Honestly I'd email ZZP or find paperwork that will tell you what you are tuned for.
If they disabled closed loop then the computer will retain LTFT. LTFT will remain until they are reset with a scanner. What are your STFT like? If they are zero you aren't entering closed loop. You still have to buy HP to be remote tuned unless you just send the ECM back to ZZP but that is not optimal.
Local shop said they'd swap out the pulley for me for 30 or 40 bucks. I just show up with the M62 pulled already. It is scheduled for tomorrow morning, pending my boss' approval.
And you are right. I got the 2.8 and stg 2 belt on and the LTFT began to move closer to 0. After 30 minutes, that DTC went away. And then I got the crank relearn done.
Now, the issue is belt slip. Just after 12 psi, I hear a fluttering type sound from the engine bay. There is some power and boost loss. It is reproducible. It happens anywhere from 3,000 RPM and up.
I searched some and saw some folks use belt dressing. The belt was a little dusty when I got it. I might try that after I search some more.
I ordered it. I figured it would be fine because it was super tough to put on the belt. I can't imagine what it will be like with the larger tensioner pulley.
did you get a genuine gm belt? or was it zzps off brand thing?
I ordered the belt from Crate Engine Depot. It came in a GM Goodwrench cardboard package. The numbers match this:
http://shop.zzperformance.com/resize...&bw=600&bh=600
I can't tell if it really is genuine except that's what it says on the box. Also, CED said there is a nation wide back order. And the stg 2 belts are hard to come by right now. And mine was drop shipped from Ohio.
Maybe a chance because it is a new belt? It holds boost up to about 13 psi. Now I wish I wiped the belt down with a clean towel because it looked a little dusty.
I'll see how tough it is to measure the belt when I get the larger tensioner pulley installed. The box says it should the 1.767 M. I will need to figure out what that is in 'Merica. It did seem to do a little better with 60 degrees out versus 40.
Solved
It turns out that I am a chowder head. The new pulley came in. But I began having doubts about the belt slipping. I got past 12 psi again and watched the boost gauge. I was in denial. My boost gauge wasn't fluctuating. I just read about it and saw what I wanted to see. Then I read about spark blow out. I figure that I'm overdue for a spark plug change anyway. I took out my old NGK BKR7E. They were all worn down pretty bad. I'll post some pics later. I know I can't read a plug. But the ground strap was worn down. One side of the center electrode of the "V" was worn almost to the valley. And the other side was getting there. As a result, they now measure at 0.053 to 0.055". New BKR7E @ 0.034 and the it runs at 17psi without issue.
I might hang on to the larger tensioner pulley - just in case.
Thanks everyone for the help. You helped your Cobalt brother get from stock power levels to maybe 250 WHP. I just have to figure out what to do about IAT2 for track days...
