Quick PCM question
Quick PCM question
So i am in the process of swapping a bad 2008 LE5 motor over for a 2007 LE5 motor will it be plug and play or do i have to get a tune to recognize the new motor? thanks for the help
With both motors being le5....Should be plug and play. As long as all sensors are in the same place with same plug. You do need to relearn the crank sensor. Any shop should be able to do that
